Question about Sewing Machines
Hi, I need your help to put on new whole part of feed dog in usha sewing machine due to broken old one from down side.
fwadley
  • 482 Answers
SOURCE: babylock ellure feed dog will not raise
go see your local parts man. he will know what you need and he will have it there or he will need to order it.
Posted on Dec 16, 2007
SOURCE: Feed Dogs won't feed fabric.
I can not find the screw. does anyone have a picture of where the screw is?
Posted on Jun 03, 2008
  • 3 Answers
SOURCE: Dropping Feed dogs on kenmore model 19233
Pull out the removable table and you will see the drop down feed dogs switch lever behind the back of the machine. Move that lever to the left or right to have feed dogs go back to normal sewing mode OR for embroidery mode.
Posted on Mar 07, 2009
SOURCE: feed dogs
I was having trouble with this too, but found more help online...you have to switch the dog feed back to 'up'....then turn the needle wheel toward you....the feed dog should snap back into place :)
Hope this helps :D
Posted on May 01, 2009
  • 980 Answers
SOURCE: repair singer 502 sewing machine
You can get the fears quite easily and fit them yourself and if you email me I can attach full instructions.
drivewithken@blueyonder.co.uk
Posted on Sep 19, 2009
The feed dog on my bernina 1130 is not working. IT will not pull the fabric.
Even if you select a longer stitch? Have the feed dogs been dropped for darning? Otherwise, your mechanical machine may be seizing due to old oil that has solidified.
Wheel on right side that controls the needle up and down is very tight...
Sep 08, 2017 | Bernina Sewing Machines
The feed dog is up but has stopped feeding
Are the feed dogs moving at all--like moving toward the back of the machine, dropping down below the needle plate, moving forward, rising, and then moving toward the back of the machine? Make sure the stitch length is set high enough to actually move the fabric--not set at zero or near zero. If the feed dogs stay below the needle plate, then most likely they have been dropped for darning.
If the feed dogs are frozen, not moving, and it is an older mechanical machine, they may be seized due to old oil.
Or, the feed dog mechanism is broken.
Sep 01, 2017 | Sewing Machines
I have 158-17750 kenmore sewing machine knob on front that controls feed dogs is stuck,will not turn to let feed dog up & down,is there video tutorial that show me how to correct the problem help!
It has seized due to old, dry oil and lack of regular maintenance. Feed dogs often are affected and are evident on most older machines found for sale because they are frozen. It would be best to apply TLC to your machine asap as the motor could eventually be damaged trying to drive parts that are sticking.
Mar 22, 2017 | Kenmore Sewing Machines
Viking sewing machine 6690 feed dog are frozen down ...how can I fix this
Hello Mary
The Viking 6690 features a 'Presser Foot Pressure Dial' located on the left side of the sewing machine head. It is probably turned down to the thin end of the wedge or may even be parked on the rectangle ... this will cause the feed dogs to stay down. Turn the dial toward the wider part of the wedge symbol. The feed dogs will come up as the sewing machine makes a stitch.
Please let me know how this works out for you.
Happy stitching.
Mar 05, 2017 | Sewing Machines
Where is the feed dog lever on my bernina record 830 sewing machine
On the Bernina 830 Record (older mechanical model), it is usually the very bottom knob on the right side (directly below the Stitch Length Lever). It should turn right or left about a quarter turn to switch between feed dogs up or down. If the knob is frozen, then it has seized due to old dried oil (a common occurrence with older mechanical machines that have not been serviced regularly). Stuck feed dogs, stitch selectors, buttonhole knobs, and the handwheel are some of the most frequent victims of seizure. However, with lots of patience, time, fresh good quality sewing machine oil or liquid Tri-Flow Synthetic Lube, elbow grease and a handheld hairdryer, these issues can usually be successfully addressed.
Jan 13, 2017 | Bernina Sewing Machines
My feed dogs keep coming up when using a hoop doing embroidery what can be the cause?
sounds like there is something wrong with the feed dogs or the feed
dog lever could be broken,, they need to be checked
Jan 24, 2013 | Brother InnovIs 4000D Computerized Sewing...
I just got this machine new and feed dog
Thats because you have a part in their thats been moved or shifted dont try anything call your technician to help you remove the broken part or remove it!! Ok
Mar 25, 2010 | Juki TL-98Q
Feed Dog problem
Here are some common reasons that the fabric won't feed:
1. Stitch length is set to zero, or machine is in button hole setting
2. Feed dogs are dropped (free motion setting)
3. Broken gears (typically in old singers)
4. Presser bar not coming down - may be bound up.
5. Lots of lint under the needle plate (in between the feed dogs) preventing feed dogs from raising.
Hope this helps.
Nov 29, 2008 | Baby Lock Esante
Sewing Machines Logo
19 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
