Question about Garden
Hi, I am in the US.I have 3 yardwork mower 625,how can I acquire the grass bag?
  • 246 Answers
SOURCE: very little grass is shooting into the bag to fill it
Hello monica_skinn:
If the Underside of the Deck is Clean and the Blades are Tightened Properly, then the Problem is Caused by the Blade Lifts being Worn or the Blades are Not a High Lift (Bagger Blade) Blades.
A Bagger Blade has a Very High Lift Ear on the Backside of the Blade Across from the Cutting Edge. This Extra Lift is What Gives the Extra Lift and Throw (by increasing air Flow under the Mower) the Grass gets to be Bagged.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
  • 246 Answers
SOURCE: Grass clippings won't go into bag
Hello steveacosta:
Check the Blade. If the Lift Area Behind the Sharpened Area of the Blade is Worn, then you will have the Problem you Described.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Good Luck
Respectfully
jbridger (John)
Posted on May 16, 2009
  • 63 Answers
SOURCE: I have a new Poulan Pro Self-Propelled Lawn Mower
Yes
Posted on Jul 24, 2010
rycgl
  • 1545 Answers
SOURCE: replacement grass catch bag for
It appears that you will need to contact the service center as in your parts diagram, the bag is not listed. A mulching blade is listed, which doesn't require the use of a bag.
http://servicenet.blackanddecker.com/Products/Detail?isId=true&productNumber=MM600&selectedType=4882
Posted on May 07, 2011
  • 3 Answers
SOURCE: I need the owners manual for a Craftsman 625
horse power not star
Posted on Jul 10, 2011
This is driving me crazy but when cutting and using the grass bag; the grass blows out between the bag and the rear deflector and hardly any grass goes in the bag. The lawn mower is brand new
It sounds like the bag is not installed properly. Or mower not put together properly. If its brand new I would take it back to where I purchased it and ask some questions.
Sep 07, 2015 | Garden
Need to replace one bag on a 3-bag grass catcher. Where can I find one
dealer can order one any lawn mower dealer will order it take serial number off frame make of mower and order it
Aug 31, 2014 | Garden
Why do the clippings remain on lawn and don't enter bag?
Blades cut the grass and blow air like a fan. The clippings should flow along with the air out into the yard or into the bag. That only works if the bag acts like a filter and catches the clippings but lets the air out to be replaced by more air and more clippings until the bag is full of clippings.
The most likely problem is that your bag does not let the air out. Cutting wet grass will coat the inside like green paint. When dry, it's like the underside of your mower.
Check the inside. You might need to scrape and/or flush from the outside in. Can yours be turned inside out"? That would be the best case.
When clean and dry, it should work.
Didn't mention the easiest fix: to take out the hand-ful of clipping blocking the path to the bad: since you already checked that.
My 21: self propelled yardworks lawnmower leaves a strip of grass about one thiird from the left hand side of the mower when i mulch with it. When I bag it works good.
I'd check your blade and see if it needs sharpening. The mulching mowers need to cut then vacuum the grass up and then cut it again. They must be properly sharpened for this process to work properly.
James
Aug 26, 2011 | Garden
Cannot find drain to change oil.
Poulon 550 yellow 22" Briggs and Stratton. It looks like you have to drain it out the cap by tipping it. There IS no plug on mine - spent 40 minutes looking for one, and I know what both types of the plug look like. What a lousy design. This mower is a piece of junk. The valve froze a week after I got it. Never again. A headache.
Dec 13, 2010 | Poulan Pro PR550N22SH 22Inch Briggs ...
When cutting grass mower motor will bog down and die
THE engine has done a lot of work and the compression is down ,,,,starts ok but hasent got the go in it to cut the grass so either rebuild engine or get a new one.
But first check the govenor rod that runs from the carby yo the flywheel as it might be uncliped.
Oct 03, 2009 | Garden
Tractor mower failing to collect grass
ok i need to know what kind of collection sys. you have.if there is an electric blower type system it may be that the blower isn't working. if the system works by the blade blowing the grass up the chute then you may want to check the blades to see if the up turned tabs on the back of the blades are still there and not broken off. also if your mowing too fast the chute gets clogged and the grass just balls up onder the deck ubtil rolled out.if a blower type set up check to see if there is a fuse to the blower motor.
Apr 22, 2008 | Karcher 2500 PSI Pressure Washer
Garden Logo
16 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
