Question about The Kitchen Appliances - Others
My deep fryer fire come down to conversion even when the thermostat is off
SOURCE: Rival CFZ530 Deep fryer
I had this same problem which is how I came across your post, and I found on the Rival website ( www.rivalproducts.com ) you can email the company and tell them the model number and they will email you the manual, and if you're like me and hate to wait that long, you can call their customer service number and tell them what you need and they will email you the manual in about an hour. The number the website gave me was  1-800-323-9519, and I also realized there was also a number on the box too.
Posted on Apr 16, 2008
SOURCE: cleaning deep fryer
You can not remove the reservoir because if you clean it out with a hot soapy spange or rag. turn the frier over and remove the plate you will see why the reservoir wont come out.
Posted on Aug 05, 2008
Sheikhtijani
  • 1284 Answers
SOURCE: delonghi deep fryer drain tube replacement
Hi, go through the operating manual of the deep fryer on the link below to learn how to replace the drain tube...
http://www.delonghi.co.uk/pdf_files/F350WA.pdf
Take care
Posted on Jun 01, 2010
kebah
  • 684 Answers
SOURCE: pitco deep fryer flames coming out the fryer
Hi there.
The soot or carbon have probably build up inside the fire tubes, better check and have an authorized service technician clean them.
Make sure that the fryer is receiving the rated gas pressure and correct gas type as stated on the nameplate, this way, carbon or soot formation on fire tubes can be prevented
Regards.
Posted on Sep 13, 2011
SOURCE: Deep fryer catching on fire
From the video it appears many things could be wrong. The baffles and burner tubes could be clogged, the burner itself can be clogged, the flue is blocked, or this unit is using the wrong type of gas, ie: propane on a natural gas fryer.
Recommended steps for troubleshooting.
1. Verify proper gas type. Natural or Propane.
2. Check Burners, tubes, and baffles, clean all soot and debris from them.
3. Check for and remove any obstructions from the flue.
Posted on Apr 27, 2013
Imperial gas fryer burner wont light
Check out the over heat is not shutting down to soon or thermostat is not opening ,
Sep 01, 2012 | Imperial IFS40 Deep Fryer
When i set the thermostat to desired setting flames shoot to the front of the fryer
Hi Dan.
Check if the fire tubes are clean, exhust system must be operating well during fryer operation. There should be no fresh air directed at the flue stack of the fryer, only exhaust.
Regards.
Oct 26, 2011 | Pitco Frialator SG14 Deep Fryer
Would Pitco 35C+ still heat if bulb/capillary of control thermostat breaks?
Hi there.
The unit will not fire up if the capillary of thermostat is broken or punctured because the thermostat's mechanical contact will remain open.
Regards.
Jul 08, 2011 | Pitco Frialator 35C Deep Fryer
Fryer does not shut off when temp .is reached
I assume it is a gas model. There are 2 thermostats. One is adjustable, you set your temp, it sounds like it has gone bad.. The second thermostat is the high limit thermostat. When it reaches 450 degrees F, it will shut down the pilot and main flame to prevent a grease fire. It may be possible that someone has hooked the thermostat up wrong. Next time you fire it up, disconnect one of the thermostat wires that has the temperature knob. If the flame goes out, the thermostat is bad,
Oct 04, 2010 | Imperial IFS40 Deep Fryer
I got problem with my cecilware gas deep fryer fms 40, i was able to turn on the pilot, then i turn it to full on possition, but the fire will go out when i was trying to adjust the thermostat, please...
Make sure the flame is staying on the burner and not lifting away from any sensors in the flame. You may need to adjust the air bands on the burners to get the flame to stay down. Also make sure the vent in the back is free of blockage.
Feb 13, 2010 | Cecilware FMS-40 Deep Fryer
My deep fryers got on fire hS ALOT BLACK
leaking pan
safety thermostat fail and main thermostat fail and cause flash over.
Jun 22, 2009 | Pitco Frialator SG14 Deep Fryer
Adcraft double deep fryer
its safety switch not functioning
Jul 03, 2008 | Adcraft DF-6L/2 Deep Fryer
Fryer works then shuts down
i think that its is a hi limit switch to prevent a oil fire the fryers at kfc would dothis everyso often and it turned out tobe a bad logicalboard somewhere, check all valves and the switches on them to make sure that the fryer is aware when they are open or closed? let me know if you need more info
~Lee
Jun 23, 2008 | Pitco Frialator 35CS Deep Fryer
CAN'T GET UNIT WORKING CORECTLY
What parts did you replace to do the conversion? Make sure all your wire connections are correct (hi-limit/thermostat/thermocouple connections).I repair these fryers if you need more advise let me know.
Nov 26, 2007 | Vulcan EF3 Deep Fryer
Kitchen Appliances - Others Logo
22 people viewed this question
Top Kitchen Appliances - Others Experts
Bilral
Level 1 Expert
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
