A
Anonymous Posted on May 17, 2017
Hello, we wonder if we could destroy cds except papers. Thank you
Epson stylus sx125: my printer keeps on telling me that I dont have paper in it or its not loaded properly. i have used different types of paper, bought new ink but it always gives me the same error. if it...
your paper feeding roller is dirty or worn out.
If you take out the paper from the printer you should be able to see part of the loer assembly. Clean it with a wet tissue and let it dry.
Afler theat give it ia try.
Regards.
original-new-pickup-roller-for-epson-l100-l200-l101-l201-t22-tx120-tx130-sx125-s22-sx130.jpg_220x220-qedtgpntabuzzsha1ph2mds0-1-0.jpg
LAT9116AAE transmission belt slipping, replaced belt & still the same problem. motor is loose so to adjust tension, so am wondering if trans. is pulling to hard, ??? do these fail & is it cost...
Hello, Thank You for using FixYa. I will be helping you today. Sometimes the pulley becomes glazed.. Use some sand paper and rough up the pulley on the motor and trans. Also make sure the belts on on the righ grove of the motor pulley.
Thank You and please rate my answer if it was helpful..
My hp photosmart c5580 won't print the correct ink color on dvds
Unless a printer is specifically designed to PRINT on CDs or DVDS, that's the problem. Usually a program called "LightScribe" is used to print on CDs or DVDs right in your DVD/CD Drive. For printers, use a Self Adhesive DVD/CD PAPER Label(s) that you can buy in the store. Inserting DVDs or CDs through a printer can really mess them up and Damage the rollers inside!
1helpful
2answers
Will jukebox read custom made cds?
Hello donovan_k111,
I should be able to play them since mosy CD jukeboxes play stock CDs anyway.
Thank you,
Shuttle83
1helpful
2answers
My DVD RW drive won''t open and the one below it opens sometimes,
Hello;
Have you tried Windows Explorer; "right" click on the drive and select 'Eject'?
Also, if it's not reading at times - sounds like dirty lense; use CD/DVD cleaner; you can buy those anywhere these days very cheaply.
I hope that helps,
Thanks.
Are those papers printable on Brother HL-4050CDN ?
Hello !
If you want to print on canvas you need to use a plotter which use ink. An example is Roland or Epson. Personal i use Epson T5200 plotter and the result is awesome.
2helpful
2answers
Difference between Brother HL-4040CN and HL-4050CDN printer
The D stands for duplex printing (both sides of paper)
2answers
Paper feed
Absolutely wonderful, concise,easy to follow directions on "paper feed" problem. Unfortunately it still does not work even after I did your directions twice...just in case! I will have to find a service store in my area. Any ideas?
But anyway, I cannot thank you enough for this wonderful service
Mary Louise
sig.jsp?pc=zszeb113&pp=zuxdm265yyus
2answers
Cdr/dvd
the lazer might be going bad on the CD side instead of DVD side i recommend a new ROM drive
k24674
ADMIN Andrew
ADMIN Andrew
