Question about Beam Industries 2775 Serenity Plus Central System Vacuum
Cannot shut vacuum on hose
Cannot operate vacuum on and off from hose switch
  • 1,673 Answers
Will the main unit operate if you switch to manual operation. If so, then it could be that the PC board has a stuck relay and you will have to replace the PC Board. Could be the switch inside the handle. You take your hose to your local dealer and or someone that you know that has a beam system and plug it in and see if it works or not. If it does, then it is in the main unit, if it doesn't. then there is a problem with the hose or switch asm.
Posted on Jan 09, 2008
Vacuum cleaner Motors plural shut off during operation.
Probably not. Both motors usually wont stop working at the same time. You have given us very little information. Model number? Brand?
May 10, 2015 | Vacuums
Vacuum spits dirt out of the back end as I'm vacuuming.
Heather,Does the vacuum have a switch or a lever somewhere that makes it change from floor to hose? If so, it sounds like you've been using it on the hose selection but not actually sweeping using the hose. In other words, on an upright vacuum when sweeping just with the vacuum normally have the lever on floor setting and if you use the hose/attachments you have to have the lever on hose setting for things to work correctly. Hope this helps!
Mar 28, 2013 | Vacuums
I have Kirby sentria that shuts off while using the rug attachment and won't start until I change to the hose attachment. I have had it in Kirby repair store 5 times, cord replaced. Took it back t
power switch faulty, slow speed terminal inside switch is burnt,hence
intermittent fault, hose uses second speed different lever inside switch
Oct 12, 2012 | Kirby Vacuums
Vacumm just shut off
It could be that you sucked up a piece of paper or plastic which got stuck in the hose and the vacuum just shut off due to over burn protection.
Check the hose if it is stuck. You can drop a penny and see if it glides and comes from the other end
Most good vacuums these days come with a tiny reset switch. Just press it with a pointed needle or pen tip. It your vacuum shut off due to protection feature, it should come back to life.
May 20, 2012 | Dirt Devil Vision Turbo W/Bonus Upright...
Kirby G5 shuts off by itself
this could be a couple of things, first I am suspecting it may be the cord. goes for so long and shuts off, possible break in the cord. Usually the machine will have normal operation at this point.
Overheating or unusual warmness coming from the machine itself, could be a possible motor problem. Usually a burning smell is associated with this.
Thirdly, perhaps the "deadman" switches are not covered properly. this could be as simple as the bag container where it joins to the machine has come loose or dislodged enough to shut the machine down. There is also another deadman switch located on the brush housing and the attachment hose. If those have been switched recently try re-switching it back off and on again to see if that corrects the problem.
Good luck!!
Jan 24, 2012 | Kirby G5 Bagged Upright Vacuum
Vacuum cleaner power loss
Generic problem for all Vacuums
Posted by fudpucker on Apr 25, 2008
Vacuum loses power while operating. Just shuts down and will not restart by toggling switch. After a brief (cool down?) period it will start.
Is there a breaker/reset? Does it have a feature that automatically shuts it down when the bag is full?
I can't locate my owner's manual, so am completely in the dark or dirt.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Depending on the Brand name and Model # there is what they call Thermal Switches on some of the vacuums that prevent the motor from over heating and possible burn out of the motor If the hose is clogged, the bag is full or the filter is dirty and the air does not flow threw the filter. Any one of the three situations could cause the vac to say “cut out” and stop the motor. So check with your local vac dealer.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 25, 2008 | Vacuums
Electrolux Canister - Stops working after 1-2 minutes.
Electrolux Canister - Stops working after 1-2...
Our vac works for a short time, then shuts off and makes clicking noise as if trying to restart again. Works after cooling for a while but for another very short time. Your suggestion on fix would be greatly appreciated.
I would advise that it could be a thermal switch or a regular switch that the thermal switch is over heating and needs replacement – there are small hoses in the door section that could have been pinched or kinked and it stopping the air flow from the vacuum – also check for a clogged or plugged vacuum hose, a full vacuum bag or a dirty vacuum filter. Check the thermal switch or reg switch or the hoses in the door. Or feel free to contact your local vacuum dealer in your area or in the yellow pages, or call the factory @ the phone number listed below: Customer Service
Electrolux Home Care Products – North America
PO Box 3900 Peoria, IL 61612
Don – The Vac Man
Apr 21, 2008 | Electrolux Guardian Bagged Canister Vacuum
Vacuum shuts off
if you want to fix this problem gently pry up the air flow control knob and look down at the plastic hose connected below the control valve. insert a small screwdriver and push off the hose from the valve. this disconnects the bag full indicator but will let the vacuum operate normally at full vacuum. you will change the bag when suction gets low. this will save you at least $100 repair bill.
Dec 31, 2007 | Electrolux Lux 5500 Canister Vacuum
Beam Industries 2775 Serenity Plus Central System Vacuum Logo
151 people viewed this question
Top Beam Industries Vacuums Experts
Level 1 Expert
Are you a Beam Industries Vacuum Expert? Answer questions, earn points and help others
