Question about RCA Televison & Video
What is the code for a RCA RT2911 receiver - RCA Televison & Video
RCA RT2911 Home theater with AV receiver
You will have to ask the seller whether local repair, possibly at an authorized service facility, is acceptable.
Jan 04, 2014 | RCA Audio Players & Recorders
Rca rt2911 will not come on at all
Check and replace damaged component/s at its main power regulator section circuit. Products powered by electricity should be serviced or repaired only by experienced professional technicians. Any attempt to service or repair the product by anyone else could result in serious injury or death. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock. Instead, contact the nearest service centre.
Aug 13, 2013 | Televison & Video
My surround system says Sat\opt i need it to say Sat\Coax what do i need to do ?
look for a button on the remote that says input select or something like that. Should be able to switch between input options.
Jul 13, 2013 | RCA RT2911 1000-Watt HDMI Home Theater...
Rca rt2911 beeps
Try with an hdmi cable . I think
Mar 04, 2013 | RCA rt2911 1000-watt hdmir home theater...
Just purchased the RT2911 this afternoon at a local Wal Mart.. Got it home, out of the box, on a shelf, distributed the speakers accordingly, plugged the unit in. I powered on the receiver and immediately...
Did you try reversing the speaker cables in the back of the unit? I mean making sure the ground wire ( the wire with a black stripe on it ) is in the right connector.
Feb 07, 2012 | RCA Audio Players & Recorders
I need the code for my older rca home theater system for my sanyo tv remote
rca recomends that you use the "code search" option that many universal remotes offer.
you can always use this remote code search from rca themselfs if the have your product listed:http://remotefinder.rca.com/default.aspx?site=rca
for your rca home theater code it is
dvd code:3160
Audio code:4300
you can also try these:4259, 4264, 4265, 4266, 4290, 4300, 4350. they are for audio receivers/amps. these should work, If not give me a message back.
as for Sanyo try these codes: 1004, 1048, 1049, 1073, 1080, 1107, 1162, 1169, 1180, 1196
Hope I helped get your home theater running agian!
Mar 16, 2010 | Sanyo Televison & Video
Can I get the codes to program my RCA converer remmote
go to rca''s website and there will be tabs to walk you thru to get any codes
Apr 26, 2009 | RCA ATSC11 DTV Receiver
Televison & Video Logo
27 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
