Question about Janome Sewing Machines
Have a janome 8900 bought a year ago. finding that it skips stitches a lot. Not a few stitches but anywhere from 1/8 to a inch. I have cleaned machine, change needles constantly, change threads.
  • Janome Master
  • 11,773 Answers
    Top Expert:
  • Janome Master
  • 49,277 Answers
Take it in for a service specifically the needle/ hook timing
make sure that the thread tension is correct
Posted on May 17, 2017
Janome Magnolia 7318 suddenly started making a lot of noise, sews a couple stitches then jams, bobbin thread tangles. It is clean, no lint or thread anywhere in the undercarriage.
Remove all the thread. Install a new needle. RAISE the presser foot and rethread from the beginning. Confirm it follows the correct thread path and the upper tension is set at the midway point.
If that doesn't resolve the issue, you may need to take it for service.
Jan 15, 2017 | Janome Sewing Machines
My Juki MO-655 serger will sew a few inches then the needle thread becomes disengaged in the stitch process. The machine will sew a few inches more then stops making stitches. I have cleaned the thre
Make sure you are threading the machine correctly. Make sure you are using serger thread that isn't old. Make sure you are undoing all the threads when it breaks and thread it from the beginning.
Make sure you have the right needles in their respective places. My Juki MO has two different size needles.
Sep 02, 2012 | Juki MO-655 Mechanical Sewing Machine
I think the timing is out on my janome 2039 sewing machine
It is very possible that the timing is off, which often occurs with broken needles. A common symptom is that the needle will not pick up the bobbin thread. Missed stitches aren't necessarily timing related--be sure to install brand needles often and use the correct needle for the fabric & thread you are using. Using the wrong needle will often cause skipped stitches.
What to Do If Your Sewing Machine Is Skipping Stitches
10 reasons for skipped stitches
Here What to Do if Your Sewing Machine is Skipping Stitches
Basic Maintenance Tension Skipped Stitches
You can search for sewing machine timing or take it for service.
Apr 12, 2017 | Janome Harmony 2039 Mechanical Sewing...
Skipping stitches
Rule of thumb: Fast needle, slow hands. This should help. GiGi
Feb 19, 2009 | Janome 1600P-DB Mechanical Sewing Machine
Viking is skipping some stitches when it is on zigzag
These are great machines but after 25 years there are probably a lot of problems that need to be fixed. It could be as easy as buffing or replacing your needle plate. If you take it in for service (and can actually find someone who is good with this machine) you will probably pay $200 to $400 to get it back to 'factory' state.
Jan 29, 2009 | Husqvarna Viking 1
Skipping stithes
Try practicing on a test piece before moving on to the quilt. Batik fabric is beautiful! I would check the thread size and needle. I tried quilting with invisible thread and had the same problem. The minute I changed to 50 wt.thread and a new needle the problem disappeared. I've found that 40 or 50 wt. thread works best on my Janome.
Oct 19, 2008 | Janome 1600P-DB Mechanical Sewing Machine
Janome 1600P DB Stitch length
The machine is skipping stitches and is probably out of time. Change the needle, rethread the machine and try it again. If it still skips stitches, try lowering the needle by about 1/16 inch and see if it works better. If the timing is off you should take it to a technician for a complete service.
sewman7
Jul 14, 2008 | Janome Sewing Machines
Skipped stitches
You will need to take your machine to a dealer and have it adjusted. Machines should be cleaned and serviced at least once a year. Needles should be replaced when dull. Skipping stitches can also be from using the wrong kind of needle. When quilting on cotton, use sharp needles, when sewing on knits use a ball needle. You can use a universal needle but they aren't perfect and will cause skipping on some fabrics.
Apr 26, 2008 | Janome 1600P-DB Mechanical Sewing Machine
Skipped stitches and getting worse
It might be that you have the wrong needle/ thread combination for the fabric that you are using. sharps for wovens, ball point for knits. the heavier the fabric and the thicker the thread the larger needle you need to use.
Dec 29, 2007 | Janome 4623 Mechanical Sewing Machine
Sewing Machines Logo
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
