Question about Dewalt Audio Players & Recorders
Radio Will not work plygged into 110 or with Dewalt battery. The 110 outlets on side of radio work fine?
SOURCE: dewalt dw911 radio
I had the same problem with the case not coming apart after I took the screws off, but thanks to someone posting a suggestion on this website, I was able to take it apart and take care of the problem. Use a soft mallet and use it around the seam of the radio until it pops loose.
By the way, my original problem with the radio was that it would not get any power at all, whether using the power cord, or an 18v battery. I was able to fix the problem by replacing the fuse located inside the case (250v / 1AMP)......works great now!! Many thanks to all of you who posted suggestions on this great website!!
Posted on May 03, 2009
SOURCE: when radio is plugged in only the gfi outlets work not the radio.
Mines similar, outlets work but radio will only work on battery. Radio will not work on mains only. Charger works at same time so ok. SORTED IT TONIGHT. Inside the charger inside the box there is a fuse (240v 2A) I think, tiny radio fuse. Changed that tonight and radio now works on mains only or battery. Very awkwark job but better than watching a load of cr** on tv. Hope this helps someone.
Posted on Aug 18, 2009
  • 60 Answers
SOURCE: my dewalt dw911 radio/charger works on either
More than likely your internal charger is faulty. Inside your inernal charger unit check the 2 anmp fuse which is white in colour.
Posted on Nov 28, 2009
SOURCE: Dewalt Radio won't hold presets or clock time
Replace the two AA batteries in the battery compartment.
Posted on Nov 30, 2009
  • 60 Answers
SOURCE: my dewalt radio stopped working. I plugged it in,
Check fuses inside. Check fuse and connections in plug. If this is a 110v radio there is one on transformer winding.
Posted on Dec 05, 2009
Dc011 radio works with battery but wont work when plugged in what could it be
Sounds like the mains transformer has gone. That is what reduces the mains outlet power of 110 volt to that of the batteries.
You could check the power cord though for 110 volts at the end.
Oct 31, 2015 | Dewalt DC011 AM/FM Radio
I have a Dewalt charger/radio (DC012 type 1) that was plugged into a 240v US outlet. The radio will come on with a battery in and work just fine, but with it plugged in it will not charge or play.
You burned out the AC circuit. Congratz, at least your radio still works. Use it on battery or take it to a radio technician to diagnose if it can be repaired. Presume it's worth.
DEWALT DC012 Worksite Charger Radio
Jun 25, 2015 | Dewalt DC012 Worksite Charger/Radio
Can I power a small appliance with my dewalt
This is what dewalt is saying...The Dewalt 12V/20V MAX work-site charger/radio functions as an AM/FM radio and recharges your 12V/20V Dewalt batteries (batteries not included). The 3-stage charger can recharge your batteries in as little as 1 hour, and the radio can run off 12V/20V batteries for cordless operation
  • 2 AC power outlets offer more versatility for jobsite power
  • Auxillary & USB ports allows for connection to CD, MP3, portable satellite receivers, and other digital audio devices.
  • USB port allows device to be charged via USB when radio is plugged into a wall outlet
  • Class D amplifier, woofers and tweeters provide full range of high and low sound for optimum sound quality,( hope this helps)
Aug 06, 2014 | Dewalt DCR015 MP3 AUX USB 12V/20V MAX*...
Radio works when plugged in to 110 volts but not on 12 volt battery
Check your fuses in radio. There are two of them. Sounds like the problem to me. Hope it helps.
Jul 22, 2014 | Dewalt DC011 AM/FM Radio
My dewalt radio wont turn on
i have put 2 new batteries but cant get radio 2 work
Mar 28, 2011 | Dewalt DC011 AM/FM Radio
Radio works on mains but not battery
I take it the battery has life in it ? check the connections to where the battery makes contact on the radio, your battery contacts may not be connecting to the radio or they may need cleaning. Does the radio charge the battery still ?
Oct 28, 2009 | Dewalt DC011 AM/FM Radio
Dewalt radio accidently plgged into 240 volt outlet.... Help!!!
There's a good chance they fried it if it's designed to run on a 120v circuit. The main part that turns on the LED might have handled it, but the more sensitive areas were probably overloaded. Does it work with the battery in it?
May 04, 2009 | Dewalt DC011 AM/FM Radio
Dewalt radio. no fm signal
did you try replacing AA abttery at the battery compartment.if it is still not working the display board is cappot
Apr 10, 2008 | Dewalt DC011 AM/FM Radio
Radio works off battery but charger does not work
I cam working on one and the transformers' primary winding is open. You will most likely need part # 429790-48 from Dewalt.
Dec 29, 2007 | Dewalt DC011 AM/FM Radio
Dewalt Radio
dewalt radio works fine on mains
will not work off battery
Aug 13, 2007 | Dewalt DC011 AM/FM Radio
Top Dewalt Audio Players & Recorders Experts
Gyula Lacz
Rob Beech
Are you a Dewalt Audio Player and Recorder Expert? Answer questions, earn points and help others
