Question about LG Televison & Video
How do i connect an LG soundbar to a sharp aquos lc-40lb700m so it works
SOURCE: LC-37D62U Sharp Aquos HDTV Settings
lost sound on Sharp Aquos 37LCD62U
Posted on Jan 25, 2008
SOURCE: Sharp Aquos LC 37HV4U - problems with AVC
I have a fully functioning lc37hv4u box & cable that I will sell for 200$ my lcd got cracked. let me know psxpirate25@hotmail.com
Posted on Aug 01, 2008
ginko
  • 19396 Answers
SOURCE: LC-37AF3X Sharp Aquos KCD TV
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
SOURCE: sharp remote control not working
Ok, looks like this TV works on MS Windows. Anyone who has had a computer 5 years back knows that when Windows has a problem, there is only one sure-shot solution.
SHUT IT DOWN, START IT UP !
Try this with your TV. Completely unplug it and leave for one minute. Start again. Voila ! Remote works flawlessly.
Posted on Sep 21, 2009
  • 73 Answers
SOURCE: Problem connecting my PS3 to my Sharp Aquos LC-C3237U LCD TV
Your PS3 set itself above the max resolution your LC-C3237U. Most likely the PS3 is doing 1080P, but the highest the Sharp can do is 1080i. So do this:
1. Connect PS3 to TV (you can use the current cable or analog cable)
2. Turn on TV and set input to port PS3 is on.
3. Make sure PS3 is connected via correct cable.
4. Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
Posted on Sep 27, 2009
I have a Sharp Aquos LC-60LE640X TV and I am trying to connect a Samsung HW-H751 Soundbar to it. I have hooked up the optical cable, adaptor and sub woofer, I have tested the Bluetooth function throug
If you are connecting the soundbar to your TV with the digital audio cable, make sure to select "D IN" using the source button on the soundbar. Bluetooth (BT) is a separate source from another device. (phone, etc.) The TV will need to be set to use the digital audio output and probably PCM format. (?) The subwoofer is preconfigured at the factory to mate up with your soundbar. (See below instructions - your soundbar includes the amplifier:)
Digital audio output setting:
After connecting an amplifier with digital audio input and
external speakers as shown, you should set an audio
output format compatible with the programme you are
watching or the device connected.
Go to "HOME" > "TV Menu" > "Setup" > "Option" >
"Terminal setting" > "Digital audio output" > select
"PCM" or "Bitstream".
NOTE
• When set to "Bitstream", Dolby Digital is output when the Dolby
Digital or Dolby Digital Plus audio formats are received. When
set to "PCM", PCM is output no matter what audio formats are
received.
• When set to "Bitstream", HE-AAC audio formats can be output
as Dolby Digital.
Jan 24, 2015 | Sharp Aquos Televison & Video
Can not get sound when connecting a samsung HW f355 soundbar to a sharp aquos 4k tv
There should not be any problem in connecting this TV to Sound Bar. Check all the connections. Contact any service technician to seek help in this matter. Refer the user manuals to both the sets.
Dec 02, 2014 | Samsung Televison & Video
Connect a Sharp TV to Sharp sound bar
Call a local custom audio/video installer that can help you for a small fee. It's okay to pay a professional and get the right help. It shouldn't cost you more than $50 at most, but probably half that amount since it's a very simple connection.
Here's a couple of weblinks that may be helpful...
http://hometheater.about.com/od/hometheaterglossary/g/Audio-Return-Channel-Arc.htm
http://www.sharpusa.com/ForHome/HomeEntertainment/SoundBar/Models/HTSB40.aspx
Dec 03, 2013 | Televison & Video
No sound on my sharp aquos lc-45gd4u 45 in
Assuming you are using the internal speakers, check and make sure you have the audio enabled. Some TV sets have a option to turn off the internal speakers. Also make sure mute isn't turned on. If you are using external audio setup, double check your connections.
Nov 24, 2012 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
Varous tv channels do not have sound. It is NOT a
TO: rdh041: I don't have the solution to you problem, but we have the exact same problem with our Sharp AQUOS 20" LC tv. Different model than yours, but same age and same perplexing issue. Several channels suddenly have no sound. If you've found a solution, would you please post it? I'll do the same. Thanks.
Jul 15, 2010 | Sharp Aquos LC-20B6U/LC-20B6E 20 in....
Connecting external speakers to Sharp LC-32SB23U
Invest in a sharp soundbar (about $175.00) matchs the cecor of the TV fits right at the bottom and looks like part of the TV and the sound is super.
Jan 04, 2009 | Sharp Televison & Video
Aquos lc-26ga5u to mac mini
Adjust resolution on your mac mini to something the TV supports. Usually 1080 vertical resolution or below
Nov 07, 2007 | Sharp Aquos LC-32D40U Television
Televison & Video Logo
21 people viewed this question
Computer Repairing
Computer Repairing
