Question about Westinghouse Televison & Video
I have a Westinghouse model number 4255vx I have power in my transformer, but no power in my TV ,no light on in my power light bar at the bottom of my tv
SOURCE: Mikomi TV power pack/transformer/AC adapter replacement
Power Plus Online sell a replacement ac adapter 'PSU 1' at www.power-plus.tv we purchased one recently for £29.95 and this works fine.
Regards Steve
Posted on Dec 30, 2008
SOURCE: can't progam my direct tv remote to operate my westinghouse 32''tv
I don't have DTV anymore, so I don't remember the exact code I used for my SK-32H240S, However, I do remember that I found one that worked at this site. Scroll down to locate your remote series # - it most likely will be printed on the upper left corner of the front of the remote - as an example, mine says RC64. Click on the corresponding listing, then follow the directions on the site. I tried only a few codes before finding one that worked correctly. Good luck.
Posted on May 08, 2009
  • 92 Answers
SOURCE: westinghouse 30" lcd tv has no sound no picture,but green lighton
Replace the Power Supply.
Posted on Sep 06, 2009
pabloloco
  • 2335 Answers
SOURCE: codes for living solutions remote + westinghouse lcd tv
The codes for your Jumbo Universal Remote to control a Westinghouse television are 097, 100, 130, and 155.
To program your remote by entering a code, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Enter the first set of 3-digit codes from the list. The LED will blink once every keypress. After the 3rd digit, the red LED will turn off indicating that the code was recognized for the device. If the code was not compatible, the LED will flash several times and you need to return to step 2 to try that code again or to try the next code in the list.
  5. After the LED has turned off, aim the remote at the TV and press ON/OFF. If the device turns off, you have used the correct code and the remote was successfully programed. If the device does not power off, return to step 2 and try again with the next code in the list.
I hope that helps.
Posted on Oct 16, 2009
  • 29 Answers
SOURCE: westinghouse model tx-47f430s lcd tv wil not turn on
This is known as SLEEP MODE problem.
Simple solutions:
1. Get a power surge protector / strip.
2. Plug your TV power cord to the power surge.
3.Then turn-on your TV using the remote control. Just in case it won't go all the way to normal state.
4. Turn-off the switch of your power surge like 5 times with an interval of 3-5 seconds.
5. Then repeat step 3 and 4.
6. These step is done to over-ride the sleep mode.
Roan
Posted on Feb 18, 2010
Wondering if its my main board on my hdtv flat screen. it comes on normal for about 10 to 15 seconds then i lose video but not audio
sounds like a failing t-con board. this board is on the back of the screen controls the signals to the screen. ribbon from main board goes to the t-con board.
Jan 28, 2017 | Westinghouse Televison & Video
Westinghouse 19inch model 19h210s has picture no sound
Fix Your Westinghouse SK-19H210S Television - Instructables
www.instructables.com/.../Fix-Your-Westinghouse-SK-19H...
InstructablesI called Westinghouse and they said that I was out of luck because it was no ... on an the screen lights up an then off ?have sound but no picture after start up .
Westinghouse SK-19H210S has picture no sound - Fixya
www.fixya.com/.../t11272945-westinghouse_sk_19h210s_picture_no_s...
Jan 13, 2012 - Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board.
Oct 16, 2015 | Westinghouse Televison & Video
I have a Westinghouse LD-4255VX 42 tv and when I turn it on the screen comes on with the crown symbol and then it cuts off
Fault with main board. Damaged component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too will be necessary.
Sep 01, 2014 | Westinghouse LD-4255VX 42" Edge-lit LED...
Westinghouse LTV-37w2 HD have no picture, no sound, no blue power light on - only some buzzing. What it can be ?
if it is just buzzing then the transformer has gone, may have over heated.it transforms the line in volts down to the volts needed to run the tv. so say 240v ac in and tv needs 110v ac. now the volts in will be making the buzzing sound but the coil on the 110vac side has gone. if you change the transformer. has to be the same colour and number. tv should be fine. as the coil in the transformer brakes its just like removing the plug from the wall and not do any more damage. so just the transformer will need changing.
Oct 01, 2013 | Westinghouse LTV-37w2 HDTV
WESTINGHOUSE TV 32 IN LCD TURNS ON FINE, SECONDS
Check for cold soder joint in the 24vdc power supply section, especially on C310.
http://s807.photobucket.com/albums/yy352/budm/Westinghouse%20LTV-32W1/
The problem can also be the backlight inverter baord.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Jul 06, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Westinghouse SK 32H540S when i Turn on TV, get Westinghouse logo, picuture turn on for 2 sec then black screen.
The problem is cause by the transformer on LIPS inverter (Power supply + Inverter board). You could see an obvious burn on the 1 of these transformers ( There are total 3 black transformer on this board). The part number is 4302H. It is available online at http://www.lcdparts.net/TransformerDetail3D.aspx?ProductID=2775
May 27, 2010 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
I have a westinghouse tv model number SK-32H240S no picture
It seems that your unit has some sort of Video side, PSU fault, or a problem to the Video section that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
Jan 21, 2010 | Westinghouse SK-32H240S Television
Westinghouse lcd tv parts
HAVE A WESTINGHOUSE LTV32-6HD. HAS SOUND, NO PICTURE. APPROXIMATELY 8 MONTHS OLD
Jan 20, 2008 | Westinghouse LTV-27w7 7 in. LCD HDTV
Televison & Video Logo
16 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
