Question about Garden
Where can i buy nylon pullstart dogs that fit on the fly wheel of an talon ac3100 chainsaw?
    Top Expert:
  • Garden Master
  • 51,171 Answers
Try a lawn mower repair shop as the plastic dogs are generic and fit a range of small motors
Posted on May 17, 2017
How to order gas line for chainsaw blue max 45cc model 6595
MAN, you MAY be in luck!
Checkout THIS obscure link!!
Chinese Chainsaw Parts
#75339 D24
GREY MARKET CHINESE 52CC - 58CC CHAINSAW FUEL LINE 75339 D24 NEW
Molded rubber gas line - NEW - Fits many Off-Brand Chainsaws made in China 45cc, 52cc, 58cc, SL4500, SL5200, SL5800, SL 4500 5200 5800 Falcon Pro, Forester, Kraftech, King Saw, Silverline, Blue Max, Yard Dog, Gio, Raiden, Talon, Powerhorse and...
75339 D24 75339 D24
Hope this is it!
Anthony
Apr 15, 2018 | Garden
Need a new Talon Chainsaw sprocket for 35cc 35cm Timber Hawk AC3100-35C
most chain saw chain sprockets are either 1/4 or 3/8" pitch
in your case I would suspect it is 3/8 pitch
measure the distance between the link pins ( not the teeth but the pivot pins of the chain itself )
after that the sprocket will be available as a generic sprocket from any chain saw shop or mower shop
Talons went bust but are being reproduced under a new brand name ( ozito I think)
Jun 28, 2016 | Talon 219 Kart Sprocket 62 Tooth
Pullstart won't pull 2 levers are stoping it
Hi Neil:
Looks like a chainsaw!
- I'd start by removing the starter assembly and then trying to turn the flywheel by hand to make sure it's not seized.
- Then pull the start cord to make sure the starter assembly is functioning properly.
- Re- install and make sure the levers (engaging dogs) are in the right position.
Should be OK.
Jul 25, 2015 | Garden
Ryobi chainsaw rcs4640n pullstart slips frequently
sounds like the gears on the pullstart mechanism is starting to get stripped there generally not expensive a small engine parts store can get it for you
Jul 28, 2014 | Ryobi Garden
Gardentec fly wheel pully springs
They can be found on Ebay. I have bought many parts for Huskys and other brands there. If not, try Amazon.
Mar 17, 2012 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
Can you help me. My "trigger"
I was able to make my own by going to the local hardware store and buying 2 nylon parts and doing some careful milling/filling. The following dimensions were checked against an original EM14e trigger. These instructions may or may not work with other McCullough Chainsaws, but they worked for me!
1.) buy a nylon thumscrew with a 3.20mm (.125 in) outer diameter and 13.2mm (.5 in) THREADED length (overall length varies depending on type of flat head used for thumbscrew and overall total length will likely exceed 18mm or .75 in)
2.) a nylon spacer .25in length and .125in inner diameter that I cut in half and used a shop grinder to loosely fit onto a mounting nail. I used the shop grinder to gently mill down to 8.7mm outer diameter by slowly pressing the spacer/nail combo against the grinder wheel.
I then tested in the EM14E handle to check for fit and after several trips to the grinder for the spacer, it works great.
3.) After checking for fit I glued the thumscrew and spacer together and am now able to use the trigger. Please note if you have a working loose fit for the trigger, do what I have and simply use masking tape to keep the trigger with the chainsaw so it does not get lost.
Jan 15, 2011 | McCulloch 14" Electric Chain Saw Mcc1514
How do you get the fly wheel off of a 1979 165cc
A model number would have been helpful.
I suggest a length of nylon rope (nothing left behind) be used as a piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises
Some pry them off (breaks cases, may damage points on yours), some smack the crank with a hammer (your crank), Some try holding the fly wheel and break cooling fins that effect balance. Professionals use a puller (call a local saw shop they might do it for a small compensation). HTH
Lou
Feb 17, 2010 | Husqvarna Chain Saw 20" Bar
Where can i get a oil pump for a Mcc1635ak 35 cc
It is located behind the fly wheel. This is the only saw I have seen like this. I would check all hose connections and install the pump overhaul kit before attempting to change the oil pump on this saw. HTH
Lou
I suggest a length of nylon rope (nothing left behind) be used as a piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
Impact wrenches destroy bearings and seals prying on the fly wheel often breaks cooling fins and throws off the balance. A puller is what the professionals use for fly wheel removal.
Feb 13, 2010 | McCulloch Garden
I need to remove the fly wheel is it right or left hand thread? What is the best way to remove?
The fly wheel is right handed the clutch is left handed.
Please watch this it will help. It explains how to stop crankshaft rotation.
R² Drive Link Outboard Clutch
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. A length of starter cord or nylon rope may be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
Lou
Oct 03, 2009 | McCulloch Garden
Talon petrol chainsaw ac3100, bar lurication
Talon chain saw wont start, have spark, but fuel drips from exhaust when attempting to start, saw only used a couple of times any suggestions?
Sep 21, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
