Question about Ovens
Have an F53 error come up on my oven. What does it mean?
    Genius:
  • 1,031 Answers
What is the make & model?
Posted on May 17, 2017
Testimonial: "Ariston os89cix"
  • Kevin Getz
    Kevin Getz May 31, 2017
    It sounds as though it's a problem with the door latch. You will need a qualified repairman, as these are tricky for the "home mechanic" to do on their own.
What does E2 -F 1- mean?
It helps to know make and model in such questions.
Whirlpool Oven...what does E2 F1 mean on the clock/control panel ...
https://www.shopyourway.com/questions/1183452
Aug 27, 2012 - The "E1 F1" fault code indicates an Electronic control board malfunction. This means that the control board will need to replaced. I'm not able to provide a part number because there was not a model number submitted.I added an image of from the technical data sheet in reference to the "E1-F1" fault code. Whirlpool Gold Oven Error Code F1 E2
25 Jun 2013
Whirlpool Oven (GBS307PDQ0) Fault Code E3 (amber ...
17 Sep 2012
What does error code F1 mean on my Whirlpool ...
1 answer
14 May 2010
What does E2 F1 mean on a Kenmore electric range ...
1 answer
25 Mar 2009
More results from www.shopyourway.com
Whirlpool Oven...what does E2 F1 mean on the ... - Shop Your Way
https://www.shopyourway.com/m/questions/1183452 Aug 28, 2012 - Control panel for Whirlpool Gold double oven. 2 answers. whirlpool range, clock/oven control goes into alarm. 4 answers. Whirlpool Gold Oven Error Code F1 E2.
Whirlpool Gold Oven Error Code F1 E2 ' Shop Your Way: Online ...
https://www.shopyourway.com/m/questions/1218462 The F1 E2 error code indicates an oven control failure. Try disconnecting power to the range for 20-30 minutes, then restore the power. If this does not help, I suspect that the oven control will need to be replaced.
Whirlpool Appliance Fault Codes ' PartSelect.com
https://www.partselect.com/JustForFun/Whirlpool-Appliance-Fault-Codes.aspx Whirpool Oven/Range/Stove Fault Codes (Including 2 and 4 digit codes). Note: Depending upon the brand of appliance, there can be many different names for the 'clock' component. Electronic Range Control, ERC, Electronic Oven Control, EOC, control board, and clock all refer to the same part. 4 Digit Fault Codes. F1-E0 ...
Mar 24, 2018 | Whirlpool Ovens
Door latch stuck
This error means your temperature sensor (probe) has failed and needs to be replaced.
Nov 05, 2014 | Whirlpool GMC305PD Electric Single Oven
Ariston wall oven error code f53 f03
I managed to resolve that problem. When you have BOTH F53 and F03 error codes, it's not a sensor fault (although F03 is the big cavity sensor and F53 is the top one)... it's a faulty capacitor trouble. On the main board there are 4 electrolytic capacitors, just replace all of them and you're ok again. It's quite simple and very cheap. :-)
Nov 26, 2013 | Ariston Technologies Ovens
Crosley oven dont work f 10 gas
The "F10" oven error code means "Runaway temperature"
try this link http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/70424-what-does-f10-error-code-mean.html#ixzz2VTV50IJ4
Jun 06, 2013 | Ovens
I have a kenmore elite oven what does an error code F-3 mean
Th eF3 error code means that their is a problem with the tempature sensor...this tip i wrote expalins what the F3 error code means.
http://www1.fixya.com/support/r10343697-error_codes_f3_f4_mean_oven
GENE
Oct 03, 2011 | Kenmore Ovens
When I turn the GE oven on sometimes it works fine other times it will shut off. When it shuts off it will give the F2 or F3 error sign.Can you please tell me what this means? Thanks
Hi, the F2 Error code means the oven has detected an excess temperature condition. Most often this is due to a bad temperature sensor - the sensor costs about $75 from an online repair site.
The "F3" error code means the oven sensor is open, I suggest you flip breaker off then back, on Re check for error, if OK fine if not turn back off and fix or call for service man...
Oct 06, 2010 | Ovens
Oven door wont open code f53 thermador how can i get it open food is in it
Hello,.
Welcome to FixYa.
The "F53" error code on your Thermador "C" series ovens indicates a upper door lock fault, makes sense since that is the issue you described.
Whether there is actually a fault with the lock remains to be seen. Here is what I`d suggest you try...
Locate the service panel for your oven ( should be an isolated 40amp breaker ) and turn it off for a few moments and turn it back on.
This will initiate the start-up sequence which activates and checks the controls and lock assembly, hopefully resetting it to the "open" position and subsequently eliminating the error code.
Let me know how that works or if you require further assistance.
Thanks for choosing FixYa and good luck.
Regards,
Macmarkus :)
Sep 29, 2010 | Thermador C302U Electric Double Oven
I have an AEG Electrolux oven D8800-4 double oven and have ann error code A3, what does this mean?
I hope you mean error code F3. if so then that means a software error and if you disconnect from mains supply then reconnect this should reset the fault if that does not work you may have a damaged circuit board.
Hope I helped.
May 06, 2010 | Electrolux Ovens
Door is locked- F53 Error
OK...you need to replace the lock, but first you need to get the darn think open. I looked at it, couldn't figure out how, and left it. My 14 yr old starting looking at it (after the kids had their TV, Ipod, etc taken away from him for the weekend.....) and he took a coat hanger from the side to pull the latch open.
The rest is straightforward sheet metal disassembly except for the front panel...label the connectors with a piece of tape before you pull the cables connecting the front panel (unless you are able to read a schematic). You can buy the part from AppliancePartsPros.com
AP2836100 (486324) Latch, door (microwave)
for about $100....next day delivery, and your ready to cook your Christmas goose!
Aug 22, 2007 | Thermador C302U Electric Double Oven
Ovens Logo
105 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
