Question about The Computers & Internet
How do i fix a posible fryed system on my fujifilm fine pix camera
I plugged a wrong cord it in to the ac unit charger
SOURCE: Fuji Fine Pix Z5 battery won't charge
I had the same problem!! Try flipping the battery around and then charging it. It worked for me! Hope this helps!
Posted on Sep 26, 2008
I looked up this question with the same problem and while the battery was placed in with the right side in, the three metal tabs weren't on the right side with the three metal chargers- so I had to spin it around the other way...i hope i'm explaining this right...now it's charging! I am so glad. This camera is excellent.
  • 52 Answers
SOURCE: I need to replace the 120 volt AC wall adaptor
Here is your link to buy it.
http://www.centurytool.net/5140044_04_Charger_W_Small_Jack_p/5140044-04.htm
Posted on Jan 11, 2009
  • 127 Answers
SOURCE: coleman rooftop a/c unit is fried? i plugged my
If there Air Conditioner is wall thermostat controlled, then take the front cover off the thermostat and check the fuse. If the fuse is ok, then take the inside cover of the AC down and pull down the control box that is mounted in the intake section of the AC. It is held on with two wing nuts. Remove the cover and observe the relays and the incoming AC wiring. Make sure that none of this is burnt. If all looks ok, turn power on and turn the thermostat to High Cool and check if you can hear the relay click inside the control unit. If not, then check to see if the thermostat has 12V going to it. Start there and see how that goes.
If it is controlled by the ceiling mount t-stat and selector switch. Remove the inner shroud and check the incoming AC wires for OK. If they look ok then check the selector switch and the thermostat.
The Refer has protection from this. Depending on which refer you have (Dometic or Norcold), the process is a tad different. If it is a dometic, go to the outside of the coach and remove the access panel on the rear of the refer. Remove the black cover from the control board (lower left side) and check to make sure that the 120V fuse is good (You will need an ohmmeter to check). If it is fine the check to see if you have power going into the 12V block at the very bottom, rear of the refer. If there is 12V there, then check the plug that the Refer is plugged into for 120V. If none, check the GFCI circuit in either the bathroom of the kitchen. If tripped you will have no power to fridge. Start there and then we will move forward.
Basic same checks for a norcold, board is harder to remove as you have remove wires. Mark and remember where they go.
Hope this helps,
Jeff
Posted on Jun 30, 2009
Partstore
  • 34 Answers
SOURCE: Misplaced Panasocic SDR-H60P AC adaptor
part number K2CA2CA00029 , can be ordered at http://www.partstore.com/
Posted on Jul 23, 2009
I plugged the wrong cord it in to the ac plug and now it only works when it is pluged im to the wall. if i can fix it how please anwser soon.
I think you fried the internal charging circuit and or the battery. You may have to replace it or try for repair shop.
May 17, 2017 | FUJIFILM Cameras
Can't insert 8GB fujifilm card into Fujifilm fine pix A330
The A330 uses xD Picture Cards, which top out at 2GB. Your 8GB card is some other type (most likely SDHC) which will not work in the A330.
Oct 25, 2012 | FUJIFILM Cameras
Fujifilm fine pix f20
There is software you can purchase in an attempt to retrieve your photo's go to www.ebay.com Type: picture recovery a list of sellers will pop up to give choices, also check www.download.com and type same notation.
Apr 22, 2012 | Fuji FinePix F20 Digital Camera
I paid for a manual for a fujifilm fine pix a820 & received the wrong manual. This camera is for a B D gift. I need the manual ASAP.
You can download the manual here for free.
Have you tried contacting the vendor who sent you the wrong manual?
Oct 25, 2011 | Cameras
I have a fujifilm digital camera its a finepixv10 i plugged the wrong charger into it now it will not turn on , can you help ?
As you have used wrong charger so you have to see if the problem is withe the camera or FUJIFILM FinePix V10 Zoom battery, Or if the battery haven't been charged by the charger, so the power is empty and you can't turn on camera, Then use a right FinePix V10 Zoom battery charger..
Apr 26, 2011 | Cameras
Re: Battery Charger BC-45W I just purchased a Fuji JZ500 and the battery needed to be charged. When I plugged the charger into the power outlet, the indicator light (yellow) turned on but after a few...
Ok all mine had the same problem however problem has been solved! The power cord that plugs into the charger is a common cord you may have laying around the house. I switched the power cord to my charger and the dreaded blinking stopped! Its just a bad power cord to the charging unit! Hope this helps!
Dec 23, 2010 | FUJIFILM BC45W Rapid Travel Battery...
Fujifilm S1500. Batter compart doesn't close
If you can't return the camera for service, my advice would be to close the battery compartment with tape. Not pretty but better than buying a new camera, I've done it a few times on old cameras and apart from cosmetics, works fine. Just make sure to use enough tape so the batteries won't fly out when using it.
Jul 14, 2010 | Pix FUJIFILM Fine S1500fd Digital Camera
Fine Pix software installation cd
Just go to the FujiFilm website. All the downloads are available there. Download and install.
Jul 22, 2009 | Cameras
Need printout of manual for Fuji FINEPIX S800 digital camera
You can download one from http://www.fujifilm.com/support/digital_cameras/manuals/ and print it out yourself.
Jun 11, 2009 | Pix FUJIFILM Fine S1500fd Digital Camera
Computers & Internet Logo
24 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
