Question about Polaris Pool & Spa
Polaris 65 vacuum above ground pool, just go on circle
Our Polaris 65 for above ground pool just go on circle . Pls help.
    Top Expert:
  • Polaris Master
  • 7,915 Answers
Thruster points at 11:00
Posted on Sep 16, 2017
  • 17 Answers
SOURCE: my hayward phantom pool vacuum runs in circles at
You need to replace the feet. They wear out.
Posted on Jun 28, 2009
  • 10 Answers
SOURCE: Polaris moves in circles
Check the football looking ballast float on the back of the cleaner. You want make sure it has no water inside of it. You can pull it off and shake it next to your ear. Link to Head Float.
Posted on Nov 03, 2009
  • 12 Answers
SOURCE: How do I hook up an aqua chem pool vacuum for an
i need to know the same thing,I hooked everything up as it looked right but no suction?I hooked the 1-1/4 hose to the vinyl liner vac. head then hooked the other end to my intake hole wich sucks into my filter,but i notice the filter water is not circulating properly,the filter itself is drained of water? will this burn it out or what?
Posted on Jan 27, 2010
jharwell668
  • 640 Answers
SOURCE: My pool vacuum just goes in circles and my other
With these automatic pool cleaners, if they are going in circles, it could be one of a few problems. First, your water flow might be functioning incorrectly. Check the water flow gauge and make sure that is coming out evenly. Adjust if necessary. Also, make sure that you do not have a worn shoe or wing on one side of the cleaner. Also, make sure the navigator throat is not obstructed on one side. The same problems could be preventing it from climbing, but for that problem, you will also want to check that the hose is not too short and that the tension in the rear flap is correct.
Posted on Jul 29, 2010
SOURCE: My Polaris 3900 Sport Pool
I had a similar issue. When I lifted the unit out of the water while it was operating only the single wheel was rotating. I turned it off and removed the bag and hose. I flipped it over on a workbench and unscrewed the three recessing screws securing the base plate. Once the plate was removed I noticed the metal chain driving the two wheels had come off on the far side of the inner sprocket. I worked the chain back onto the sprocket and tested it by rotating the single wheel and verifying the other two wheels rotated. After reassembly I put the unit back in the pool and it drove straight and high on the sides. Hope this helps someone :-)
Posted on Nov 25, 2012
Why on a polaris 380 would water pour out of pressure relief valve and not make it to vacuum
check inline filter or check to see if hose is collapled sometimes the bend where they go into the polaris
Jul 12, 2014 | Polaris 380 In Ground Pool Cleaner
Polaris 340 goes in circles
make sure output of unit is aimed at 11:00
Apr 10, 2014 | Polaris 380 In Ground Pool Cleaner
Hayward great white just spins in circles
Could you clarify the exact model? The picture shows a Polaris 380, and the Great White is built by Sta-Rite/ Pentair,(now sold under the name Kreepy Krauly), not Hayward.
Confused yet? Don't feel bad, I am too!
Sep 15, 2013 | Polaris 380 In Ground Pool Cleaner
I have a polaris pool pump which is 5 yrs old and dead. Since general pool pumps of the same horsepower are much cheaper I would like to know if you can substitute a normal pool pump in place of th polaris...
I don't see why not, unless your trying to get above 40psi. I would focus on the pumps flow rate, that will give you a better stance on how closely the pumps relate.
Apr 11, 2013 | Polaris 280 In - Ground Pool Cleaner with...
WHAT AND HOW DO YOU VACUUM INTEX ABOVE GROUND SALT WATER POOL
I used the manual vacuum that came with the pool during the summer because I actually got in the pool and vacuumed), but ultimately, now that it is cold, I went to the pool store and bought a much bigger vacuum (that still hooks up to the water hose) and then a longer pole. It's just too darn cold to get in the water during the winter. :-) Hope this helps!
Nov 02, 2012 | Intex Automatic Salt Water System for ...
Machine keeps going around in circles jet at back is going straight back?
Few different things can cause this. Wheel bearings can be bad, tires worn, teeth on gears inside wheels stripped or broken, or the teeth on drive shaft worn or broken. Low pressure or clogged line can also cause to run sparatic, but not necessarily in circles. Most likely problem is with bearings, or wheels. Check these closely for problems. Most pool stores with check it and replace parts (that you purchase) for free.
Sep 21, 2010 | Polaris 380 In Ground Pool Cleaner
Jul 05, 2009 | Polaris 380 In Ground Pool Cleaner
Pool & Spa Logo
198 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
David Spradling
David Spradling
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
