Question about iPad mini Tablets & eReaders
Wanted to transfer from an iPad mini two to an iPad 4
How do I delete books from the ipad mini
You can manage files on your iPad mini with this iTransfer tool. It also helps you add/remove files like books, movies, photos, etc.
Transfer Files among iOS Devices iTunes and PCs with Ease
Nov 03, 2015 | Targus CityGear Mini for Apple iPad 16GB...
Transfer photos from my PC to my ipad mini. I have tried iTunes but I don't understand it
Try downloading an app called Shareit.
When attached to the same WiFi, you can transfer Photos directly from iPad to iPad and even between Windows and Andriod devices. You start Shareit on both devices and send from one and receive on the other.
Feb 16, 2015 | Apple iPad Mini
Disabled ipad 3
What wrong with your iPad 3? Maybe you can reply on the tablet replacement repair parts for iPad 3 to make your iPad return back new and health. Nowdays, there are more repair parts for fixing the unflexible and scracked.
Oct 04, 2013 | Apple iPad 64 GB WiFi
How do I get my apps from my iPhone & iPad to my iPad mini
For apps you can:
If you only want some of your apps, just go to the app store, purchased and select the apps you want. You can download for free on the new device as long on the same iTunes acct.
For all apps, turn on app share under Settings, iTunes & App Stores, turn on Automatic Downloads for Apps. Turn this on, on both iOS devices you want to have the same set of apps on
For photos, turn on iCloud Photo Stream under, Settings, iCloud.
Jan 12, 2013 | Tablets & eReaders
Copy photos from PC to Ipad
Connect your iPad to your PC. Start iTunes. In the left column of iTunes on your PC you should see your iPad listsxed. Select your iPad. Look for photos in the bar at the top of the right column in iTunes on your PC.
For more detailed guide of transferring photos from PC to iPad, follow this tip "Copy files from Computer to iPad".
Jun 01, 2012 | Apple iPad2 WiFi 64GB
I want to transfer my pics from my computer to my I Pad but doing it by Email is slow, is there a better way?
Follow the steps to transfer pics from your computer to your iPad:
Step 1: Connect your iPad to your computer using the USB data cable that came with your iPad.
Download Install and run iTunes and select your iPad device from left panel under "Devices" section.
Step 2: Click on Photos tab, Check the "Sync Photos from" checkbox and select "Choose Folder..." option from drop-down menu. Locate the folder with the photos you want to transfer on your computer and hit "Select Folder" button.
Step 3: When folder listed in iTunes, select all pictures that you want to copy to your iPad and hit Sync/Apply button from bottom right corner.
Feb 17, 2011 | Apple iPad 64 GB 3G Tablet PC
Tablets & eReaders Logo
22 people viewed this question
Top iPad mini Tablets & eReaders Experts
NOEL
NOEL
Andrew Taylor
Andrew Taylor
Kolbrun...
Are you an iPad mini Tablet and eReader Expert? Answer questions, earn points and help others
