My tv goes black and then comes back after a couple minutes... it does this repeatedly. i took the back out and remove dust. what can i do to fix it?
  • 556 Answers
SOURCE: Sony kdfe60a20 - The TV turns on but after a
classic Sony telling you the lamp is going bad. Replace lamp yourself it is consumer replacable.
Posted on Aug 11, 2009
maatmartin7
  • 1213 Answers
SOURCE: 47in Phillips-tv picture goes black still has
Could be the signal board has a bad cap, in this case it sounds like you are getting intermitten power to the inverters....when the tv goes down and of course you have audio....Shine a flashlight on to screen and see if you have a picture...look carefully. If this is the case..you have the above problem!
Posted on Nov 23, 2009
Raditronic
  • 196 Answers
SOURCE: 27" panasonic tv, picture blinks and goes black frecuently.
cold solder in vertical ic
Posted on Apr 24, 2010
pjbaldi
  • 8 Answers
SOURCE: dynex 32" tv picture goes black
If there is still about ? 24. Volts coming from the Power Board when it goes dark, it will be the Inverter board that needs replacing. If not, it is the Power Board that needs replacing. The Voltages should be written next to the sockets & plugs on the Power Board.
Posted on Jun 02, 2010
DrewPalmer04
  • 325 Answers
SOURCE: Screen goes black for 10 seconds and comes back on
This is a protection circuit that prevents the tv from coming on (to stop damage of the components) ....you need to check your voltages off the power supply and make sure they all read well (EX: 24v12v5v etc). Also look for popped capacitors that would make the values lower than need be for the tv to power on properly.
Once you repair the power supply then you may need to replace other components if needed (EX: backlight inverter)!
Please rate if this helps! :D
Posted on Mar 08, 2011
Testimonial: "Yes helpful, but I don't think that is something I can do myself"
L32W961 screen goes black then comes back on. later when video comes back sound does not
That is definitely a manufacturers error.
If it has been less than a year since you purchased it i would contact them.
They will send you to a service center. If it cant be fixed they will replace your tv.
It is all covered by them.
If it is past a year its honestly not worth fixing it,
You can find name brand 32 inch tv's for less than 250
while fixing it would cost around 150.
Mar 30, 2014 | Envision L32W761 32 in. LCD TV
5 yr old tv goes through cycle and tries to come on, eventually does but after many tries.
My sony did almost the exact same thing. I removed the bulb & cleaned all the dust out of the cooling ducts & the screen on the bulb was full of dust. That bought me about a month, then I replaced the bulb & haven't had a problem since(over a year ago). Just make sure you NEVER touch the glass of the new bulb with your hands,oil on your skin will greatly shorten the bulb life! I found a bulb at a local electronics store for under $200.00... don"t forget to clean dust from cooling ducts,& make sure cooling fan is working, bulb gets extremely hot!
Mar 02, 2012 | Televison & Video
LN-T4061F Goes black after a couple of minutes.
The T-Con bd is probably going bad. Also the Main bd could be bad. Have a trained samsung tech troubleshoot the set.
Jul 07, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
SONY GRAND WEGA TURNS PICTURE DISPLAY ON AND OFF
bulb is dirty remove and clean if it persists replace bulb.
Jul 05, 2009 | Sony Televison & Video
Sony kp-61hs10 tv, has sound but picture goes black after 3 min.
I just had the same problem. If your lucky it might be a free 5 minute fix. The five light flashes mean impropper current. I took the front grill off, then behind that is another black cover, I took that off and noticed the circuit boards COVERED in dust. I then took an air can duster and blew off all the dust... works like new. No more flashes and in an out picture. The collection of dust was interfereing with the electrical current.
Ben
Apr 15, 2009 | Sony KP-61HS10 61" Rear Projection...
Screen Goes Black
it sounds like your "lamp" is going out look for a hidden compartment.. or in your owners manual to see where its located its an easy fix and costs much less than a new tv
Oct 16, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
60sx12b/13k black screen
Hi, you have some poor solder connections on the sweep board, this is an inexpensive fix for any tech to do, get it soldered and enjoy, good luck & Happy Holidays
Nov 28, 2007 | Hitachi 60SX12B/13K 60" Rear Projection...
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Jul 28, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
DS27930 Screen Goes Black
There is no vertical card inside this set. Its the simple unexpensive vertical output iC. you most likly have a cold solder connectiion, on or about the flyback transformer, or video circuit in the TV set. Good Luck Please do not forget to rate this thread.
Dec 15, 2006 | Sanyo DS27930 27" TV
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
