Question about The Computers & Internet
Computer card does not give video
I cleaned the memory, I changed the battery, the hard disk, the source. I left the machine but it does not have a screen output, I connect the cable and the cable goes without signal on the screen. Any help or suggestion will be very helpful.
    New Friend:
    Problem Solver:
  • 5 Answers
Kindly check if you put back the memory in the right place, but if it still doesn't work, try to get an eraser, use it to clean the teeth of the memory, but if it still not working, try to replace your memory..
Posted on May 17, 2017
My acer pc is not booting properly
there maybe faulty installed hardware on your PC. remove those hardware like sound & video card (if any), PCI modem, CD/DVD ROM, etc. turn on your PC without those hardware & if/ there's nothings change?..it means that there is no wrong with your PC's hardware. turn the PC off, re insert IDE & power supplies cable of your hard disk drive to make it sure that the HDD is properly connected & being detect by the system. remove the memory card and clean or wipe the connector surface of the RAM with tissue paper. (change new memory card if needed). check the mother board C-MOS 3 volts battery if it is volts sufficiently .turn your desktop on & wait for good results.( Reformatting your OS is also recommended.)GOOD LUCK!
Jul 09, 2014 | Acer X193W LCD Monitor
I have a gigabyte p4 pc, when i power it on the fan runs but it gives out a continuous beep. checked ram, processor on another motherboard, cleaned the motherboard, checked for loose cards and cables
The continous beep usually means a memory failure (RAM) or video memory if a plugin card is used.
Check to be sure the unit sees all of the memory, a weak power source( without AC adapter) could cause a partial failure of one memory card.
Another fault would be that the battery is very low on charge and won't accept any charge.
BAD Battery.
hope it helps
May 31, 2012 | Gigabyte GA-8LD533 Motherboard
My computer wont turn on with or without the charger
Try taking out battery and plug in power. If it works, battery is faulty. If not,
Try taking out your hard disk plug in power, if it works, hard disk is faulty. If not,
Try taking out memory card, if there's a sound, memory card faulty. If no sound, it's your motherboard that is causing the error.
Note: If machine is under warranty no need to pay for the repairs.
Jul 01, 2009 | Computers & Internet
When the computer is turned on via the power button, the computer does not come on. When I check the LED indicators, the on/off indicator goes green, the battery power indicator is first orange, then...
Jun 30, 2009 | Computers & Internet
Not start up and not charging, changed battery and charger,
Jun 30, 2009 | Sony VAIO VGN-AR230G Notebook
Dell latitude C640 laptop battery will not charge. Got a new?? battery but it won't charge either. I am able to run on A/C power just fine.. When I got the computer (used) the battery worked fine... what...
Jun 08, 2009 | Dell Latitude C640 Notebook
My Computmer only charges when its off
BATTERY
Jun 04, 2009 | Toshiba Satellite 2435-S255 Notebook
Possible mishap with the power?
there are different ways on how to check the problem you encounter regarding on your machine. kindly follow the procedures below:
- first take out the battery and plug in the power supply. if it works, suspected it's a faulty battery (if your machine is under warranty call the service center for the replacement of your battery
- if the machine won't turn on after taking out the battery and pugging in the power, take out the hard disk, plug in th power. if it works, suspected hard disk faulty. (replace hard disk)
- if machine still won't turn on after taking out the hard disk, take out the memory card. you will hear a beep sound after taking out memory card. if it works suspected memory card faulty. (replace memory card)
- if you didn't hear any sound after taking out the memory card, suspected motherboard faulty. (replace motherboard)
May 27, 2009 | Toshiba Satellite A25-S207 Notebook
HP a1712n How to troubleshoot MOB problem?
you can consider 4 factor on no video,it maybe video card or memory card,processor last mother board this if PSU was good,you also check memory card to other computer,somerime need only to clean terminal slot of memory by pencil eraser,eraser slot then put it back,also video card same process in cleaning try also to other computer.Instale good memory card and good video card even with out hard drive,cd room the mother board.if does not run,defective motherboard,
Mar 16, 2009 | HP Pavilion a705w PC Desktop
Computer
Increasing computer speed is a relative item. Depending on the state of your machine several items could help. None of the following changes are likely to dramatically speed up a machine, but they may change a mildly annoyingly slow machine into one with performance that is acceptable. Or most likely help return your machine to the speed it had when you purchased it.
Removing viruses , spyware and various malware can increase perceived speed by eliminating applications you probably do not want executing on your computer. There are free products as well as purchased products that perform these functions with varying degrees of success. Companies such as Trend Micro, F-Secure and Symantec, Panda offer free online scanners for a quick cleanup or second opinion and purchased products for continuous testing. ClamAV is an open source product (free) as are Spybot, Spywareblaster. Lavasoft's Adware offers a free and paid version of a adware removal tool. There are many more viable and suitable applications in this area. Some (limited) free games and applications may be broken by products like spybot so care should be taken in using that product if you desire the use of the related applications.
Eliminating startup applications you do not use or do not use often could reduce both physical and virtual memory pressure. Many of the exist in the systool bar area on Windows XP and often within a preferences menu windows can be instructed not to start them when the computer boots.
Cleaning up unneeded files on the hard drive and purging caches after closing or as you close web browsers could reduce issues with a nearly full hard drive. Temporary files tend to get left on the machine and are not cleaned up unless specifically requested by the users. Temporary Internet files when there are multiple users of a machine are kept by user so cleaning these up when closing a browser helps all users. (Using proper care and removing unused applications (often demos) loaded by the factory can reduce disk usage -- make sure you understand what is not needed before doing this or you may break your machine and utilize uninstallers to do the work do not start deleting application files using the trash can/recycle bin)
Compacting (not compressing) files on your hard drive periodically could improve disk efficiency and simplify file allocation because larger blocks of free disk space exist.
Compressing files on a hard disk if it is running out of space slows a computer because compressed files must be decompressed before they are used. Purchasing a second or larger hard disk (and transferring your files) so compression is not used can speed up a computer. Not all hardware works in all machines -- assure any hardware upgrades purchased are compatible with your machine.
Running less applications at one time can speed up some slower computers.
Some motherboards will accept faster processors -- but that change would require considerably more technical expertise than the above solutions. and not all processor speed increases are compatible with the existing memory. Likewise some (and limited) cases faster memory can allow the processor to run faster as it allows the processor to reduce it's wait time for memory.
Dec 11, 2007 | Computers & Internet
Computers & Internet Logo
20 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
