I can not get my washing machine to go. For some reason it won't go to the 59 min wash. It is on 2.17 and won't let me change it to anything else
SOURCE: samsung b1245s washing machine
The error code HE2= water heater error (The heater element did not getting hot)
Unplug the machine to reset this error.
Try different cycle let see you still getting the same error.
Posted on Jun 23, 2008
  • 132 Answers
SOURCE: whirlpool washing machine won`t spin or pump out
1-check the drain hose maybe cloged 2-check the drain filter maybe filed with materials 3- check no spin mode maybe you selected thank you
Posted on Jun 08, 2009
57 varieties
  • 1653 Answers
SOURCE: Whirlpool washing machine - F51 code
F51 - This is a motor Rotation Positioning Sensor failure. If this persists you will eventually need to call in a service engineer to repair it as the machine will eventually stop working altogether.
Posted on Oct 02, 2009
  • 330 Answers
SOURCE: Keeps pausing in the middle of wash cycle. Sits
the timer is busted getting stuck at same point their expensive as well
Posted on Jan 05, 2011
FitzOriginal
  • 842 Answers
SOURCE: bosch classixx 1200 washing machine.
Before you investigate the fault, try unplugging the machine at the mains for 20 minutes. This MAY reset the problem and all will be well. If that fails, then read on:
The flashing lights are an error code. You will see that there are a series of rapid flashes followed by a pause and then the series of flashes will be repeated, this is the error code being displayed. If you count the number of flashes being given then you use that number to correspond to the fault code, for example, three flashes would be fault code 3.
Fault Code 1 notlit.gif notlit.gif lit.gif Door open after program has been startedThis error code may well not show up for a minute or so after you actually go to start the washing machine but the door can be closed and the program restarted.
If the error persists there may be a fault with the door locking mechanism or door latch.
Fault Code 2 notlit.gif lit.gif notlit.gif Water intake has failed
Error after more than 10 minutesa failure of the water inlet valve or the water supply itself has been cut off somehow. This can be due to the water valve or supply as stated but it may also be worth checking the filters in the fill valves to ensure that they are clear.
Fault Code 3 notlit.gif lit.gif lit.gif Heating time exceeds 105 minutesThis would ordinarily indicate a fault with the water heating element or, certainly, the water heating circuit as the washing machine is indicating that it has failed to reach temperature.
The error can be caused by faulty wiring, the heater as stated, low voltage or even a calcified heater has been known to generate this error code.
Fault Code 4 lit.gif notlit.gif notlit.gif Takes longer than 6 minutes to drain.Very often you will see this error if the filter is blocked or obstructed or the drain pump is jammed or faulty.
This error code can also be caused by the pressure sensor being blocked by overfoaming from overdosing detergent or using a poor quality detergent as well as a pressure switch or sensor failure.
When this error occurs the program is aborted as it is considered to be a "fatal error" without any attempt to drain the washing machine.
Fault Code 5 lit.gif notlit.gif lit.gif NTC thermistor open circuit or short circuit
Self explanatory really, either a faulty NTC or wiring. The washing machine will complete the program but will not heat.
Fault Code 6 lit.gif lit.gif notlit.gif Unexpected heatingThe machine has attempted to heat at a stage in the program where it should not.
Fault Code 7 lit.gif lit.gif lit.gif Fault detected in motor or drive circuit
Very often you will see this error if the carbon brushes or the motor fails.
This error code can be generated by no tacho reading from the motor (the electronics cannot see the tach generator of the motor), a triac fault or short circuit or a faulty reversing relay on the control board. The washing machine will try to start the motor but after several attempts the program will be aborted with this error code which is again consider to be a "fatal"
Posted on Jul 05, 2011
REPLACE PUMP
easy
  • How to Replace a Washing Machine Water Pump: 12 Steps www.wikihow.com/Replace-a-Washing-Machine-Water-Pump
    • 4 MIN
    • 76K VIEWS
    2016-01-08 · Video embedded · How to Replace a Washing Machine Water Pump. Washing machines are durable and expensive appliances. Repairing them is often less expensive than replacing ...
  • Washer Not Draining? Washer Drain Pump Replacement (Part ... www.youtube.com/watch?v=DwV71h86Gxw
    • BY REPAIRCLINIC.COM
    • 3 MIN
    • 381K VIEWS
    2010-05-14 · This video provides step-by-step instructions for replacing the drain pump on top loading direct drive Whirlpool washing machines. The most ...
  • Geeks On Home: How to Replace a Washing Machine Drain Pump www.geeksonhome.com/how_6509829_replace-washing-machine-drain-pump... How to Replace a Washing Machine Drain Pump. Washing machines take the drudgery out of laundry day, and they're a lot easier than using a washbasin or beating ...
  • Related searches for Washing Machines replace pump
  • How To Replace The Pump in a Washing Machine - YouTube www.youtube.com/watch?v=cvyCSQMPkCc
    • BY BUYSPARES
    • 5 MIN
    • 74K VIEWS
    2011-07-13 · For all your washing machine spare parts and accessories, visit: http://bit.ly/1VKQiNZ If the pump in your washing machine is faulty or broken, ...
  • How to Replace the Pump on a Washing Machine - Bosch ' ... www.espares.co.uk/.../how-to-replace-the-pump-on-a-washing-machine- View All Washing Machine Pumps Now » How to Replace the Pump on a Washing Machine - Bosch. Is your washing machine failing to drain following a wash cycle?
  • How to Replace the Pump on a Whirlpool Washing Machine www.geeksonhome.com/...replace-pump-whirlpool-washing-machine.html How to Replace the Pump on a Whirlpool Washing Machine. The pump in a washing machine helps remove the water from the washer's tub. Water comes in through the ...
  • How to replace a washing machine pump on Aeg, Electrolux ... www.youtube.com/watch?v=yrY9R_T8qrY
    • BY HOW-2-REPAIR.COM
    • 10 MIN
    • 17K VIEWS
    2014-03-26 · How to replace a washing machine pump on Aeg, Electrolux, John Lewis, Zanussi washer dryers Please remember to mark us to your ...
  • How to change and replace a washing machine pump on ... www.how-to-repair.com > Home > Washing machines > Pumps After checking that the pump is faulty in our previous tutorials you will need to replace the old washing machine pump with a new one. Disconnect the appliance from ...
  • Whirlpool Washing Machine Pump Parts from RepairClinic.com www.repairclinic.com/.../a11b5c36/Whirlpool-Washing-Machine-Pump-Parts Shop for your Whirlpool Washing Machine Pump from our huge inventory. Return any part for any reason.
  • How to Replace Beko Washing Machine Pump www.how-to-repair.com > Home > Washing machines > Pumps This video will show you how to replace Beko washing machine pump, If your Beko washing machine is not emptying or draining the water then it is a good chance
  • Mar 10, 2016 | Washing Machines
    When I run the 59 minute wash it ends with Error E14 code, short washes end OK.
    WOW 1 cycle is 59 minutes sounds like a big waste to me .most of ours on a non computerized machine might take 30 hour total
    Jan 28, 2015 | Washing Machines
    Candy washing machine gc4 2d washes for about 15" then stops for 30" (the screen goes black) then on again for about 10" and then stops again.
    sounds like overload protection is disabling the machine. it could be caused by a lot of reasons, the only advice I have is to check for a jammed drum, empty machine and see if drum turns freely. best luck to you.
    Dec 06, 2014 | Hoover Genuine Candy Zerowatt Washing...
    Washer stays in wash cycle will not spin out i changed control board no help
    Isyour washing machine displaying an error code? If so, try using the owner's manual to decipher the code and you may beable to easily diagnose the problem. The problem could be as simple as the doorbeing slightly ajar, the machine is in pause mode, or the spin selector isstuck. Checkthe handy chart in the article Washingmachine won't advance to washer spin cycle for more possible reasons why your washingmachine won't advance to washer spin cycle-and some tricks for getting itworking again.
    Aug 01, 2012 | Electrolux Washing Machines
    I have aa frigidaire front load washer model LTF2940FE1. We put a pretty big load of towels in this morning. halfway through the cycle the machune made a couple of loud noises, like it was shaking, and...
    Never put a large load of anything in, they're quite frankly not designed to work like that for a number of reasons. If the drum is full then water can't circulate properly and your clothes won't get washed as well as they could do.
    The machine shut down to prevent damage to itself, try turning it off at the mains for 30 mins, turning it back on and then putting half the load in. This should reset it and stop the shaking.
    Jun 24, 2012 | Frigidaire ATF6000ES Front Load Washer
    How to reset Beko wmb 91242 LC? Machine won't do
    My washing machine beko WME7247W won't do anything it said C on it won't start change tem do anything can you help me
    Apr 08, 2012 | Washing Machines
    Hoover vhd sensor dry 59 minute programme not working
    "Rapid W&D 59 Min.
    When you only have a few items to wash and dry in a hurry, this 59 minute cycle is the ideal time saver! Suitable for a light 1,5 kg load size (e.g. 4 shirts) or slightly dirty fabrics, this cycle will wash, rinse, spin and dry your garments in under an hour.
    We recommend that you reduce the detergent dosage when using this programme to avoid wastage".
    If the other cycles work without issue, it in not faulty.
    Check the wash weight.
    Sep 20, 2017 | Hoover Washing Machines
    My hoover washing machine top load won't start. I have checked the power from the wire going to the timer.The door latch switch is working and still it won't start.
    my hoover washing machine do not stop they show 1 min left . i was try serval time the happend is same and inside few water as well
    May 26, 2011 | Hoover HTC243 Top Load Washer
    Washing Machines Logo
    23 people viewed this question
    Top Washing Machines Experts
