How to resolve Host machine check reset 501 error while using RUMBA
SOURCE: Checking virtual IP servers... [VIP Raw]
[VIP Raw] TIMEOUT
Checking HTTP virtual IP servers...
[VIP Http] TIMEOUT
Posted on Mar 25, 2010
  • 2855 Answers
1) Clear your browsers out
Download 'ccleaner' and use it daily. Run it through a couple of times,using the factory settings and the 'Run Cleaner' control until 0 bytes are seen to be cleaned following a scan
Run the 'Registry' from the left hand toolbar but 'Save' any changes after opting to 'repair' errors.Never make changes to your Registry without saving the information.
http://www.filehippo.com/download_ccleaner/
Open Internet Explorer (even if you use another browser as default) > Tools > Internet Options > Connections tab > LAN settings > Uncheck all the boxes and check "Automtically detect settings" > Save > Save
Posted on Aug 18, 2010
  • 707 Answers
clear your Cache and History from/through IE. Try re-opening http://www.yahoo.com on IE then try logging into Yahoo Messenger again.
either manually or try this free tool
http://www.piriform.com/ccleaner
download, install, run cleaner, and then registry options
hope it works for you
Posted on Nov 19, 2010
  • 4 Answers
por favor solucionen mi problema no me deja abrir mi msn dice que mi cuenta a sido bloqueada y que tengo que desbloquearla , ayudame por favor desbloqueela en codigo de desbloqueo es 81003003 ese codigo me dan para entrar ahi
Posted on Jan 15, 2011
OmelSoft
  • 187 Answers
Try this solution:
1. Open your Yahoo! Messenger
2. Click <Messenger> Menu and Select <Connection Preferences> and another window will open.
3. Under <Connection> choose <Connect directly to the Internet>
4. Click Apply and OK
5. Re-open YM.
Hope this may help.
Thanks & Regards,
(-_-)
Posted on Mar 24, 2011
Develop ineo 501, machine stopped, showing " have the fusing unit replaced soon, contact the service representative" -no error code. There is also "license management error occurs" but this promt was way...
that unit is manufactured my konica minolta. it is a Konica Minolta Bizhub 501 and will use the same fuser even though the image units, toners, and transfer belt have to be chipped for the ineo. There is a picofuse in the fusing harness that blows as soon as it is installed and that starts the fuser life counter. the counter is reset when a new fuser (or new fuse, if the fuser is still good) is installed. You will need to replace the fuser for the message to go away.
Jan 05, 2015 | Office Equipment & Supplies
Konica bizhub 501 take code c2806
actually code c28xx have 7 variant. for example, c2801, c2802, c2803 (error 3,4,5,6) and c2804. if follow the code code c28xx is TCR output abnormality.
ok, first you clean T/S block, do servicing and cleaning all parts.
second, if still same, do toner auto supply.
third, trouble reset. off your machine first, press and hold utility/counter and on machine, until trouble reset appear. press it and off/on again. ^^,
Oct 05, 2013 | Konica Minolta Bizhub 501 Copier
My konica minolita bizhub 501 is showing the error code C3501. How do I fix this?
if the code does come back DO NOT RESET the machine again! It is indicating a problem the code you are resetting is the fuser and it can catch on fire! That will ruin a perfectly good day!!!
ENSURE YOU WAIT 10 SECONDS
1.
Turn OFF the main power switch. (Located inside machine) Leave control power switch in the on position.)
2.Turn main power switch ON while pressing the Utility/Counter key.
3.Touch [Trouble Reset].
4.Check to make sure that [OK] is displayed and the it has been reset.
5.After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Oct 12, 2012 | Konica Minolta Bizhub 501 Copier
Can't sign into yahoo messenger.
marwan karm bekhet hesen mahamd
Apr 09, 2012 | Yahoo Messenger
Checking virtual IP servers... [VIP Raw] Resolving host name vcs1.msg.yahoo.com... [PASSED] [VIP Raw] Connecting to Virtual IP server 98.136.48.32... [FAILED] *** 'COMPONENT_TYPE_WININET' value:...
Aug 16, 2010 | Yahoo Messenger
HTTP 501 ERROR
To resolve this issue:
  1. In Internet Explorer, click Internet Options on the Tools menu.
  2. In the Internet Options dialog box, click the Advanced tab.
  3. Click to clear the HTTP 1.1 check box, and then click OK.
  4. Test to determine if the issue is resolved. If the issue is resolved, do not complete the remaining steps. If the issue is not resolved, go to the next step.
  5. In Internet Explorer, click Internet Options on the Tools menu.
  6. In the Internet Options dialog box, click the Advanced tab.
  7. Click to clear the Show friendly HTTP error messages check box.
  8. Try to view a Web page to reproduce the error message and to receive a new, more descriptive error message. This new error message may be similar to the following: HTTP version not supported by program name. Note the name of the program in this new error message.
  9. The program name that you noted in step 8 may be the cause of this issue. Either remove this program, or reinstall it.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Apr 28, 2010 | Computers & Internet
$ symbol not recognised in Mainframe Display
The $ is a special character that does not translate. If you use %24 it will translate to $ on the host.
Jan 15, 2009 | NetManage RUMBA OFFICE 7.4
53 people viewed this question
jasbo
jasbo
