Question about Refrigerators
My ice maker makes ice and water dispenser works. It won't dispense ice out of dispenser on door. What could be problem?
Buffalo12980
  • 625 Answers
SOURCE: Water dispenser
the slide switch ice - water may not be making up. the paddle inside the door operates a common microswitch to either dispense ice or operates the water solenoid. check out the selector switch.
Posted on Aug 22, 2007
SOURCE: Jenn Air JCD2389GES ice dispenser problem
my ice maker is not making ice.
Posted on Mar 26, 2008
  • 16 Answers
SOURCE: No water to door dispenser
The water lines might be frozen. The found the water lines in my fridge behind the bottom drawers and used a hair dryer to melt the ice.
Posted on Jan 23, 2009
  • 142 Answers
SOURCE: water dispenser on front of refrigerator door does not dispense water. Ice Cube maker continues to make ice cubes. Defrosting doesn't fix problem.
Water dispensing solenoid is bad. You need to replace the solenoid valve. This typically is independent of the ice maker.
Posted on Jun 02, 2009
bobjohns
  • 51 Answers
SOURCE: Water and ice dispenser on door does not work but
There is a computor board behind the control pannel it could have failed. There is a problem with rust making the ceiliond not work also. remove control cover and see if there is rust in there.
Posted on Sep 28, 2010
Ice maker works but no water out of water dispenser?
Hi
You have not supplied the make or model of your fridge and so I can only offer a generic response.
Most ice-makers, chilled water dispensers are reliant upon a water stop valve that make a distinctive click when operated.
Does it click when you dispense water?
If not, then assuming the ice dispenser works (indicating the activate button is working), then the water valve has possibly failed (or less likely the wiring somewhere in between).
Dec 15, 2013 | Refrigerators
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
Ice maker will not dispense water or ice.
sounds like maybe the switch that is press to release water not working so it doesnt sent the signel to let water out dispenser
Sep 29, 2009 | Maytag MSD2756G Side by Side Refrigerator
Water dispenser does not work, ice maker does work. This is a used Whirlpool side by side. I hooked up the water yesterday and the water dispenser worked. Overnight, something went awry and I do not get...
Icemaker is in line with the water and runs from the icemaker threw the door and up to the water valve. So that is why the ice maker is working and the water is not working, most likely the water has frozen inside, And this can be caused by many different reasons, if it has been humid or the door was left open then shut it would cause the moisture in the air to be drawn to the warm water and flash frosted the pipe, try to see if you can defrost the line with a hair dryer. If that does not work post here and I will tell you the next step to try.
Aug 30, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water dispenser on front of refrigerator door does not dispense water. Ice Cube maker continues to make ice cubes. Defrosting doesn't fix problem.
Jun 02, 2009 | Frigidaire FRS26R4A Side by Side...
Ice maker will not make ice
the ice maker is not making ice but the water is still working
Jan 29, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
In door ice dispenser does not work but the water dispenser does.
check to make sure there is water or ice in your ice maker tray. If none then problem is usually a water supply issue to the ice maker. Behind the frig are the water supply inlet valves. One is for the water dispenser in the door. THe other is for the ice maker. However when one goes bad they both are replaced as one unit. Also Check position of fingers in ice maker. If not in a vertical position then try to reset the ice maker unit and worse comes to worse, replace it with a new one.
Nov 19, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker not working
The icemakers won't make ice if the temperature is not below a certain set point. Varies between manufacturers. Try making the temp colder.
Feb 01, 2008 | Hotpoint HSS25GFP Side by Side...
Water dispenser
Aug 10, 2007 | Whirlpool GS6SHAXLQ 25.5 Cubic Foot Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
