Question about Home
Riobel Rain shower head with waterfall is leaking and will not seal, any suggestions
  • 2039 Answers
SOURCE: Leaky Gaggia Classic Espresso
you have very steam because like you know our loosing our pressure you need a seal kit be carefull when you play in there calcium buildup is very hard to remove cheers
Posted on Feb 03, 2008
  • 235 Answers
SOURCE: leaking shower head
Check the spout pull knob . Debris can be keeping it from closing completely.
Posted on Jul 05, 2009
  • 297 Answers
SOURCE: The shower hose leaks from the connection between shower hose and
have you tried teflon tape? wrap it around about 7 times and you will be fine.
Posted on Jul 16, 2009
  • 129 Answers
SOURCE: I have a Delta 1400 single handle tub/shower valve
You might have to replace the tub spout, because the divirter is not closing all the way. A new one will stop water from getting by it.
Posted on Sep 30, 2009
  • 50 Answers
SOURCE: The shower head is leaking. I disassembled the
You need to pull and replace the cartridge on your shower valve most likely. It varies by Make and Model, but generally, remove the handle, remove any sleeve around the center spine, remove the round trim plate, close the service stops, remove the retaining clip or ring, and pull the cartridge straight out of the valve body by pulling on the spline... or get a cartridge puller. Then take your cartridge to the store and get a new one. Flush the valve body by slightly opening both service stops and then install the new cartridge and reverse the process.
Generally this problem occurs when sediment has torn part of the sealing o ring on the cartridge. If you send me the make/model and/or a picture I will give you the specific instructions
Posted on Oct 11, 2009
Are riobel faucets a good product
Any faucet sold in a "Faucet Shop" is junk. Any faucet that is made outside of the USA is junk (i.e; Grohe (European) is junk, but Grohe USA is fine. Why? Because real plumbing supply wholesale sells them and has replacement parts.
Not convinced yet? Then when your buying you expensive "decorator" faucet groups, ask the seller if they carry repair parts for everything they sell? You key to grabbing your debit card and hitting the exit door, is when the salesperson gives you a big-eyed stare of wonderment, at the question you just asked them. - Cardiff Plumbing & Leak Detection Co. 35-years of plumbing service and repair. Go fish.
Apr 16, 2014 | Riobel PR12BNW 4 piece deck mount faucet...
The water coming out the shower jets is not powerful, help?
follow this steps and fix it. God bless you
If a faucet leaks, replace seals and gaskets .
If a shower head leaks, create a better seal or replace seals .
If a sillcock wears out, replace the washers .
If a compression faucet drips from the spout, replace the washer and/or the seat .
If a faucet leaks from the handle, replace O-ring(s), replace the packing washer, tighten the packing nut, or replace worn packing, depending on the valve type .
If a ball or cartridge faucet leaks from the collar, replace worn O-rings .
If a disk faucet leaks around the base or has reduced flow, replace cracked or pitted disk assembly or worn inlet seals .
If there is water under the sink, tighten the faucet-set locknuts under the sink. You also can replace putty or a gasket, replace a worn faucet, or replace leaky supply tubes .
If the aerator leaks around the edge, replace the washer in the aerator .
If the spray hose leaks or has reduced flow, replace the O-ring on the diverter valve, replace a worn washer at the base of the spray head, or clean the diverter valve and spray head .
Nov 25, 2013 | Home
Hansgrohe Clubmaster Kiwa head leaking from seal
For the Clubmaster shower head there is a rebuild kit available. This is part number 92027000 and is available through your local dealer or online dealer. If you need further help feel free to contact me at Hansgrohe. 1-800-334-0455 press 2 for Tech and ask for David Scarborough. I'd be happy to help.
Sep 05, 2012 | Home
My shower is leaking and i have tried a new pipe with washers what else can i do
Did you use any teflon tape on the shower arms threads to seal it up. Also check and make sure fitting on shower head isn't cracked once tighten up onto shower arm it could have a crack in it and leaks. Plastic shower heads tend to crack when they are tighten to much.
Jul 31, 2011 | Home
The shower head is leaking badly around the outside rim of the head when in use. i removed centre fixing screw and found a number of broken pieces of plastic approx.three mil. longinside the head which was...
hiya:) wish i had something better for you but i think you should just buy another shower head. even if we could find the parts, which i doubt, after shipping & handling (because you will not find the parts at the store) they would cost as much as a new shower head. not to mention your time. hope this helps and good luck:)
Jul 27, 2011 | Grohe 27069 Relexa Shower Head Shower...
I just installed a Moen Traditional 82008BRB faucet and shower. After having it installed for a day, water will drip (20 or so drops) out of the shower head every 5-10 minutes. This also occurred when I...
HELLO- Very possible that there can be dirt or solder inside, hard to determine without looking inside at the sealing points of the vavle itself. Try to determine if it is the hot or the cold side,also look at were the valve seals off ,could be small imperfection in the seal ! Good luck
May 17, 2011 | Moen & One Handle Tub & Shower Faucet
Water leaks shere showerhead joins the shower stem
when reconnecting the shower head to the pipe coming from the wall..
did you use some pipe tape, pro dope or another type of joining compound?
this seems likely to be the problem.. if you don't have any on hand, visit a hardware store and ask their staff for pipe tape for plumbing and you should be pointed into the right direction.
May 12, 2010 | Water Pik & Wallmount Showerhead
My Hans Grohe rain shower head is having a lighter spray recently. Is there a way to improve the spray force and/or clean it? Thanks, Therese Terschuren
Rain head showers are a nice thought, but they come with a bundle of problems. This is common one, though, so fear not.
As long as your regular shower head isn't losing pressure (I'm assuming that you have at least two heads instead of just one rain head) I would recommend carefully removing the head with an adjustable wrench and letting it soak in CLR (calcium lime rust) for at least an hour. Often times minerals in water will build up in the small holes on a shower head and greatly reduce efficiency.
Remember to apply teflon tape to the threads before carefully retightening the shower head to avoid spraying water from the wrong end!
Mar 25, 2009 | Home
Walk in shower leak into room below
I would unscrew shower head pipe and either pipe dope it or tefilon the threads and then reinstall it. I would also take the handle(s) rosettes off and look for a leak from there with a flashlight, while shower is on. I believe the most comon leak for walk in showers are the door seals. Are you sure it is not coming out from under the door? Another test that yuo may want to preform is to Stopper the drain, fill the shower pan with water and watch for bubbles, or look for leaks from below.
Mar 20, 2009 | Home
Feb 03, 2008 | Gaggia Classic Espresso Machine
Home Logo
143 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
