Question about Water Garden
Can I use my irrigation system 1 hour a week instead of using water cans?
  • 16 Answers
SOURCE: pump runs continuously with not water
replace the pressure guage.
prime the pump by pouring in water in the impeller basket area and replace lid-try running pump again
Posted on Aug 23, 2009
  • 40 Answers
SOURCE: I have a 1/2 hp pump which I use to pump lake
when using the spicket you use less flow than your irrigation system so a delay in the pump coming on is normal...otherwise if you are having the same problem when the irrigation is running..a pressure switch adjustment may be necessary...please follow the manufacturer instructions for your pressure switch.
Posted on Feb 18, 2010
SOURCE: Instructions for garden watering system Hardie Irrigation
Posted on Mar 08, 2010
  • 299 Answers
SOURCE: I have an Irritrol Irrigation system (RainDial PLUS)
With the water turned on you may be able to hear or feel the water running through the bad valve. If not, you can turn each one on and off by hand by either turning the solenoid or the bleeder valve figure out which one it's not. Once you find the culprit you can see if it needs a new solenoid or open it up to clear out any sediment or debris that's keeping it from closing.
Posted on Apr 20, 2010
  • 927 Answers
SOURCE: Can you use a draper
Here's how to tell.
Connect a tee to the outlet of the pump.
Install a pressure gauge in the tee.
Install a valve after the gauge.
Open the valve and start the pump.
Once water flows, close the valve slowly until you get 50 psi on the gauge.
Have a 5 gallon bucket nearby and measure how long it takes to fill the bucket at 50 psi.
If it fills the bucket in 30 seconds, you can attach heads to the pump that combined consume 10 gallons per minute.
Let me know how you do.
Posted on May 29, 2011
What are the benefits of using rain water harvesting?
There are many benefits of rainwater harvesting, and some of them are listed below:
1. The rainwater can be used for irrigation.
2.Reduces water bills.
3. After filtering can be used for drinking.
4. Increases ground water level.
5. Easy maintenance.
There are lot more advantages for which you can refer Regenwassertonne.
Mar 17, 2017 | The Kitchen Appliances - Others
Drip it don't drop it
The popularity of Drip Irrigation Systems has been rising in the past years. It is true that this method of irrigation is usually a bit more expensive than sprinklers and isn't as resistant on the long run, but on the other hand the water saving and the system's efficiency definitely make it worth it. So why not giving it a try?
First of all, this system waters plants and flowers more slowly and the water goes straight to the roots, so no water goes to waste.
Moreover, it requires to be activated with less frequency than sprinklers.
In most countries it's one day of irrigation every week during the winter, two days during spring and fall and three during the summer.
Did you get one yet?
If you did here are two basic suggestions to start and keep up a satisfying drip irrigation system.
1. In order to figure out how long to leave it running, you can measure how much water your emitter produces and according to that and your plant's needs, set the system's timer.
So take a spoon and measure how many seconds the system takes to fill it up.
14 seconds = 1 gph (gallon per hour)
7 seconds = 2 gph
4 seconds = 4 gph
If your system is of the first kind, producing 1gph, usually you should leave it running for about 90 minutes, if it's the second (2gph) for about 60 minutes and if the third (4gph) for about 30 minutes.
(If your plants require a higher-flow emitter you can get one that produces up to 20 gph and leave it for about 12 minutes each watering.)
2. In order to keep your drip irrigation system in good shape check its line periodically for breaks, or its emitters for clogs.
Make sure that each emitter releases the right amount of water.
Also you should flush the drip irrigation lines and filters about twice each year. You can do this by uncapping the end cap on the drip line and letting water flush through the line.
on Sep 10, 2013 | Garden
Haste to stop waste!
Too often we let our irrigation systems go on without really making sure that the amount of water, the pressure, the radius and other settings are what our lawn or landscape needs.
This causes not only a great waste of water and money but it may also ruin our flowers and plants.
Therefore here are a few tips to transform a wasteful sprinkler irrigation into the effective system it should be, and to keep a healthy landscape, lawn or garden.
1. When to water.
Watering your lawn and landscape should be differentiated according to seasons.
During warm months (May to October) irrigation should be activated between midnight and sunrise, so to minimize the water that evaporates.
While during winter, plants and lawns should be watered during the warmer part of the day to prevent water from freezing on the landscape.
2. Don't drown your plants.
Keep an eye on your lawn while the sprinklers are on and monitor when the water starts dripping off the sides. This way you will know how long your sprinklers should be left active for, so that the plants may absorb the water without being overwhelmed.
3. Avoid daily, light watering.
4. When watering plants with deep roots, water well and deep, until about half inch deeper than the deepest roots, in order to encourage downward growth.
5. When watering on a slope do it gradually. Run your sprinklers every 3 hours circa and aerate to increase infiltration.
6. Check your sprinkler's efficiency once a month.
Check for damaged, leaking, clogged or stuck sprinkler heads and for constantly soaked patches of grass or soil to detect leakage.
Make sure that the water is sprayed all over the area and that new additions or plants that grew higher and larger don't block the spray pattern.
7. In seasons in which the temperature reaches 30/32 degrees Celsius remember to run your sprinklers 5 to 10 minutes in the afternoon to cool the area. It reduces the symptoms of summer patch disease.
8. Create water zones by putting together the plants that have similar water needs, and water them accordingly
9. Be careful when mowing. If your sprinkle heads don't retract underground after irrigation, apply small flags on them so that while mowing you see them better and avoid damaging them.
on Sep 09, 2013 | Garden
What is a Drip Irrigation System?
According to Wikipedia "Drip irrigation, also known as trickle irrigation or micro irrigation or localized irrigation, is an irrigation method that saves water and fertilizer by allowing water to drip slowly to the roots of plants, either onto the soil surface or directly onto the root zone, through a network of valves, pipes, tubing, and emitters. It is done through narrow tubes that deliver water directly to the base of the plant."
What is the average emitter flow rate for a normal garden?
emitters can put out between 0.16 up to 4 gallons of water per hour. it depends on how much water you want, how much water pressure there is, and if the emitter is pressure compensating
Jan 28, 2013 | Garden
I have a 1/2 hp pump which I use to pump lake water to my irrigation system. The pump takes too long to turn on when the spicket is opened and sometimes too long to shut off when the water spicket is...
Mar 31, 2009 | Flotec 1 - 1/2 Sprinkler Pump Composite...
Garden Logo
20 people viewed this question
Top Water Garden Experts
Vernon Taylor
Are you a Water Garden Expert? Answer questions, earn points and help others
