Question about Garden
Have new Holland 5ft mower model716 GC ser. number YCWB10055, with Slip Clutch Part MAG125D801DOI need new (2)clutch dic
  • 566 Answers
SOURCE: 1997 hyandai accent gt clutch problem
hi considering age of car and that you have no leaks on hydraulics? may i suggest you try bleeding the clutch to rid of old fluid a couple of pumps may be suffice ? b/fluid does absorb moisture and heat over time hence recommendation tat fluid be changed at period specified in handbooks ie 12 monthly ?
Posted on May 15, 2009
  • 226 Answers
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
Posted on Jun 01, 2009
  • 155 Answers
SOURCE: We mow 2 acres with a Greenfield ride-on.
Hi i have seen this with most greenfield models The only way to fix this problem is to replace the drive clutch assy as it ends up to costly to replace the worn parts : shaft,clutch plates & drive pulleys.
In most cases replacing these parts has led to a new assy six months later.
Posted on Jul 23, 2009
  • 430 Answers
SOURCE: LX176 Electric Clutch Slips
The clutch is basically a big 12volt elecrto magnet. When it gets power it grabs the magnet and turns the blades. Usually they either work or they dont.
I would check the relay first. Then check for a loose wire or bad connection.
If it comes down to a failed clutch then be prepared to spend between 150 and 300 bucks. remove the deck and unplug the 2 wire connector from the clutch then remove the center bolt from the crankshaft and the clutch will slide off the end of the shaft. There will be a bracket or pin that holds the clutch and prevents it from spinning. Pay attention to how the bracket or pin is situated and be sure to reinstall the new clutch the same way.
Posted on Jan 04, 2010
  • 3 Answers
SOURCE: Mower starts, but when I let off clutch, it dies.
when the seat goes out of adjustment due to the crappy adjustment bolt design, the bolt inadvertantly engages the safety switch under the seat.
Posted on Oct 24, 2010
JD 345 pto will not turn on.
What you need are wiring diagrams, not schematics, and you will have to inquire directly to John Deere.
Jul 20, 2016 | John Deere Garden
Can the clutch be adjusted on an unidentified riding mower/tractor?
Probably not if its a hydraulic transmission. The first thing to do is fit a new drive belt as this is the most common cause of what appears to be clutch slip.
Jan 30, 2016 | Garden
PTO turns without mower shaft inserted. Mower blades turn when rotating shaft by hand. Slide shaft back into PTO and nothing is turning. Belts on mower deck look ok.
Sounds like your magnetic clutch is not fully engaged or slipping and cannot handle the load of the mower deck..try this...Using a good pair of snug fitting gloves..with the engine in its lowest idle position and the shaft out of the clutch turn on the carefully see if you can manually stall ( make the clutch slip) if it does sip or stall it needs replaced.just be careful....good luck..
Jul 29, 2015 | Garden
TS6.140 New Holland tractor clutch appears to be slipping how do I adjust it 2013 year model
There a lever clutch petal hooked to. Unhook linkage, move lever toward back of tractor. Screw linkage to aleign with lever.
Jan 04, 2015 | Garden
Can a bad battery cause clutch to slip?
Not likely. But to eliminate that possibility try connecting a battery charge to the battery and try engaging the blades then. Also check all electrical connection in system for corrosion and tightness. Lastly With compressed air blow all dirt and debris from the mower, especially clutch area and Hydraulic pumps. Check tension on blade drive belt.
Aug 17, 2014 | Swisher Garden
Clutch cable installation
  • Put your mower in the lowest position and open the hood.
  • 2 Lift up the retainer spring that holds the clutch cable to the adjustment bracket. Pull the cable out of the bracket.
  • 3 Remove the clutch cable spring from the idler bracket. Pry the spring open with a pair of pliers if necessary.
  • 4 Hook a new clutch cable spring over the idler bracket and squeeze it closed.
  • 5 Slip the clutch cable under the retainer spring.
May 04, 2013 | Husqvarna Garden
Received a * used* Swisher ZT 2660 26hp in October of 2010 has 50 hours on the meter. First 2 or 3 cuts all went fine last cut of the year when the mower would contact grass / leaves the blades would...
Is the belt slipping? If it's slipping you'll notice it, because it'll smoke pretty soon. If, as you watch it under varying load, it slows down with the blades then the belt is fine.
If it's not the belt then it's going to be the electric clutch that drives the belt. Get your voltmeter out and tap into the wires that go to the clutch, watch it as the mower runs. Anything under about 13V and the clutch may slip. If the voltage is good then the clutch is worn out. They don't cost too much, I'm pretty sure they're well under $100 still.
Make sure the wires that plug into the clutch are making a good connection. You want to check the voltage between the switch and clutch so that you're also checking the switch- if it's got a little crud in it, or a bad connection farther up the line, it can cause the clutch to slip, and you'll see this as the voltage dropping.
Jan 10, 2011 | Swisher 60" 26 Hp Zero Turn Radius Riding...
We mow 2 acres with a Greenfield ride-on. Sometimes have to cut long grass by slipping the clutch to get slow forward speed. Problem is that the clutch system occasionally locks into forward or (worse...
Jul 18, 2009 | Garden
Garden Logo
22 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
