Question about Hampton Bay 52 In. White Redington III¿ Ceiling Fan w/ Remote Control & Light Kit
I have 2 issues: (1) remote does not seem to operate fan or lights (speed or dimmer); (2). with wall switch, fan goes on but lights do not. I am more concerned with item (2) at this point.
SOURCE: Hampton Bay Ceiling Fan At Slow Speed
I recently replaced my hampton bay fan for the same reason (slow at all speeds) and discovered scorched and melted capacitors and wiring inside the fan. My suggestion is to stop using fan and replace immediately.
Posted on May 11, 2008
  • 157 Answers
SOURCE: hampton bay fan, wall mount remote control
Hello burrow31. There maybe a switch located on the fan stating 'remote/manual'. Check your manual. Remove the battiers in your remote and short out the battery contact terminals. Reinstall the battiers, start the fan and after fan has reached set speed press & hold fan speed button for one second. Still no speed change contact the Mgfr. with model & serial #.
Posted on Oct 13, 2008
  • 2002 Answers
SOURCE: remote controlled ceiling fan
unplug the fan then remove the batteries from the remote then plug the fan back in and, reinstall the batteries; this resets the fan control
Posted on Apr 22, 2009
SOURCE: Hamilton Bay Remote Control Ceiling Fan
Rempte light comes on but does not activate fan or light?? thanks
  • 1617 Answers
SOURCE: Hampton Bay Classic Collection 52" remote ceiling light/fan
The wall switch has to be on for the remote to work. You should only be using the remote.
Posted on Jun 20, 2016
Open Question I have installed a ceiling fan and have run the wires to a wall switch that also has only one black wire and one white wire. How do you wire to a double switch
Trust Me ...I am an electrician. There is no way (legally) to do what you want to do with the wiring that exists. One of two things can happen at this point...1) rewire the switch leg with 3 wire cable (Type NM-B aka Romex with 3 conductors + ground). This involves some skill and maybe some drywall repair. OR 2) buy a remote control for your ceiling fan. They sell them at most home improvement stores, and they install fairly easily in the motor housing of your ceiling fan. The transmitter runs off of batteries, and doesn't require special wiring to operate. Your wall switch will have to remain ON for you to operate, but the remote can handle the rest, like dimming your lights and fan speed control. Good luck!
Apr 22, 2015 | Electrical Supplies
Hunter fan remote bypass
This fan uses a "ballast" to run the fan. The ballast (part #272) probably contains wiring for multiple speeds. Here is a manual that discusses the wiring-
To use a wall mounted fan dimmer, you need to identify the high speed wires and connect them to the dimmer switch. This method will bypass the other speed windings and is not as power efficient.
Jan 31, 2014 | Hunter 21617 Palermo Brushed Nickel...
I have a harbor breeze ceiling fan on a dimmer
You have 3 options. You can connect the fan blue and the fan black to the red ceiling wire. Then you will need to control the fan and light with the strings. The wall switch will turn off everything. Option 2 is make sure that there is a switch wired to the black ceiling wire. If there is a switch I would check to make sure the switch is working. Option 3 is to purchase a remote control unit for both and leave the wall switch to shutoff the whole unit. Hope this helps.
Oct 11, 2013 | Speed Ceiling Fan 3-speed Switch By...
Dimmer not working but the light does come on.
What kind of wall switch do you have? Is it a remote wall switch? You can't use a basic Fan/light control with a remote.
Jun 03, 2013 | Hampton Bay AC414-LRU 52'' Kemper...
Minka aire concpet 1 ceiling fan issue
Ceiling fans have tiny "brains" that get fuddled when one tries to combine remote control and wall switches/pull chains. If you want to be able to use remote control, redo the installation omitting the other switches.
May 30, 2017 | Minka (F517ORB) Ceiling Fan
We want to use a 3 way-speed wall switch instead of using the remote control. Is this possible? If so, what three way switch do you recommend?
That is easy, yes there is no reason why you cannot convert this to a Three way switch. ANY Three Way switch that is rated for mains use will be OK. They are all much of a muchness, IE: All more or less the same. Go to your local electrical depot, and ask for a Three Way mains switch, wire it up, and you'll be good to go.a184221.gif
A very rough drawing of how to do it.
Mar 30, 2010 | Casa Vieja Dryers
My new fan with light fixture is hooked up but it only works through the pull strings not from my wall dimmer. Can someone please tell me why and what do I need to do to have it work from the wall dimmer....
It depends if the fan and lights are ran for separate control. If only one power line is ran from the fan to the switch location than you are out of luck. You should install a switch instead of a dimmer because a fan is not designed to work with a dimmer. A dimmer works by rapidly turning the power on and off faster than our eyes can detect creating a dimming effect for lights. This is not good for your fan. The strength of the fan speed will be limited by the dimming/power output of the light dimmer.
Nov 21, 2009 | Universal Remote Control Hampton Bay...
Control fan/light separately, with only two wires
They are available at Home Depot and Lowes. Hunter makes a wall mounter dimmer that will control the lights and fan speed separately. There is a receiving unit that mounts above the fan to the house wires on one side and the others connect to the fan.
The two hots you mentioned should be a black one and a blue one. The blue is for the lights; the black the fan. Ground everything you can to boxes, etc, if the house is only a two wire system without a ground.
I believe that remote wall switch and receiver runs close to $40.
Apr 22, 2009 | Slider Lutron: Dual Fan Control / Light...
The Hampton Bay Altura Ceiling fan functions only with remote.
I contacted the manufacturer ( after my Altura fan would run on high speed only and the remote would not control any thing. They said their was a manufacturing defect with a capacitor that affected many of the Altura fans. We are now on a waiting list for a new capacitor and housing, because they did not have enough replacement parts.
Nov 26, 2008 | Hampton Bay 52 In. White Redington...
Hampton Bay 52 In. White Redington III¿ Ceiling Fan w/ Remote Control & Light Kit Logo
29 people viewed this question
Top Hampton Bay Dryers Experts
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
