Question about kawasaki 2004 Jet Ski 1200 STX-R Base
2001 Kawasaki 1100 stx di. Had a hose hooked up to it tonight idling and reviving it up, then it started to rev up on its own for a couple of seconds. Any ideas what it might be.
    Sergeant:
  • 194 Answers
You may have leaking crank seals. If they leak they can cause air to mix with the fuel before it gets to the carb, causing the motor to rev high unexpectedly.
Posted on May 17, 2017
Hi i have a 2003 kawasaki stx 1100 di that will not tick over from cold for the first 5 minute of running then after that it will be fine the rest of the day please can any one help thankyou
Was the engine cranking over fast or slow? A low battery can cause this. Do you keep the battery on a maintenance charger like a battery tender?
Oct 06, 2016 | The Video Game Consoles & Games
My 2003 Kawasaki prairie 360 when u install the hose from the air box it will only idle u can not rev it up take the hose off and it runs fine
2003 360 Prairie 4x4 cutting out... I'm stumped! - Kawasaki ...
www.kawasakimotorcycle.org > ... > Kawasaki ATV and Mule
Dec 14, 2011 - This 360 4x4 has me stumped. ... 2003 360 Prairie 4x4 cutting out. ....It idles just fine, it has perfect throttle response, it just won't rev without ... 2006 Prairie 4x4 governor prob?
Oct 1, 2009
04 Prairie 360 Knocking when Idling and Belt Light on.
Jan 26, 2009
Older Prairie Tune Up Questions
Sep 19, 2008
Prairie 360 (Limp Mode)
Jan 4, 2005
More results from www.kawasakimotorcycle.org
Nov 19, 2015 | kawasaki Motorcycles
Need wiring diagram 4 1999 stx kawasaki
Hello there,
Cannot find free ones,
Go here and for Five of your American Dollars, you can get it.
http://www.selffixer.com/jet.ski/kawasaki/1999-kawasaki-stx-1100-wiring-diagram.htm
Sep 19, 2014 | Motorcycles
Need wiring diagram for kawasaki 1100 stx ignition
Hello there,
2001 Kawasaki ZX-12R will not idle
Hi, Snowboard117 and the usual suspects are:
1. Idle speed improperly adjusted.
2. Air fuel mixture screws not properly adjusted.
3. Inlet system air leak.
4. Leaking accelerator pump.
5. Loose low-speed jet.
6. Plugged low-speed jet.
7. Contaminated or plugged low-speed circuit.
8. Enrichner valve/choke not seated or leaking.
9. Multi carburetors out of sync and need to be balanced.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
2001 ZX12r wont idle
Plz help just got 2000 zx 12r and im little confused
Kawasaki 2000 Ninja ZX 6R Service Manual Page 2
OEM Parts for Kawasaki
Kawasaki Ninja Owners Manuals
May 28, 2017 | 2001 kawasaki ZX-12R
Jet ski bogs out under load.
I had a similar experience with that model. It turned out to be a mouse nest in the water box. However , in this case i think you just have some moisture corrosion on the rubber tipped needle in the carburetor. Clean that part of the carb and do not alter the tiny spring in any way. If that does not work open the electronics box, if it is wet , dry it out , and seal it back up. Those are the three things I know of that will cause your problem. Start with the carb.
Apr 06, 2010 | Encore Software Kawasaki Jet Ski...
Just broke its second pinion shaft i drive case at shoulder of thread first time it did it was under warranty
Sounds like tuning problems.
Yamaha cautioned on this.
First, make sure the engine remains in a good state of tune, valve clearance, carb sync, idle speed (STOCK, 1000~1100 rpms) idle mixture.
Then starting procedure, full choke no throttle when cold, do not try to rev it until the engine gets some heat in it.
Jul 24, 2009 | 2001 Yamaha V Star 1100 Classic
Kawasaki zephyr 1100 not running right
The carbs have some very tiny passages that will easily be blocked by that varnish reside. You will need to pull the carbs and flush every jet drilling with an aerosol carb cleaner like gumout Remove the jet and blow the spray cleaner through, rinsing out ant gum build up. Clean all the passages you can find and the rest of the carb linkage and bod. Idle passages are vacuum drawn and if your manifold vacumm is low then the fuel cannot be sypyphoned. to keep the engine running. Vacuum leaks are common on bikes that sit because the hoses dry up and loose thier seal. Check all you hoses and replace any in doubt. Good luc And let me know, please.- Ned
Jun 20, 2009 | 1995 kawasaki Zephyr 1100
Just bought a zrx 1100 which is from america but a uk spec bike . great condition just given it an oil and filter change as i do with any bike i buy . seems fine but never owning a kwak before i want to...
not that im a ware of  possibly could be your hose to the crank case breather is off or one of the hoses on the emissions fresh air intake under the tank  check these first
Feb 17, 2009 | 2001 kawasaki ZRX 1100 R
kawasaki 2004 Jet Ski 1200 STX-R Base Logo
43 people viewed this question
Top kawasaki Boating Experts
J.D. Browning
J.D. Browning
Fabrice Wolters
terry stevens
Are you a kawasaki Boating Expert? Answer questions, earn points and help others
