My adsl wifi is'nt working - Computers & Internet
Por que me corta el wifi en ps3 super slim 500gb y cell y tablet por cortos tiempos
Conexi?n ADSL con filtros de ADSL. ┬┐Ocurre si alguien llama a la l?nea telef?nica? Podr?a ser defectuoso filtro ADSL cayendo conexi?n a internet.
DSL connection with ADSL Filters. Does it occur if someone rings into phone line ? Could be faulty ADSL Filter dropping connection to internet .
Jul 17, 2014 | NetGear R6300 WiFi Router
Bsnl broadband modem
Indian Telecom gaint Bharat Sanchar Nigam Limited (BSNL) has introduced 4 types of ADSL Broadband Modems(ADSL Basic Modem(CPE), ADSL WiFi Modem, ADSL WiFi-TA Modem & VDSL WiFi Modem) with Ethernet, Wi-Fi , USB, and Terminal Adapter port.
Which version have you got?
Feb 10, 2014 | Acer Computers & Internet
Internet light on router diplayed red
The ADSL installation details have changed, so you need to update the router.
Check the router has not been moved too far from the laptop.
Jan 27, 2014 | NetGear DG834G Router
Cruz reader r101 will not load web pages
Is your ADSL correctly set up for WIFI?
Have you got the encryption (WEP?) key to enter into the T101? Your ADSL will not connect unless the identical key stored in your ADSL parameter set are correctly entered from the 'keyboard' on the T101.
If you go into T101 Wi-Fi settings, you will see a list of networks, one of those should be yours, just connect to it.
Hope that is of some help, or just a pointer in the direction you want to go. -Good luck!!
Feb 11, 2013 | Velocity Micro Cruz Reader R101 Tablet PC
I have a laptop OS win7. I hav internet over LAN port. My laptop has wifi. How can i share my internet with laptop wifi. i hav a mobile which has wifi. My question is how can i share my internet through...
It sounds to me like you only have a cable/adsl modem bringing in your internet connection. To share your internet with other wifi devices you will need to buy a Wireless router. Be aware you can buy adsl and cable routers depending on what your broadband provider has given you. Take these details into a computer shop who will advise you of the right type of router to buy. Dont buy cheap, go for something like a netgear router.
May 30, 2011 | ASUS Eee Atom Z520 Netbook
Dear Sir, I m nt abl 2 dwnload video youtube in wave 533 pl.tell the procdre hw 2 slv the prblm Rgds SK Rawat
First of all you must be on the internet via your service provider or your WiFi capabilities through a land line/WiFi ADSL modem where you can then connect to you tube where you will automatically see movies on your phone.Hope this helps you.
Mar 18, 2011 | Samsung Wave S8500 Smartphone
I have moved to new home. I am using 2wire wifi
you can check if the ethercable is loose or if you have a spare ethernet cable (rj45) you can replace the one that youre using
Jul 14, 2010 | 2wire Wireless-G 802.11g ADSL Gateway
Have ADSL Modem and Wireless Router, i connect with UTP cable so dont have internet in my wireless router... I connect my laptop to modem directly and have internet... Whats wrong...??
the wireless router is not properly configured... configure ur adsl and disable dhcp server in the same. and then disconnect it ... then configure ur wifi router with a static internet address that is from the adsl range . put the default gateway as the adsl and save it, connect the adsl to wifi and switch both of them on... ur done... but make sure if ur adsl address is 192.168.1.1 the ur wifi address is 192.168.10.1
Jan 10, 2010 | Cnet CWR-854 Router
Wifi drivers problem
first check in your bios if the internal wifi card is enabled.
if it was not then your problem should be fixed by enabling it.
if it was enabled then try :
go to the compaq/hp website go to support and get the wifi driver for your model c700.
and reinstall the driver.
if this doesnt help pls add more info like what is not working is the wifi driver installed does the wifi card show up in the hardware propertys etc any info can help.
good luck
Feb 07, 2009 | Compaq Presario Notebook
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
