Question about The Computers & Internet
Why the S2700 switch cannot transparently transmit the packets whose VLANID is greater than 127 after VLAN translation is enabled?
2 Suggested Answers
jorna
  • 85 Answers
SOURCE: Why the Huawei S2700 switch cannot transparently transmit the packets whose VLANID is greater than 127 after VLAN translation is enabled?
Take the Huawei S2700-9TP-SI-AC for example:
After the VLAN translation function is enabled for the Huawei S2700 switch, the 128 module problem exists because the chip difference supports only 128 VLAN TO VLAN entries.
The packets received through the port are processed as the VLAN smaller than 128. The calculation method is (vlanid)%128.
Therefore, for a VLAN greater than 128, port vlan-mapping vlan id map-vlan id, that is, the mapping from the VLAN to the same VLAN, must be configured for the transparent transmission to be implemented.
More related:
Huawei S2700-9TP-EI-AC
Huawei S2700-9TP-EI-DC
Huawei S2700-9TP-PWR-EI
Posted on May 11, 2017
Is Huawei S2700-18TP-SI-AC Layer 3 switch? Can Huawei S2700 Switch Function as a Gateway?
Huawei S2700-18TP-SI-ACis Layer 2 switch, Huawei S2700 series Switch cannot be used as a gateway.If it is used as a gateway, it sends all packets that need to be forwarded at Layer 3 to the CPU to forward the packets through software. This causes a high CPU usage. Because CAR parameters are configured to protect the CPU, a large number of packets are dropped, affecting forwarding of service packets.
Mar 22, 2018 | Huawei Computers & Internet
Can anybody know why the S2700 switch cannot transparently transmit the packets whose VLANID is greater than 127 after VLAN translation is enabled?
After the VLAN translation function is enabled for the S2700 switch, the 128 module problem exists because the chip difference supports only 128 VLAN TO VLAN entries.
Hope my answer can help you!
Dec 11, 2017 | The Computers & Internet
More related:
May 11, 2017 | Huawei Computers & Internet
DHCP Users Go Online Through the S2700, But Cannot Access the Internet. Why?
When a large number of DHCP users go online through the S2700, the S2700 generates a large number of dynamic DHCP snooping binding entries. On the S2700 V1R6C00SPC800, the software provides incorrect priority settings for DHCP snooping binding entries and IP source guard and DAI ACL rules, and the ACL rules have a higher priority than DHCP snooping binding entries. As a result, the software delivers the ACL rules but not DHCP snooping binding entries. User packets cannot be forwarded because no binding entry is available.
Solution: Install S2700SPH006, enable DHCP users to go online again, and reconfigure IP source guard and DAI on the physical interface from which DHCP users go online.
S2700 Switch Thunder link com
Nov 04, 2016 | Computers & Internet
What Are the Differences in AP-side Switch Interface Configuration and Intermediate Switch Configuration in Direct and Tunnel Forwarding Modes?
Differences in configuration on switch interfaces connected to APs are as follows:
In tunnel forwarding mode, interfaces connected to APs transparently transmit only packets of the management VLAN. These interfaces must be added to the management VLAN in untagged mode. In direct forwarding mode, interfaces connected to APs must be trunk or hybrid interfaces. These interfaces must be added to the management VLAN in untagged mode and added to service VLANs in tagged mode. If a trunk interface is connected to an AP, the PVID of the interface must be set to the management VLAN ID.
Differences in configuration on intermediate switches are as follows:
In tunnel forwarding mode, intermediate switches transparently transmit only packets of the management VLAN. In direct forwarding mode, intermediate switches transparently transmit packets of both the management VLAN and service VLANs.
S5700 Switch Thunder link com
Oct 17, 2016 | The Office Equipment & Supplies
Can the S2700 Switch Function as a Gateway?
The S2700 switch cannot be used as a gateway. The S2700 is a Layer 2 switch. If it is used as a gateway, it sends all packets that need to be forwarded at Layer 3 to the CPU to forward the packets through software. This causes a high CPU usage. Because CAR parameters are configured to protect the CPU, a large number of packets are dropped, affecting forwarding of service packets.
Aug 08, 2016 | Computers & Internet
How to Enable a Switch to Transparently Transmit BPDUs That Are Discarded by Default?
You can enable a switch to transparently transmit BPDUs in the following modes:
1. Run the bpdu bridge enable command to enable the port bridge function. Then the switch can transparently transmit all BPDUs.
2. Globally specify the group MAC address of BPDU for the inbound and outbound ports of two edge switches on the network, and enable the L2PT transparent transmission function of the protocol for the ports.
Incoming BPDUs are replaced with the group MAC address, converted to data packets, and forwarded in the VLAN. Configure the L2PT function in the outbound port to replace the group MAC address with the BPDU MAC address.
Jul 11, 2016 | Computers & Internet
How to stop user privately setting up a static IP address?
Huawei S2300/3300/5300 series switch although no H3C switches am user-bind command, but through the DHCP Snooping function can also be realized IP+MAC+ port binding to prevent users set up a static IP address. For example, if the request port Ethernet0/0/1 in addition to the static IP address for the 1.1.1.2, MAC address for the 001c-2309-9aa7 corresponding to the user, all other static IP users can not access the internet. Configuration is as follows:
Configure the device DHCP Snooping
# enable the global DHCP Snooping function.
[Quidway] DHCP snooping enable
# configure user side interface of VLAN.
[Quidway] VLAN 100
[Quidway-vlan100] quit
[Quidway] interface Ethernet 0/0/1
[Quidway-Ethernet0/0/1] port default VLAN 100
[Quidway-Ethernet0/0/1] quit
# enable VLAN DHCP Snooping function.
[Quidway] VLAN 100
[Quidway-vlan100] DHCP snooping enable
# configuration interface for packet inspection at the user side
[Quidway-Ethernet0/0/1] DHCP snooping check ARP enable
[Quidway-Ethernet0/0/1] DHCP snooping check IP enable
# configuration static binding table entry
[Quidway] VLAN 100
[Quidway-vlan100] DHCP snooping bind-table static IP-address 1.1.1.2 mac-address 001c-2309-9aa7 interface Ethernet 0/0/1
Aug 06, 2015 | Huawei Boxed Ls-s2318tp-ei-ac Quidway...
Cisco asa 5500 - sh interface - reveals switch ingress policy drops - what are these ? will they slow down traffic ?
The following is an excerpt from cisco.com defining policy drops and their possible causes:
This drop is usually seen when a port is not configured correctly. This drop is incremented when a packet cannot be successfully forwarded within switch ports as a result of the default or user configured switch port settings. The following configurations are the likely reasons for this drop:
blank.gifThe nameif command was not configured on the VLAN interface.
Note blank.gifFor interfaces in the same VLAN, even if the nameif command was not configured, switching within the VLAN is successful, and this counter does not increment.
blank.gifThe VLAN is shut down.
blank.gifAn access port received an 802.1Q-tagged packet.
blank.gifA trunk port received a tag that is not allowed or an untagged packet.
blank.gifThe security appliance is connected to another Cisco device that has Ethernet keepalives. For example, Cisco IOS software uses Ethernet loopback packets to ensure interface health. This packet is not intended to be received by any other device; the health is ensured just by being able to send the packet. These types of packets are dropped at the switch port, and the counter increments.
blank.gifThe VLAN only has one physical interface, but the DEST of the packet does not match the MAC address of the VLAN, and it is not the broadcast address
Throubleshoot these and see if any of them apply to you. Thank you for choosing fixya.com.
Dec 04, 2010 | Cisco (ASA-SSM-AIP-20-K9=) Firewall
Computers & Internet Logo
15 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
