2015 Starcraft washing machine leaks water inside on spin cycle but water still pumping out of sulage hose can't work out how to take w/machine out Thanks.
  • 1462 Answers
SOURCE: hoover washing machine top load, model 550m.5.5kg
water leak from cold hose nothing to do with other problem. tighten hose connection and fit a new hose washer overfilling probably because air chamber blocked. remove lid. you will see a pressurestat somewhere at the top - usually round with anything from 3 to 7 wires and a small tube underneath. follow hose down and it connects to the air chamber. make sure this is free of gung and check hose for splits and has no blockage. to check the pressure stat itself, attach your own hose to the stat and while machine in fill mode, blow down this hose and you should hear a click and water intake will stop
Posted on May 04, 2007
  • 240 Answers
SOURCE: Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Posted on Sep 09, 2007
SOURCE: Washer leaking water from bottom
MIne did and it was the bleach container on the top that was getting clogged and leaking over, we actually drilled the hole a bit bigger and cleaned it all out and it stopped. I've had to take the whole top of the washer off to do this about 2-3 times now.
Posted on Dec 26, 2008
  • 864 Answers
SOURCE: kenmore washing machine series 90 is leaking
Tip the washer onto the front and you will be able to see through the bottom to look for leaks.
Posted on May 31, 2009
  • 1185 Answers
SOURCE: During the final spin cycle, water is leaking inside the machine
You have a problem with the pressure switch cutting in too early before all of the water has drained away from the outer drum
There is either an obstruction in the outlet pipe or pump which is not allowing the water to discharge fast enough.
The machine is then spinning with too much water left in the outer drum added to the water which is being expelled from the clothes equals leaking
Take the hose off the back of the machine and put it in a sink , make sure it is secure and do a rinse cycle
Watch the outlet and make sure it is a strong flow if it is weak then you have probably got an item of clothing stuck in the pipe from the drum to the pump and a strip down is required
One more thing there is a small plastic bottle attached to the back of the outer drum this has tube which leads to the pressure switch
Make sure there is no congealed soap in the Air Bell as it is called
Posted on Jul 05, 2009
Water leaking on fast spin
hi Eamon.
this is what i found from the internet.
Washing machine leaks on spin Last updated on February 6th, 2017
Sometimes a washing machine leaks on spin, but not before. If this is the case, either it's going into spin with too much water inside, or something may only be leaking under the pressure and tub movement caused by spinning.
If you can see water running out of the soap drawer during spin it's probably gone into spin without pumping the water away properly. If it wasn't pumping water out at all it would not go into spin, but a partial obstruction can reduce the flow enough to allow a spin with the water unable to escape fast enough. This causes water to be forced up into the drawer or out of the steam vent at the back. If you suspect this check the last section of this article - Washer leaks from drawer
If water is coming from underneath when it spins then it's more likely to be caused by something leaking only under pressure. Check the door seal all around inside for slits and small holes, especially higher up, which may only open up and let water out when the washer is bouncing around on spin.
Other possible causes are hoses inside the machine which have small holes which open up during spin or which leak where they connect to the tub under spin conditions. These type of leaks often leave tell-tale rust or dry detergent marks. After that there could be a crack or small hole high up in the plastic outer tub which only gets exposed to water when it's forced around the tub during spin.
You are looking for something that is moving and allowing water out when the tub bounces around under load, or something high letting water out when it gets thrashed around the top half of the machine on spin. If you can't see anything obvious get a washing machine engineer
More articles about leaking washing machines Why does my washing machine leak only during the spin cycle
and if you want to read up on some more then try this link.
washing machine water leaking on fast spin cycle Google Search
Nov 23, 2017 | Washing Machines
Defy dishwasher leaks water only at the end after spin cycle
please confirm if you are referring to a dishwasher or washing machine. Usually the spin cycle applies to washing machine. Check where the water is leaking from. Most likely the drain pump hose is cracked. Need the model number of washing machine to make further suggestions.
Dec 29, 2012 | Dishwashers
Hi, our washing machine started leaking water underneath just the weekend gone. I didnot see where the water was coming from but my wife tells me that she started the washing machine as per normal as...
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occurs. Removing and Cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there is gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end. You have indicated that the spin was activated to drain off and so the drain exit seems good . Hence I would advice that you check the drain hose fittings and drain pump. Check once again to confirm if this was a program controller malfunction of the cycle. finally keep your machine in slight slant /tilt so that the water drains off fully to the exit valve.
Apr 11, 2011 | Washing Machines
Hi I have a Hotpoint Ultima 6kg WMA 76 washing machine - had for 6/7yrs. It has just started leaking water from the drawer when it changes from the wash cycle to the spin cycle...have given the drawer and...
You need to check the pump filter, and clean same.
Remove lower rear cover, locate and remove large black hose, remove and clean filter inside hose.
Please rate my solutioon.
Jul 26, 2009 | Washing Machines
Leaking washing machine
Jan, if your pump needs to be replaced, I haven't seen a step by step instruction on it so far, so I hope this will do. First Unplug the machine and remove the remaining water from inside of it.(even after the spin cycle, water remains inside the bottom of the tub, the pump and the drain hose) The easiest way to do this is using a wet /dry vac, attaching it to the end of the drain hose that goes into the wall and sucking the remaining water out. Next pull the unit forward and tilt the top of it back about 45 degrees. (when you have it tipped back far enough, the top will rest against the wall behind the machine instead of tipping forward) Remove the belt from the pulleys underneath the machine. Remove the 3 bolts holding the pump to the base of the machine. Use a pair or pliers or channel locks to remove the clamps on the hoses attached to the pump. Install the replacment pump you've purchased from a local appliance parts sttore or bought from the manufactures web site on line by reversing the process. Run a quick fill/ spinto make sure you have no leaks.
May 20, 2008 | Amana ALW540RA Top Load Washer
Water leaks and spin cycle not working properly
Water leaking from the bottom usually indicates either a bad hose , bad hose connection to the pump or a leaking pump. Also sounds like the machine is not spinning out. Is there water left in the tub at the end of the cycle?
Feb 28, 2008 | Maytag MAV7600 Top Load Washer
Water leaks (drips ) into tub after cycle/spin is complete
You have a bad pressure switch or the small hose connecting to the pressure switch may be bad
If the washer leaks water when is filling only, check the following: 1.Fill hoses
2.The water mixing valve
3.Filling injector ( If your washer uses one )
4.Filling spout
If the washing machine leaks during the wash cycle, check the following:
1.The pump
2.The tub stem & seal
3.Tub to pump hose
4.The drain hose
5.Tub (rusted holes)
6.The drum support bolts
If the washing machine leaks during the spin cycle, check the following:
1.The drain hose
2.The tub cover seal
3.The pump
4.The pump hoses
5.The stem & seal
Feb 10, 2008 | Maytag LAT2300 Top Load Washer
Miele washing machine model W713 front load - issues
If it is leaking from the waste pump area it may be blocked by a small piece of clothing like a sock or something similar! This will also cause it to take too long to complete a cycle. Remove the rubber hose onto the waste pump and check inside the hose and the pump, make sure the pump spins freely and that nothing is stuck in the hose pipes leading to the pump
Sep 13, 2007 | Washing Machines
Machine stops in Rinse & Spin Cycle & leaks water
Hotpoint WF430 Front Load Washer This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
May 24, 2007 | Hotpoint WF430 Front Load Washer
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
