Question about Tools & Hardware - Others
I do not know what filters I need for my rain soft ro system
  • 12,469 Answers
Search for the:
Make Model filter
or
Make Model manual
Posted on May 17, 2017
Can weco polaris uva-1c system be installed under the sink by itself?
UV water disinfection systems can be installed downstream of your already installed kitchen reverse osmosis water filter system or just by itself. US EPA states that "UV treatment is an effective process for inactivating many microbial pathogens in water with potential to serve as stand-alone treatment or in combination with other disinfectants."
Easy way is to cut the faucet tubing (blue tube) in middle and connect the UV. Wall mounts should be included inside the UV package.
However, if you already have the tiny ro system, check the diagram below and install the uv between the auto shut-off valve and the 4th stage filter (polishing filter).
To nicely fit this UV into the RO system, you'll also need two 2-1/2" X 2" double filter clips. Tubing this way should allow more contact time for water and uv rays since the flow rate from the membrane is very slow.
https://cfpub.epa.gov/si/si_public_record_report.cfm?dirEntryId=309164
Apr 12, 2018 | Option Computers & Internet
How can I connect a tiny-150 compact reverse osmosis water filter to the water supply?
Water Supply Connection uses metPure Universal EZ RO Adapter that fits both 1/2" and 3/8" supply stops.
Amazon $20.00
9mhakhhf6wzaqaagfpczwmaaadko7mbaaaa5dhzaaaagplobaaaaeb5ddyaaacgpdobaaaaub6ddqaaacjv1m7+d6jadilb3eqhaaaaaelftksuqmccaa== Express Water RO Feed Adapter Valve Quick Connect for Undersink Reverse...
Apr 06, 2018 | Plumbing
6 stage ro system under counter style will not stop draining or producing ro water at all I removed unit changed 3 pre filters and a post polisher now I gotta problem How long will this unit run to fill...
If the RO is not shutting off and there is no water from tank there are several things to check.
1. The product water tank is probably low on air. The tank may be full but no water will come out. Put enough air in tank to force out all the water then reset air pre-charge to 7psi for 3 gallon tank.
2. The capillary tube / check valve of RO system is bad. This puts back pressure on membrane to help create water.
3. The Automatic shutoff is not working, causing the unit to run constantly.
I would have to know what model RO it is to narrow down the problem further.
Depending on the Membrane production 10, 25 gpd, etc. and the TDS of water it may take 24 hrs to fill the tank.
RJ
Oct 07, 2011 | Culligan Under Sink Water Filter
I am installing a reverse osmosis system in my home and need a "dummy cartridge" part to replace the water filter that is in the refrigerator - PureSource RG-100 and how do I get it?
hello.
i know such thing exist but i am having a hard time finding a part number for it. A alternative would be to in essence bypass the ref.filter this way.
The water line on the back of the refrig where the house plumbing connects to feeds directly into the filter first then out of the filter into the water valve to be dispensed to icemaker and door dispenser.you could connect the water supply from the RO system directly to the water valve instead of connecting the RO to the inline refrig filter.
Gene
Aug 06, 2011 | Frigidaire PLHS237ZD Stainless Steel Side...
I want to unhook my reverse osmosis how do u do that and what are the steps
Here are the steps to remove your RO system. Put a pan and a couple rags under sink to catch any water that might spill.
1. Label all the lines from RO (with masking tape) to remember where they go.
2. Turn the water off to RO system
3. Run all the water from the RO tank
4. Turn the valve off on RO tank.
5. Remove the line to the RO tank and pull tank out.
6. Remove the line to the RO drain.
a. If there is an AIR GAP faucet this line may go there first
b. plug the whole for RO drain or replace the standpipe
7. Remove the product line from RO faucet
8. Remove the water line feeding the RO system.
9. Make sure the valve feeding RO is shut off completely
a. If this valve is a piercing valve you may want to consider replacing the section of copper
plumbing because it will eventually leak if left unused.
10. When re-installing the RO remove old filters, sanitize system and replace with new filters.
RJ
Nov 11, 2010 | Culligan Under Sink Water Filter
Leak at one of the fittings on my Culligan RO system
Too much pressure in holding tank will not cause leaks in the RO unit. All too much pressure in tank will do is cause low or no product water in RO tank. Older Culligan RO systems (H8, H83, H5) had fittings that used metal locking washers and these can cut the RO line after the RO has been moved around while changing filters. Newer styles (AC30, Water Tower) use quick connect fittings and the RO line may work loose after filter changes and system being moved around under sink.
Turn the incoming water off to RO, turn the water off on RO tank, open the RO faucet to relieve pressure and pull the line off feeding the RO tank, inspect (you may want to cut off a small portion of the line at the filter) check the o-ring and re-install.
RJ
Aug 01, 2010 | Culligan Under Sink Water Filter
Culligan ac 30 reverse osmosis system - changed the filters, good flow for 3 days then began diminishing. Now nothing comes out of the faucet. Holding tank is empty.
I would pull out all the filters changed and check them. If a GAC filter is used as the post filter, before the RO tank, carbon fines can come out of the filter and can plug up the head on the RO system. Make sure the sediment pre-filter is not plugged and there is plenty of water supply. You may have lost pressure in the RO tank. A 3 gallon tank should have 7psi pressure when totally empty.
RJ
Jun 20, 2010 | Culligan Under Sink Water Filter
When replacing the filters it says to put bleach in the 5 micron housing and carbon filter . do you put both filters in and add bleach to both
I prefer to clean the housings out with about a tablespoon of bleach before installing filters. TFC membranes used in almost all RO systems are susceptible to chlorine degradation. So unless you pull all the filters and sanitize the system it is NOT a good idea to add bleach to housing when installing filters. It helps to use latex gloves when changing filters to prevent bacterial contamination from your hands. This is the main reason RO systems need to be sanitized with filter changes.
RJ
Apr 02, 2010 | Culligan Under Sink Water Filter
How to sanitize ac30 culligan RO sytem?
It helps to sanitize the RO system each time you change the filters. Always test the RO water with a TDS meter to determine if the TDS rejection has dropped below 80% rejection. If it has the membrane should be changed along with the other filters. Always wear latex gloves when changing RO filters to prevent bacterial contamination. There are complete instructions on sanitizing the RO in the Culligan manual. Here is the link for the AC30 Manual.
http://www.freshwatersystems.com/support/AC-30.pdf
RJ
Dec 31, 2009 | Culligan Under Sink Water Filter
Can I remove refrigerator filter if hooked up to RO system?
its not necessary to keep the filter in place with an r/o system.
Thanks for using FixYa peyton
Feb 20, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Tools & Hardware - Others Logo
57 people viewed this question
Top Tools & Hardware - Others Experts
john h
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
