Question about Garden
Tecumseh 4.5 HP mulcher lawnmower - engine runs fast
Replaced linkage because engine would only run if choke was pushed in.
    Problem Solver:
  • 5 Answers
There are a couple things you can do to maybe make the mower run without choke being on, remove the carb, disassemble float bowl and use a bread tie to clean out the jets and tubes. while you are inside the carburetor float assy, check the nut that holds the float bowl and make sure that the small hole is open, to test this yiu can blow into the hollow of the nut and see if there is air escaping or not, this entails getting the taste of gasoline on yiur lips, but a small price to pay as oposed to a mower shop service charge. i remedied my problem with a bread tie to clean the jets(openings) some are large enough to use a small paper clip. once you are relatively sure yiu checked and cleaned all the tubes, jets, and holes, reassemble the carb and put it back on and give er a yank see what happens, you'll probably find this worked and fixed your problem,
Posted on Jul 29, 2009
I have a Murray 20 model 20213A with a Tecumseh engine. The lawnmower will start but it dies a few minutes later. What could cause this and where can I get a manual for this model lawnmower?
Use high test fuel without ethanol, and
Murray 22" Lawn Mower - Carburetor Cleaning, Nasty ...
? 7:33
www.youtube.com/watch?v=_dzcDZUh1MY
May 10, 2013 - Uploaded by mountainbikekayak But here is the link for the start up of this Murray had to replace the plug as well also ... as well: Murray 22" Lawn Mower 6.5 HP OHV -- First Start after Carburetor Cleaning - Part III - May 9, 2013 ... When I start it, it runs for 3-4 seconds and dies. ... Youcan also find you engine Model # online and view the ...
Sep 09, 2015 | Tecumseh Garden
Where can I get a diagram of carb choke and throttle linkage set up?
I bought a brand new 13 hp Tecumseh on my rider,was trouble from day one,fought it tooth and nail,finally took to shop,they put a brand new Taecumseh carb on it,couldn't get it to run,went to a dinky lawn mower shop,was told the carb was not the right one,wow,they sold me a used one that looked way different,but it worked super,so try another non-tecumseh carb or fight it forever.
Jun 07, 2015 | Garden
Engine runs on half choke
You probably have some buildup in the carburetor, because tillers are gernerally used seasonally it leaves plenty of opportunities for buildup to occur . Also, you should inspect throttle cables and linkage to insure that everything intact.
Sep 07, 2012 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Is my Craftsman Mulcher lawnmower a 4 stroke or 2 stroke engine??
It should be a 4 stroke, the only thing I can find on it is the mulcher blades, set up called a side discharge mower. It has a 5.5 HP ,22 inch, briggs and stratton engine. Hope this helps.
May 05, 2010 | Craftsman Garden
I have a 15hp tecumseh engine that will only run with the choke on.
You have a partially gummed up carburator. Get a bottle of carburator cleaner to add to your fuel. Follow those directions and you should be fine.
The alternate method may be to get a can of starter fluid. Spray the fluid into the air intake as the engine is running with the choke on. When the engine sounds better take it off of the choke status. Joe
Apr 11, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
Garden Logo
712 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
