Question about Skagen Watches
I want the Skagen watch repair Center in Dallas, Texas telephone number
Noggin
  • 944 Answers
SOURCE: Skagen 433LSLB Watch Battery
If you take the watch to any jeweller they will be able to identify the battery type required - also they should be able to replace the seals, which are always worth replacing when a battery goes. Here is the link for contact with Skagen if you need it; http://www.skagen.com/service.asp Hope this helps :)
Posted on Mar 25, 2007
SOURCE: cracked glass (plastic) in SKAGEN 170LTTM
Found a skagen watch repairer in Melbourne , thank you
Posted on Dec 29, 2008
escapement
  • 2334 Answers
SOURCE: How to adjust Skagen watch band.
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Jan 10, 2009
dmbgo
  • 58 Answers
SOURCE: skagen watch glasses keep cracking
Yes I would speak to Skagen in stron terms, this should not happen and wa probably aused by the glass being stressed when fitting it
Posted on Jun 22, 2009
  • 103 Answers
SOURCE: replacement battery for Skagen 430SSXD watch
send your watch into skagen since you have a lifetime warranty you do not want to breech that. plus they reseal your watch and other watch repair places cant.
http://www.skagen.com/service/home.fx
Posted on Aug 04, 2010
The glass of my skagen watch has come out. suggest me service center in hyderabad, india
I doubt there is a specific one. Try their web site or take it to a watch repairer.
Oct 12, 2017 | Skagen Watches
Replacement battery for Skagen 430SSXD watch
Mar 13, 2010 | Skagen 430SSXD Wrist Watch
I want skagen watch service center address in Hyderabad India
The glass of my Skagen watch has cracked and i want to get it replaced, so looking for a srevice center near Chandigarh, India.
Mar 03, 2010 | Skagen 355LGSC Wrist Watch
Can not get a crown for skagen 237sgg model. any ideas?
call skagen they have a great customer service department. and they repair all of there own watches. since they have lifetime warrantees you want everything to be done by them anyways.
Oct 03, 2009 | Skagen 237SGG Wrist Watch
Skagen watch glasses keep cracking
Jun 18, 2009 | Skagen 170LTTM Wrist Watch
Cracked glass (plastic) in SKAGEN 170LTTM
Dec 28, 2008 | Skagen 170LTTM Wrist Watch
Crack face glass
good after noon ! if you want to repair your watch can you bring here in my own watch center ,the exact address is ,MEDRANO WATCH and CELLPHONE CENTER located at b.laqui st.brgy.3 cuenca batangas philippines,thank you ! GOD BLESS !
Aug 28, 2008 | Skagen 105LTMXB Wrist Watch
Watches Logo
Top Skagen Watches Experts
Jerry Greenberg
Jerry Greenberg
Gary Nitowski
Are you a Skagen Watch Expert? Answer questions, earn points and help others
