Question about GE Dishwashers
I have a GE dishwasher Model #CDT765SSF1SS the control panel on the left hand side that displays the information that's going on with the dishwasher the screen is blue doesn't show wording. Help
SOURCE: GE Max dishwasher no lights on panel
I have the same problem and actually found a workaround by mistake you may try as a temporary solution (if that works for you):
- press and hold the lock button for a couple of seconds
(the delay timer would increase by 1 hour)
- press and hold the lock button again
- repeat until it reaches 9hrs
- repeat one more time: the control panel should be functionnal again.
Let me know if that worked for you!
Posted on Mar 22, 2008
marked
  • 6487 Answers
SOURCE: unlock apex tv model # AT2702
  • If you have a blank screen with a red key on the bottom left, simply press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired.
  • If your TV asks for a 4-digit code or password please enter 3308 or 6688 to unlock the screen or reset any preset rating levels.
  • If you have a GT2011J or GT2011S Television, hold the (Display) button for 10 seconds, it will unlock the screen. If password or code is requested, try 3308 or 6688.
Hope that helps..........
Posted on Jul 20, 2008
SOURCE: MY CONTROLS ARE LOCKED
Press and hold the End of Cycle button for 3 seconds.
Posted on Nov 06, 2008
SOURCE: front door panel, stainless for GE dishwasher
Ebay has a guy selling stainless panels, cut to size; search dishwasher stainless panel
Posted on Nov 11, 2008
SOURCE: Leak from a De Dietrich
Pull the built in unit out and tilt towards the rear right leg and the water will drain on to the floor. The Dishwasher then restarts but the anti flood sensor will reactivate after 2-3 more washes. Do not know final fix yet.
Posted on Feb 09, 2009
Dishwasher door will not close dishwasher come on with door open.
Good Morning Garthraie, thanks for your post!
I see that the door on your Frigidaire dishwasher appears to be locked and will not close. Could you please advise if the control panel has any lights lit up on it? Also, may I have the model number of your dishwasher? You can locate the serial tag (which lists your model number) on the inside left hand wall of your dishwasher. With this additional information I would be able to assist you further. -Matt
Apr 12, 2016 | Frigidaire Dishwashers
Why can't I get the lights to go on to start it?
Hello Vanessa, thanks for your submission!
I understand that you are unable to operate your Electrolux dishwasher and the lock symbol on your control panel is on. This means that your dishwasher control has been locked and you would need to disable it in order to start the dishwasher. If you could provide me with your model number I can explain how to disable the control lock. You can locate the serial tag (which lists your model number) on the inside left hand wall of the dishwasher. With that information I can assist you further. -Matt
Apr 10, 2016 | Electrolux Dishwashers
Frigidaire dishwasher has blinking codes. we replaced the main control panel and the pump is and heating element are good What next?
Thank you for your inquiry, Geri!
From the information you have provided your Frigidaire dishwasher is blinking codes and you have replaced the control panel. What lights are blinking on your dishwasher? Could you provide me with your model number please? The model number can be found on the serial tag which is located on the inside left hand tub wall. With that information I would be able to assist you further. -Matt
Mar 07, 2015 | Frigidaire Dishwashers
Leaking around heating element posts that protrude through dishwasher body
Some dishwashers like your model number are under recall for a potential fire hazard due to water leaking through the heating element posts onto the wiring.
Your serial number must begin with the 2 letters listed . Below is the list of recall serial numbers: FL, GL, HL, LL, ML, VL, ZL, AM, DM, FM, GM, HM, LM, MM, RM, SM, TM, VM, ZM, AR, DR, FR, GR
Call the phone # below or check out GE recall website. What GE does is replace the element and gaskets, unless there is burnt or arcing visible on the wires, they may replace the dishwasher.
www.geappliances.com/products/recall
GE has determined that an electrical failure in the dishwasher's heating element can pose a fire hazard. GE will provide a free repair to all consumers with units affected by the recall. We ask that you not use your dishwasher until it is repaired and to disconnect the electric supply by shutting off the fuse or circuit breaker controlling it and inform all users of the dishwasher about the risk of fire.
Consumers who instead wish to replace their dishwasher with a new model can receive a rebate towards the purchase of certain new GE and Profile brand dishwashers. Consumers can use a rebate of $75 for the purchase of certain GE front-control plastic tub dishwashers, or a GE rebate of $100 for the purchase of certain GE front-control stainless tub dishwashers or GE Profile top control dishwashers. See the rebate form for eligible models.
GE is aware of 15 reports of dishwasher heating element failures, seven of which resulted in fire and smoke damage beyond the unit. No injuries have been reported.
The model and serial numbers are important, as not all dishwashers are included in the recall. Look at the inside on the front left side of the dishwasher tub to find the model and serial number.
This recall is being conducted in cooperation with the U.S. Consumer Product Safety Commission, which will also monitor the effectiveness of the recall program.
Recall Hotline
866-918-8760
Monday through Friday, 8 a.m. - 5 p.m. ET.
Before calling, have the model and serial numbers on hand.
Customer Care
Apr 21, 2014 | General Electric Adora GHDA670N Built-in...
Smelly water in the Dishwasher to coil if not
if you're not using the d.w. for a couple of days and water is still coming into the d.w. you have a bad water valve on the bottom left hand side of the d.w..the valve isn't closing all the way allowing water to enter the d.w. even when it's not in use.you can try shutting off the water valve under the sink and see if this stops the water from going into the dishwasher,if it does then you definetly know it's a bad water valve on the d.w.let me know what you find
Jul 24, 2010 | GE 24 in. PDW7880JSS Built-in Dishwasher
I have a GE Profile Dishwasher... it's about 5 years old (Model # PDW7880J03SS). It has a front control panel. This morning, only half of the lighted buttons work. The left side does not. I have hit the...
I have a GE profile model number pdw8200jbb . Only two lights appear on the touch panel. The stay on for a little while after opening and closing the door and then go off. Any suggestions
Jun 27, 2010 | GE 24 in. GSD4320Z Built-in Dishwasher
WR55X10415 on GE None of the panel lights are on. no water no ice
Before you go too far lets check the wiring harness. Your model is a Profile or Artica and model number? I would not buy anything until I traced out the wiring. You may have plulled the pinplug at lower left hand of door near floor and behind kick plate. Sea Breeze
Mar 20, 2010 | GE Refrigerators
Replace GE ice dispenser damper door on GE model PSI23sgna
take both hands and place on the front bottom edge of control panel pull up and out it is hard and you think you are going to break something but you are not when you get the control panel off there will be 4 screws at each corner undo them and slide that piece off then you can see your door
Aug 30, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile dishwasher GSD4930X88WW will not start C3 error code
The wiring diagram for GE dishwashers is usually found under the dishwasher, take the bottom panel off, then look for a envelope about 3"x5" up against the bottom side of the floor of the dishwasher, right under/behind the front edge. If its not there it makes servicing it tougher. C3 code means the drain sensor is not functioning, C7 code means the temperature sensor is not functioning.
As to the voltages used, I would only know that by looking at the wiring diagram (which I do not have).
Jan 14, 2008 | GE GSD3800G - Multiple Color Built-in...
Dishwashers Logo
49 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
