Question about Eureka Vacuums
Looking for a diagram of the motor for the Eureka Europa 12 amp true heap vacuum cleaner 381001256
SOURCE: looking for Eureka belt 70646A for a Eureka The Boss upright
I just replaced the belt on my Eureka The Boss Smart Vac (Model 4870D). I purchased a namebrand Eureka R belt from a local vendor. I did my best to follow the instructions printed on the bottom of the machine. I turned on the vacuum cleaner and the belt brush was spinning! I dropped it into vacuuming floor mode and the belt wouldn't spin no matter what level I put it on.
I called the manufacturer (1-800-282-2886) and spoke with a very nice woman on the phone. While I was speaking with her I noticed that a silver screw was lodged within the "brush roll control" yellow selector switch. With some shaking it became dislodged and I was able to put the "brush roll control" into the hard floors setting and turn the "carpet height adjustment" all the way to the right, so that it was facing the word "low." I then followed the instructions for replacing the belt again.. (1) remove base plate (2) remove brush roll (3) place new belt around motor shaft and then around brush roll (4) insert left side of brush roll before right side (5) rotate brush roll to be sure belt is centered (6) replace base plate, making sure to insert under 4 little tabs before securing with screws.
It appears that it is very important that the carpet height and brush control adjustment are set to their highest point possible (hardwood setting) in order to get the brush to roll in a carpet setting.
"R" is the correct belt for the 4870 and should be correct for all other 4800 models.
Thank you for posting your problem to this website. If I hadn't seen that others were having trouble, I would have just given up. I hope this long post helps someone that was in my situation.
Posted on Aug 06, 2008
nwj2468
  • 76 Answers
SOURCE: My wife's Eureka 5855 Boss Bagless Wide Track stopped running
its probably something in the motor. you may have to replace the motor which could cost around $50.
Posted on Apr 19, 2009
bastoe
  • 34 Answers
SOURCE: How do I to change the belt on an eureka altima 12?
the belt is on the bottom right (looking at it from the front). the Eureka website does have the manual for download, http://www.eureka.com/service/manuals/80244.pdf
With the vacuum flattened (straightened) out, turn it over and remove the back roller cover, (2 screws) once off, the roller should just pop out on the opposite side (opposite from the belt). Don't forget to turn the roller to center the belt once you have it on.
Posted on Jun 14, 2009
  • 21 Answers
SOURCE: Looking for the instruction manual for the Eureka
Go to http://www.eureka.com/service/manuals/80244.pdf this is a direct link to the owners guide for your model or you can call customer service at 800-282-2886 and request a hard copy
Posted on Jul 19, 2009
  • 430 Answers
SOURCE: Eureka canister vacuum cleaner Model 6865
The 6865 has a high rpm AMTEK Lamb motor, Brushes will seldom solve the problem at this stage.
Once the sparking and burning starts the conectiion between the brush and commutator is arcing and burning. If the sparks are blue, save your time.
A good service tech will run in brushes with a seating stone and a low voltage setup to allow new brushes to seat, but this is generally best accomplished on heavy duty , lower rpm motors.
IF YOUR ARMATURE IS SCRATCHY LOOKING OR WORN LIKE AN APPLE CORE,OR THE SEGMENTS ARE NOT PARALLEL IN THE SPACING YOU WILL NEED A NEW MOTOR.
Posted on Oct 16, 2009
What is the replacement belt number?
Shop for Eureka Vacuums What is... on Google
Eureka® Replacement...
$2.89
Staples Eureka Upright Vacuum Clea...
$5.99
Eureka Eureka Hand Vac Belt
$2.49
Eureka Eureka R Type Replacement...
$5.99
Bed Bath & B...
(4) Eureka AS1104 Drive Belt
$3.49
Google Trusted StoreeVacuum... Search Results
    Belts - Eureka
    www.eureka.com/en-US/Vacuums/Accessories/Belts/
    EurekaWith high-quality vacuum cleaner belts from Eureka, you can get better performance from your ... For optimum performance replace belts every 12 months.
    Eureka Replacement Belt for Upright Vacuum ... - Walmar
Jan 19, 2016 | Eureka Vacuums
Eureka True Clean vacuum cleaner manual
Contact Eureka local dealer , or go to Eyreka Website , for info.
Mar 16, 2015 | Eureka Vacuums
How to reconnect a eureka altima 12 amps vacuum carpet adjuster
download the instruc manual, and proceed according. go to www.retrevo.com or www.fitness.manualsonline.com
God bless you see the diagram
Jun 19, 2012 | Eureka Altima Upright Vacuum Model 2996AVS...
I'm looking for CV1801 Vacuum Motor, Greator Toronto... Thanks
Hello There,
I've looked up your model vacuum cleaner, and it seems that I am able to still get this motor for your Eureka central vacuum cleaner. We're located in the United States, but we can certainly ship this to you.
Here's a picture of the diagram for you;
We sell the genuine Eureka motor for $199.00, however you may save substantially on this motor by purchasing it under the Lamb Electric name. The motors are identical, and Lamb actually makes this motor for Electrolux, and sells the replacement parts for MUCH less money they Electrolux. We sell the motor under the Lamb name for $119. I went ahead and added this part to our site so you could place your order if you wanted to. I don't have it in stock today, but my parts distributor is showing 3 in stock, so we can easily have your order shipped out within 2-4 business days.
Here's the link to the Eureka CV1801 Central Vacuum Cleaner motor, Part number 54586;
http://www.govacuum.com/10661-Eureka-Central-Vacuum-Cleaner-Suction-Motor-Assembly-Part-54586-.aspx
Hopefully this was helpful to you. I've also left you a link below to the parts diagram of your vacuum cleaner, in case you need some visual help to see how it comes apart. If you found this repair to be helpful, please be so kind and rate the repair helpful, or leave feedback for me. I really do appreciate it, and this also helps people with the same question find the answers easier. If you have any questions, please feel free to email me at chris (dot) jones (at) govacuum (dot) com.
Full Size Schematic in .pdf form:
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/eureka-cv1801-central-vacuum-cleaner-part-diagram.pdf
Thanks so much,
Chris Jones
GoVacuum.com
Jan 06, 2011 | Eureka CV1801 Bagged Vacuum
Surfacemax 300 yellow eureka vac. is there a belt? if so , what is the belt number and how do you change the belt? most vaccs have this info on the product a is not ablet to locate this info. tnanks
On the top yellow part above the rollerbrush, there are two screws. Take them out. Insert your fingernail into the part where the yellow meets the rubber and lift. The yellow should pop off. Follow the directions printed on the label inside, directly above the rollerbrush to change the belt.
Your vacuum SHOULD have come with a replacement belt as well as an instruction guide. The instructions for replacing the belt are there. If you don't have this, well, that's why I typed this out. :) You can purchase a belt on eureka.com by looking under customer service, and putting in your model number. This is located on the label on the back of the vacuum, under where the cord goes through that loop thing.
Oct 24, 2010 | Eureka 6833D SurfaceMax Canister Vacuum...
My Model 2961 Eureka wont take power now?
Anytime that you smell that electrical burning smell on a vacuum cleaner, this is the motor going bad. There are two distinctive burning smells in fixing vacuum cleaners, the electrical burning smell which is the motor, and a rubber burning smell which is the belt.
The bagless vacuums cleaners in general, their motors last usually no more then 3-5 years. The motor in bagless vacuums work much harder then the motors in their bagged counterparts.
The motors in Eureka vacuums can range in price from $70-$120. If you can provide me with the exact model number on your vacuum cleaner (can be found on the bottom or the back of the machine on the sticker that also contains the serial number) I will be able to get you the part number, and price of the motor that's used in your vacuum.
It may be worth considering to just get a new vacuum cleaner at this point. If you'd like me to give you a personalized recommendation specifically for your unique cleaning needs, I'd be honored to do so. Please just let me know what types of floors you have mostly in the home and I'll be happy to share my knowledge of vacuum cleaners.
I hope this was helpful to you. If you found this helpful, please be sure to rate the repair helpful so other Fixya users that have this same problem can easily find the answer.
Thanks so much,
Chris J.
GoVacuum.com
Apr 11, 2010 | Eureka 2961AVZ Bagless Upright Vacuum
Jun 14, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Apr 15, 2009 | Eureka 5849A Boss Bagless Upright Cyclonic...
Vacuums Logo
24 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
