Question about Kenmore Elite Oasis 27052 Top Load Washer
I need to take case off oasis He washer. Need manual
I need to take case off an oasis HE washer. I do not have a manual. I took the back off to adjust the springs and balancer. Now I need front access. Thanks DH
  • 42 Answers
the front of the machine can be accessed by removing the body of the machine. this can be done by putting a screw-driver just below the rim of the body at the top. most of the machines in this series do not have screws on them, but fo check if u have any in your model(you haven't mentioned the model number). then, you can lift off the body by taking it off to the right and left along the lip.
cheers
Posted on Jul 25, 2009
My machine is a kenmore elite oasis mod 27042603 I need a pump for the washer. It makes a grinding noise when it starts to drain. I took it apart and did not see anything in it that might be obstructing...
You can order parts from any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Make sure you use a complete MODEL NUMBER to ensure you find the correct parts listing. The first three sites listed also include exploded view parts illustrations to assist you with locating and properly identifying any parts you may need. The Oasis has two pumps. One is a drain pump and one is a recirc pump. The pump you are referring to, I believe, is the drain pump. Prices vary between sites, so shop and compare.
If you do not find your model number listed at all the sites I have provided, use the part number from the Sears site for your search criteria. In some cases, the model number may not be listed, but the part numbers will.
If you need guidance on how to replace the pump, the following link explains how:
http://www.fixya.com/support/r4155097-checking_drain_pump_whirlpool_cabrio
The Cabrio is the Whirlpool version of your washer. Both models are manufactured by Whirlpool and the washers are configured the same, so these instructions should apply. If you have any questions, please post back and let me know. I hope you find this information helpful.
Dec 23, 2010 | Kenmore Oasis 27042 Top Load Washer
Need instructions on replacing pump on Oasis Washer
This may or may not help but see the following Service Manual for the Whirlpool Cabrio which is basically the same as the Kenmore Oasis.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
May 06, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite oasis top loader 27062
See the following Whirlpool / Kenmore service manual for the Whirlpool Cabrio washer. The Kenmore Oasis is basically the same.
Also see the Sears Parts site for your washer.
Enter the full (###.########) model number and you should see descriptions of the major components and parts lists.
May 04, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Would like to know how to adjust the water level kenmore oasis he
There is not a manual adjustment - the settings are pre-set at the factory.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 25, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Looking for a manuel for a kenmore elite oasis he,stopped washing
If you are looking for a REPAIR manual, each one of these washers come with a technical data sheet located inside the front panel of the appliance. The tech sheet includes all diagnostics procedures, error code definitions, troubleshooting flow charts and wiring diagrams. To access it, you can pop the top panel open by locating the two retaining clips in the seam along the front of the washer where the washer top and front panel meet. About 2 inches in from each side slide a putty knife into the seam and push in to release each clip. Hold the lid shut as you lift the top. The tech sheet is located on the inside of the front of the washer between the wash tub and casing. Or....you can have someone lift the washer and tilt it back and you can try reaching up from the bottom between the wash tub and front casing.
If you need an OWNER'S manual, you can go to managemylife.com and type in the your model number under the "Manuals" link. They have an extensive list of manuals in .pdf (Adobe) format that you can download or print for FREE.
I hope this helps you.
Feb 12, 2010 | Kenmore Washing Machines
Constantly off balance
I have a kenmore elite oasis top loading washer about 3 years old. I took it apart and checked the springs and the rods and the plastic ends that hold the rods in place and all of them look fine. I run an empty load in the washer and it still goes unbalanced on the spin cycle. My water bill has tripled due to the fact that every load takes 3 to 4 washings. I need help please!
Jan 02, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
My Kenmore Elite Oasis also quit in the middle of the cycle - there seems to be no power to it. I can't get it to turn on and the door is locked. The clothes have been in there for a couple of days now and...
Disconnect your Kenmore Oasis washing machine from its power source. Make sure that your washer is unplugged before beginning to disassemble it.
Remove the screws that hold the control console to the top of your Oasis washer. In some Kenmore Oasis models, the two screws may be covered by plastic end caps. After removing the screws, set them aside until you are ready to replace them.
Flip the console up, back and out of the way.
Locate the cabinet clips on the top of your Kenmore Oasis washer. These clips are located toward the back of the washer top and would be hidden by the console if it were not currently flipped up.
5
Slide your screwdriver underneath the metal cabinet clips. Wiggle the screwdriver back and forth to gently pry the cabinet clips free.
6
Disconnect the group of colored wires that plug into the top of the washer from the control console. These wires control the lid switch on your Kenmore washing machine. To disconnect, grasp the white plastic clip and pull gently.
7
Remove the washing machine cabinet. Tilt the cabinet towards you, and then lift the entire cabinet up and off of its platform.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!$!$!$
Oct 25, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Removing the top of a Kenmore Elite Oasis Washer to replace hose
5
6
7
May 17, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
I need a manual for a Kenmore washer, model # 1102708604.
I have now got the manual for the Kenmore Elite washer and dryer coming in by mail. I had gone to the local Sears store and then to the service center close to home. The service center was able to find the manuals and order them for me.
Thanks for your help.
Cecil
Apr 10, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Oasis HE won't drain
I had the exact same problem last night.
Here is what I did and it fixed it with NO PARTS or SERVICE CALL.
First, I took the drain hose and Blew through it with my mouth... I got air bubbles to come up in the wash bason, this told me the drain pump and hoses were not "Clogged"..
Next I took a shop vac and a 5 gallon bucket and used the vac to **** on the drain hose to start a siphon into the bucket...worked like a champ... I had it drained in less than 3 mins....
I Took the back cover off and then the drain pump off and took the 4-5 screws out of the mounting bracket and took the pump cover off.
What i found when I did this was that there was a VERY SMALL FLAT ROCK stuck between the impellor and the pump casing.
WIth a small screw driver I flicked out the rock and the impellor was free again... HOWEVER, When you do this, the impellor will turn half way and stop... half way and stop, half way and stop...etc.........IT WILL NOT SPIN FREELY like a top. When the motor is still attached to the pump, the armiture in the motor still gives reisitance to the impellor...This I PRESUME this to be normal..
I ended up putting it ALL back together except the back cover to test it...I turned it to a wash cycle and let it run for a few mins. Then i hit stop twice to cancel that wash request. Then i started a second wash cycle and the drain pump kicked right on to drain the water left in the basin from the first test wash..... So far she's purring like a kitten..... Fingers Crossed of course...
Apr 18, 2008 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
Kenmore Elite Oasis 27052 Top Load Washer Logo
132 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
