Question about OKI Office Equipment & Supplies
We have problems with OKI 5720 it seems to freeze when connected as LAN printers.
How can i switch on wireless radio on my pc?my laptop is acer aspire 6930.followed the instruction how but didnt work.
I had the same problem with a Sony Vaio. It seems one of the updates put entries in my registry to start a Vaio Lan Manager with Windows.
Check these keys to see if any kind of a 3rd party Lan Manager is running. If so, delete the entries and reboot.
Sorry about the lateness of my answer, but I just had the problem.
Good luck.
Jul 26, 2009 | Acer Aspire 5720-6661 Notebook PC
I have a new network printer (Samsung SCX-5635FN) I cant get connection to the printer. I have connected to the LAN port of my router and tried both DHCP and static IP. I have try to change the LAN cable...
have yo installed the printer on to the system ( add a printer ), have you installed the correct driver for the printer
it is not a matter of just connecting leads and expecting it to work
Apr 11, 2017 | OKI C5300n Led Printer
Oki b4600 displays check image drum toner senror error
Try this:
Press Online
Press Menu repeatedly until MAINTE MENU displays. Press Select.
Press Item+ until DRUM CNT RESET displays.
Press Select.
Jul 01, 2009 | OKI B4600n Printer
OKI C5650n USB port not working
Yes, well I can´t help you to solve that problem and in fact i´m hoping that you´ve already solven it, cuz right now i got the same problem with my c3450... It worked just fine under vista x64 but now on windows 7 x64 i have the same problem as you have/had!
Jun 02, 2009 | OKI Office Equipment & Supplies
Setting up an OKI printer on an IMAC
Without mac drivers you do have a problem. Put it on ebay and get another printer that supports mac and windows.
May 12, 2009 | Apple MacBook Pro Laptop Computer with...
OKI C3530N Multifunction Printer
Check the left side of the drum cartridge.
There's a little door that may be stuck closed.
Carefully push it open with a small screwdriver.
Oct 31, 2008 | OKI C3530N Color MFP Printer
Oki ML 320 Turbo/D IBM - JetDirect 170x Print Server prolems
Check the receive buffer on the Oki. I usually set it to the highest (88k or 128k). You might also check the print head gap if you are printing multi part invoices. If the print head is too close it may overheat and stop printing. If you have a different printer, swap it out and see if it prints correctly. It may be a problem with the JetDirect 170x, not the printer.
Nov 08, 2007 | OKI MICROLINE 320 Turbo Matrix Printer
Waiting your help
Your printer does not have a display to let you know what's wrong with it. To check the unit, you must install the Printer Monitor software that came with the unit. Your problem most probably refers to empty toner or drum replacement.
Aug 14, 2007 | OKI B4250 Led Printer
23 people viewed this question
Top OKI Office Equipment & Supplies Experts
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
