Question about Electronics - Others
Id like to view movies on my elefw195 through a usb flash drive. what format should that usb drive be, and what specific file formats does it support?
JoAT
  • 121 Answers
SOURCE: USB flash drive wipe out
I went to the Sandisk website and they actually have a bunch of how-to videos on there that will help you out with your problem: http://www.sandisk.com/Retail/Default.aspx?CatID=1459 As for getting your information back, you would need special recovery software in order to do that. Here is a link that might be able to help you with that: http://www.download.com/VirtualLab/3000-2248_4-10642058.html
Posted on Mar 23, 2007
STUART360
  • 34 Answers
SOURCE: Movie Formats To Work With Xbox 360
As you may have heard, with the Xbox 360 Flash Fall 2006 System Update they are adding support for WMV video playback from new sources. Videos can be streamed from a PC running Windows Media Connect, Windows Media Player 11, or the new Zune client player, and can also be played from Optical Disc and most USB mass storage devices. For all these sources, only the WMV video file format and codecs are supported. How do I know if a video file will work on the Xbox 360? Currently only the Windows Media Video (WMV) file format and codecs are supported. If you have a file with a ?.wmv? extension, then the odds are pretty good that it will work. Technical details on the types of files we support can be found at the end of this post, but the easiest way to find out if a file will work or not is to just try it. Hopefully after you click play the video will show up on your display, but if the content is not supported you will simply get an ?Unplayable Content? message blade from the side of the screen and then be returned to the Video blade. How do I create videos that will play on my Xbox 360? Windows Movie Maker, a standard feature of Windows XPSP2, will output WMV video files compatible with the Xbox 360 console. Either use the default settings when you finish a movie and click ?Save to my computer,? or just make sure that the output video format you select shows the file type as ?Windows Media Video (WMV).? Videos will usually look best when they are closest to the original resolution that they were created with. Try to create video files at least 360 pixels high in vertical resolution in order to minimize content upscaling on the console. If you decide you want finer control of the output video file format, download a version of Windows Media Encoder (http://www.microsoft.com/windows/windowsmedia/) and then start encoding away. Optimal size and bitrate settings will vary depending on the source material you are encoding. As a general guideline though, 1.5 Mbps is a typical bitrate that should be suitable for most standard definition content, and 8 Mbps is a common bitrate for high definition content. Can I get more technical details about the kinds of files you support? WMV video files with the extension ?.wmv? are stored in a generic file container format known as ASF. ASF files can contain many different types of codecs within them. Xbox 360 supports most common WMV video codecs, as seen in the following chart: Supported Video Codecs: Name FourCC Windows Media Video 7 WMV1 Windows Media Video 8 WMV2 Windows Media Video 9 WMV3 Windows Media Video 9 Advanced Profile WVC1 There are some files with ?.wmv? extension that may play on a PC, but are unsupported on the Xbox 360 console. Windows Media Screen, Windows Media 9 Image (Photostory), and some older Microsoft codecs are unsupported, as seen in the following chart: Unsupported Codecs: Name FourCC Microsoft MPEG-4 Video Codec V3 MP43 Microsoft MPEG-4 Video Codec V2 MP42 Microsoft MPEG-4 Video Codec V1 MP41 Windows Media Screen V9 MSS2 Windows Media Screen V7 MSS1 Windows Media Video 9 Image WMVP Windows Media Video 9 Image v2 WVP2 ISO MPEG-4 Video V1 MP4S Anamorphic content with nonsquare pixels is currently unsupported on Xbox 360 console, and will be displayed as if the pixels were square. If you want to play such content on your console, it is recommended that you re-encode the content in a square pixel format.
Posted on May 26, 2007
Ashu2748
  • 62 Answers
SOURCE: HOW TO FORMAT A WRITE PROTECT USB DRIVE
the drive isnt write protected the usbport or the connection is loose so that the computer is showing the drive as read only drive also you can format it using command and also setting off the read only attribute that may have been put by a virus also softwares like usbcillin makes pen drive writeprotected take care
Posted on Jan 19, 2009
SOURCE: Cannot format 400gb usb flash drive
I had the same problem.
Go to the Dos Prompt via run cmd
format d: or whatever your drive letter is.
This worked for me.
PS these flash drives are copies and are made in China. I just bought one for $7.50 Yes that is seven dollars and 50 cents.
Posted on May 21, 2009
SOURCE: view a DSCN movie on Quick time but format is not recognized
You will need a software (probably from Kodak) to play and convert the movies.
Have you tried VLC Player. It can be downloaded free and it can play many formats.
Posted on Nov 06, 2009
How can i play movies from flash drive on my boss bv9363bi raw
Merely want to access the movies stored on a RAW flash drive?
OK! Do not rush to format this flash drive to cause worse data loss troubles.
And then, download RAW file system recovery software to scan this flash drive and see whether all your desired original movies and file are still recoverable.
And then, do a quick or full format there to fix this RAW drive.
Always timely back up and update your important flash drive data on several drives from now.
Mar 08, 2015 | Electronics - Others
How do i know/change my new PNY 16GB USB flash drive to "comply with the USB Class Specification (USB MSC) and supports formats of FAT32 and FAT16" per my car infotainment system requirements? i am trying...
You have to format the drive to the correct type before transferring your music onto it. Not sure whether you're using windows or Mac. In windows go into file explorer, right click the usb drive and select format. This will show you a section of formats including FAT32.
Feb 22, 2015 | PNY Electronics - Others
I am not able to remove disc protection
format it useing nokia 6120c,6220,and c5-00 phone.. or view this site= http://www.makeuseof.com/tag/format-write-protected-usb-flash-drive/
Oct 07, 2014 | Electronics - Others
WHY WONT MY 16GB PNY FLASHDRIVE WORK WHEN I DOWNLOAD A MOVIE ONTO IT?
Perhaps it has not been prepped, eg: not formated to use. Format it with fat32 file system using formatting software from the manufacturer. Also, make sure the movie file does not exceed 16 GB.
Apr 30, 2014 | PNY Attach? 16GB USB 2.0 Flash Drive
Ipod touch pa623ll
You can add video content to your Apple iPod and watch movies on its screen.
Video syncing is controlled by the iTunes application, which then sends the movie files to the iPod's hard drive.
The iPod supports a variety of video formats, and iTunes can convert other files that are not supported.
Plug the iPod USB cable into the bottom of your iPod.
Connect the other end of the iPod USB cable into a free port on your Mac or PC computer.
Open the iTunes application by clicking on the Dock icon on a Mac or using the Start menu on a PC.
Go to the "File" menu and select "Add to Library."
Navigate to the movie file you want to transfer to your iPod and click "Open."
Click on the movie you just added to iTunes, go to the "Advanced" menu and select "Create iPod or iPhone Version."
This will convert the movie file to a format that the iPod can play.
Click on the name of your iPod under the "Devices" list on the left side of the iTunes window.
Go to the "Movies" tab and choose to sync all movie files with your iPod.
Click on the "Sync" button at the bottom of the iTunes window.
The syncing process will begin and the movie file will be transferred to your iPod.
Transfer DVD Movies to an iPod
Transferring DVD movies onto your iPod for personal on-the-go viewing depends on the exact type of DVD you are using.
Some DVDs are in a format that can easily be transferred to iTunes, which can then convert the movies to a format for the iPod if needed.
If the DVD can't immediately be played in iTunes, you will need extra software to convert it before you can transfer the movies to iTunes and then to the iPod.
Load the DVD into the computer's disc drive and open up both the DVD in a window and your iTunes application.
Drag the DVD's main movie file into the main iTunes window to add it to your personal iTunes library.
Connect the iPod to the computer with its USB cable if it isn't already connected.
If it is already connected, or if the iPod does not automatically sync with iTunes, drag the DVD movie file from the library list to the iPod shown in the iTunes source list.
Convert the movie file to an iPod friendly format if you get a message saying the file can't be played on the iPod by selecting "Convert Selection for iPod" in the Advanced menu.
Please note that this conversion can take some time--five to 10 minutes for every two minutes of video.
Conversion Software
Download and install a DVD conversion program to your computer; look for one specifically designed for converting DVD to iPod if possible.
Open the conversion program on your computer and upload the DVD movie file into the program with the "Open" or "Upload" option.
There should be multiple files on the DVD; the actual movie has the longest run time.
Select the format that the file will be converted to from the program's drop-down list of available formats if the program is not automatically set for an iPod format. If an option specifically labeled "iPod" isn't available, choose an MP4 format.
Choose a location on your computer to save the converted file to using the program's "output" option--the desktop is the most common and easiest location.
Click on the conversion button, which is usually the biggest button located in the lower right corner, to convert the file and save it to your computer.
Open up the iTunes application and drag the converted iTunes or MP4 file into the iTunes library.
Connect the iPod to the computer using its USB cable.
http://www.dvd-ipod.biz/guide/cucusoft_dvd_to_ipod_guide.html
Jul 24, 2013 | Computers & Internet
Eh5000 wont play movies on usb stick
The TV can only play a specific format of video. You may be using MP4 files while the TV can only view 3GP or FLV formats; just try downloading a converter (I've used FLV Converter on Windows XP for years, works fine and very simple) and changing the file format.
Jan 30, 2018 | Samsung Electronics Samsung 40" EH5000...
Cannot see pc MOV or JPG files on flash drive in Canon SX230
Thanks very much for responding to my problem.
It seems Canon will not allow edited pictures or video to transfer from PC to their digital cameras for viewing.
steps to my problem:1. my canon SX230 created all the parts for my WMV video in MOV format originally.
2. created a movie (WMV format) in Windows Live Movie Maker. Works well and plays on my PC (windows 7).
3. after WMV completed - converted to HD MOV format in 2 different file convert programs and with 2 different HD MOV resolution settings on Both programs. WMV resolution is 1920x1080 (HD). ALL 4 MOV videos play well on my PC in 2 different programs.
Steps getting Canon to see video in playback mode.1. copy MOV video from PC to Flash drive in my card reader in same folder as my original JPG & MOV files, then inserted into camera - does not recognize file.
2. copy MOV file from PC to camera with USB cable. Windows error message. Wrong format - would not copy.
3. Formatted flash drive in camera. Took picture to create DCIM folder, JPG image, and CANONMSC folder with M0104.CTG file .Deleted CANONMSC folder. Copied my MOV video from PC to camera (USB cable). this time copy successful. However camera does nor recognize file.
5. tried again except deleted M0104.CTG file but not the CANONMSC folder. no luck.
It seems Canon will not recognize any file that has not originated in the camera AND has not been altered. Upon researching answers on the NET - many other users of Canon cameras have the same problem with no luck.
Apr 23, 2012 | Cameras
I am using a 8Gb usb flash drive. I formatted the drive. Copied the new bin files to it. The is no directory on the drive. I click the usb and it tells me there is no usb drive. I place the usb drive in...
You formatted the drive first - what format did you use? The HTS3520 can only read FAT or DOS formats (FAT-32 is the newest format that the unit can read.) (Most USB flash drives come with a FAT32 format.)
Alternatively, you could burn the upgrade files to a CD-R.
See http://www.p4c.philips.com/cgi-bin/dcbint/cpcontent.pl?mid=Link_Software&scy=BR&session=20110704115315_216.183.195.180&ctn=HTS3520/55&slg=ENG&dct=FUS&did=ENG&reldct=FUR&file=/files/h/hts3520_55/hts3520_55_fur_eng.pdf#toolbar=0&zoom=100 for the detailed settings for burning the files to a CD.
Jul 04, 2011 | Philips HTS3500S System
Doesn;t taking large files
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW.EXE
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Jun 19, 2008 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Electronics - Others Logo
60 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
