How many hours will a 3kw geyser take to heat up to 70 degrees celsius
  • Heating & Co... Master
  • 3,087 Answers
You need to know how water you are heating up . There I a table for this google it . But you need all the formula two parts do not work .
Posted on May 17, 2017
I must calculate how many kilowatts per hour a 3kw 200 litre geyser will take to heat the water to 70 degrees celsious
go google and type in ---formula for heating water-- it will shows as so many btu or kilojoules to heat 1 liter of water 1 degree in one minute
May 17, 2017 | Heating & Cooling
Why cools the ac only 1 hour full power and never reaches the set-point temperature ?
check that all the doors and windows are closed as ac units do not work well when trying to cool the world
is the ac unit too small for the room size
I suspect that because it is working the problem is outside the ac control
is the inside fan working and blowing out cold air
May 22, 2016 | Heating & Cooling
How to convert Fahrenheit to Celsius
Put 70 in for F, and apply BEDMAS, the order of operations, brackets, exponents, division and multiplication, and finally addition and subtraction. In this case, we have to do the brackets first before the multiplication and division. The answer should be 21 degrees Celsius.
Feb 24, 2015 | Office Equipment & Supplies
Overheating torque & transmission
One thing to check out is the transmission cooler lines running to the radiator, they may be clogged.
Oct 11, 2014 | Cars & Trucks
Not sure the heat pump is producing enough heat
lower the fan speed to low and if you do not close your turns at 50 degrees Celsius then check the freon
Nov 04, 2011 | Heating & Cooling
Gateway MX6453 fan does not start until 70 degress celsius
This would be due to a faulty sensor if it does not reboot and overheat then leave it be and buy a cpu cooler that goes underneathe the unit there around 20 bucks.
Jun 14, 2009 | Gateway MX6453 Notebook
Reset Heating/ AIr cond temp display as well as EXT temp ????
the temp display can be switched between celsius and farenheit readings, since the car is from europe the default is celsius, The manual has instructions on changing back, You have to hold 2 buttons on the display per the manual.
May 07, 2009 | 2003 Land Rover Discovery
I have a comfort zone furnace. If it's 50 degrees in the house, and i set my thermostat to 70 or so,it takes at least 24 hours to reach 70 degrees. The furnace starts up and runs normally for about five...
When the thermostat calls for heat it should run until the room reaches the temperature setting then shut off. Is the blower motor running and can you feel air coming out of the vents? It sounds like the blower is either not running or putting out enough air to keep the furnace heating. The blower moves the heat from the heat exchanger to the room, if it can't remove enough heat from the heat exchanger there is a limit switch that will shut the burner off if it gets to hot and that's what it sounds like is happening.
Apr 25, 2009 | Heating & Cooling
Heating & Cooling Logo
24 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
