Picture failtly visible, audio good - Televison & Video
TV has sound but no picture
The Audio and Video are two separate components and operate independently of each other. Therefore: The Video portion requires technical repair by a technician with the proper test equipment.
Jan 31, 2018 | Televison & Video
Code for grundig delphin X 250 MP3 lost code because battery failt.
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
Sep 15, 2014 | Televison & Video
Turn my plasma has audio but the picture is not visible black
A LCD may have backlights but Plasma sets do not for the most part.
If backlight does not come on--no voltage reaching it, not being turned on by the set, or backlight is bad.
May 28, 2012 | Polaroid FLM-1512 15 in. LCD Television
White vertical lines on screen. Unable to see pictures
check your graphics card connection to the motherboard when turned off. Try to install new drivers for the correct card. All else failts try a different monitor with same graphics card. If that doesn't work you know it's your graphics card. If it works fine, somethings up with the monitor itself.
Oct 20, 2009 | Apple iMac G4 Desktop
Picture is suddenly snowy - hardly visible
Try cleaning the Head with Servisol Video 40 available from Maplin or Radio Shack or other stores. They even have it on Amazon.
Oct 13, 2009 | RCA VR706HF VHS VCR
Toshiba 35A44
check the verticle stage
electrolitic capacitors
and the verticle IC
Sep 04, 2008 | Toshiba 35A44 35" TV
Turns on but no picture or sound.
please check the connection wire/cable that gives power to your tv. if no fuses are blown. it may be a capacitor problem.
Mar 30, 2008 | Philips 50P8341 50" Rear Projection...
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
