Question about Fisher and Paykel Washing Machines
Where is the cheapest place to buy this Fisher and paykel circuit board and what do they call this part
    Habit-Forming:
    Scholar:
  • Fisher and P... Expert
  • 167 Answers
What is it off? What model number? Where in the world do you live? This is the internet and you could be anywhere. Not possible to give a proper answer with so little detail.
Posted on May 18, 2017
SOURCE: lint assembly-Fisher and Paykel DEGX1
Pretty easy on the lint assy;
Remove the lint cup;
Find screw (5) in a recess at the bottom of the lint cup area;
This will allow removal of the perforated lint surround, and the 'lint scraper'; Also will expose the moisture sensor (3) hanging off wires at the bottom of the assy;
At the bottom of the surround there is another recessed phillips screw; remove this, then twist the surround (14) counter-clockwise about 1/2" and remove to expose the filter (13).
<img src="http://img50.imageshack.us/img50/9130/outlectductsh4.jpg" alt="FP Dryer Lint parts"/><br/>
Not sure on the reset- I do know the top swivels up after removing the two screw caps and screws at the front of the unit on either side. This exposes the underside of the control panel; there are screws at the back of the control panel also.
Posted on Apr 24, 2008
RescueTech
  • 145 Answers
SOURCE: Top drawer no power
This looks like an old question, but for the sake of refference I will respond to it..
On your dd603, the heater plate in the bottom of the drawer acts as a dropping resistor in the power supply circuit. The main computer is often replaced incorrectly when the the machine is "dead". The correct procedure is to check the heater plate first and there are several resistance tests that are done at the connector for the heater plate. Usually the overload on the plate itself is blown out. This will cause a dead machine.
Some of the other experts object when we say "You should get a service manual" but that advice is warranted here.
You can get one here:
http://fisherpaykelparts.net/index.php?categoryid=115&productid=18
Posted on Dec 28, 2008
  • 212 Answers
SOURCE: the panel cover on my fisher & paykel nautilus is broken
Fisher and paykel is based out of australia. call the # in the manual to order part. they have a division in california. parts usually take me two to three weeks to recieve.
Posted on Jun 21, 2009
Geekman
  • 32281 Answers
SOURCE: Inverter E172FPB
Try LCD Parts use this link :-
www.lcdparts.net
Posted on Aug 31, 2009
  • 3741 Answers
SOURCE: fisher and paykel gw612 fault
click on this link directly to get the user manual of your product http://safemanuals.com/user-guide-instructions-owner-manual/FISHER%20%2526%20PAYKEL/GW612%20-_E in this link there is mentioned all types of troubleshooting and error code list. This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Posted on Dec 30, 2009
My Fisher & Paykel GWL11 top load wahser will only wash in cold after the first cycle. It
the problem other then the thermosat and solenoid valves is probably the main board. to check you need to replace the board with known good second hand board . buy an old machine for parts
Nov 19, 2011 | Fisher and Paykel GWL11 Top Load Washer
My fisher and paykel dryer will not even turn on
It sounds like the micro switches on the control printed circuit have broken - if you cant hear a very small click or feel the click of a switch thats probably the problem . Dont be afraid to carefully take the whole electric control panel off the machine with the view of having the switches checked and or replaced .Most of these circuits simply clip into place . More advice your tv repairman often can replace these micro switches a lot cheaper than buying a new printed circuit . (By the way please check the printed circuit for any signs of water damage before seeing technicion ) .
Aug 13, 2011 | Fisher and Paykel DEGX2 Dryer
My fisher paykel washer smells like something is getting too hot and melting plastic when it starts the rinse cycle then it starts beeping and shuts off. I have had this machine about 2 years and had to...
Check the drain pump after it has been draining for a while. Drain the water out, turn power off at wall. Tip the machine back against the wall. Look under the front right hand corner and locate the drain pump. Touch the metal part & see if it is very hot. Should be just luke warm. Very hot means it has to be replaced with a new pump now before it burns out and damages the control board.
Jul 27, 2017 | Fisher and Paykel GWL11 Top Load Washer
Fisher and paykel washer doesnt turn on. no power . power at wall outlet
There are solder in slow burn fuses located on the circuit board that can burn out if the pump gets clogged or broken and some other reasons that you can buy from Mouser electronics using p/n (mouser) 576-37416300410 or Mfg p/n 37416300410. The fuses are reddish, round cylinders about .5 inch high and wide. Anyone who can solder can easily fix this. Be sure to tag any connections that you remove although all you need to do to get the circuit board out to work on it is remove the small rubber hose and 2 electrical plugs connected to the board through the outside cover. There is paperwork inside the head of the machine (and there is the circuit board) with fault codes to help you determine what your specific problem could be but I had a no power problem recently and replacement of these 2 fuses fixed it. Let me know if you need further help!
Nov 18, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher and paykel dishwasher won't drain
SOLVED! Remove the white plastic shield under drawer, look for the small green U-board circuit board near the center. If it's loose, that's the problem because the board has a sensor that detects the rotor spinning and if loose the computer gets confused. Slide the board into place, so one end of U-board is close to center, you can see where it slides in. I took a 1/4" diameter wad of 15min epoxy putty an secured the bottom corner of the board.
Aug 31, 2009 | Fisher and Paykel Dishwashers
CIRCUIT BOARD GONE OUT
Do not be unhappy with your machine. Believe me, many brands that cost much more than the Fisher & Paykel have circut boards go out on them as well. First of all you machine is still in warranty if it is only one and a half years old since the machine has a two year warranty. Other manufacturers only have one year even if they cost much more to purchase. Be thankful that you are entitled to a repair at NO Charge! I have sold appliances for 34 years and sell multible brand names. I can assure you that based on the lack of quality manufacturers have been delivering to the public over the last ten years you have made the best desicion when you purchased your Fisher & Paykel. Most washers have between 350 and 400 parts in them to create a potential of failure. the Fisher & Paykel has only around 70 parts total. We have sold them for over ten years and it is the best product in our store bar none! Remember, you are still in warranty so your repair will cost you nothing!
Apr 22, 2009 | Fisher and Paykel IWL12 Top Load Washer
Fisher and Paykel Intuitive Eco Washing Machine
The drain pump is overheating. I suggest you do not try to use the machine until you replace the pump unit, failure to stop using the machine will result in the pump short circuiting and destroying the main control board!. Please go buy a new pump and fit it.
Sep 23, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
44 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
