Question about Golf
Hello, I own a Precedent Golf Cart 2008 and while connecting new speaker wires some loose wires connected and shorted out.
I found two fuses and they were ok Are they more fuses someplace else ?
  • 100 Answers
There is a fuse by the controller. Not easy to get to. Either pull the two screws holding the silver plate down behind the batteries or go up underneath the cart and move aside the plastic shield to get to it.
Posted on May 22, 2017
4 Suggested Answers
voodoomox
  • 1689 Answers
SOURCE: wiring diagram
dave, the link below contains electric golf carts wiring diagram, one here is almost the same with your 08 Precedent like the one below.
good luck
Wiring diagram
Posted on Jul 24, 2008
  • 146 Answers
SOURCE: bxr1121 woofer not working connections
if you hook one of the other speakers to the wire for the woofer does the speaker work?
if so it is bad woofer
if not wiring is no good
there might be a circuit breaker that you push in on the on off switch or in other place
make sure if you are using speaker level connection that you are putting it in right place
it should be a line level input if this is a powered sub woofer
also there might be a volume control on sub also
be more specific on connections and where they are coming from if you need more help next time
good luck
Posted on Mar 12, 2011
skychief2001
  • 21873 Answers
SOURCE: I have an ezgo electric golf cart and I have now replaced the 60 amp link fuse that connects to the battery and black wire. When driving the golf cart just quits and when checking the fuse is blow. Th
This is not a car question, but generally speaking a fuse blows when the current in the circuit exceeds the limit of the fuse.
I would look at the amp draw of the motor if that is what runs on that circuit and also the connections. It could be that the motor brushes are wearing out and the motor is pulling too much current.
I'm somewhat lost on your description - - you say it is a 60amp fuseable link but you bought 20 amp fuses. Are you dealing with two different circuits ?
Posted on Jul 24, 2012
My 2009 tomberlin golf cart the lights, horn,turn signals are not working. Every time you put a fuse in it blows instantly
You have a dead short somewhere. Look for insulation off the wires, check to see if all connectors are not touching with space between. Make sure all is clean an look for burn wires an connectors, once I found a dead insect shorting out the connectors.
May 29, 2017 | Golf
2008 Yamaha golf cart what drive does it have
It is either gas and has a gas tank or it is electric and has 4 x 12 volt batteries. Search Results
Owners Manual Download - Yamaha Golf Car
https://www.yamahagolfcar.com/ownersmanualdownload/ You can find them on the Yamaha Golf Car Owner's Manual section of the site. ... If you have a service related question, please contact your authorized Yamaha ...
Find Your Model/Serial Number - Yamaha Golf Car
https://www.yamahagolfcar.com/findyourmodel/
This overview page connects you with the resources of Yamaha Golf Cars dedicated to keeping your ... Follow the steps below to get information on services.
What Year & Model Is My Yamaha Golf Cart? ' GolfCartGarage.com
https://www.golfcartgarage.com/what-year-is-my-yamaha-golf-cart/
This guide will help you determine the year and model of your Yamaha golf cart. ... If the serial number begins with "JW9-300101" you have a 2013 Yamaha DRIVE. ... 2008. JW2-000101. YDREE. 2007. YDREPT (The DRIVE PTV). Beginning ...
Yamaha DRIVE Gas - Specs and Features - Golf Carts and NEVs
golf-carts.axlegeeks.com/l/7/Yamaha-DRIVE-Gas
The DRIVE by Yamaha is a gas powered specialty vehicle that can hold at most two ... The cart has a peak power output of 11.4 horsepower, 0% more than the ...
Yamaha G14 Golf Cart Specs ' Yamaha Year & Model Guide ...
www.performancepluscarts.com/yamaha-year-guide/
Need golf cart parts for your Yamaha golf cart, but don't know the year or model? Visit our website to ... Yamaha Serial Numbers will indicate the year of production. View the .... The Yamaha Drive is the newest addition the the Yamaha Golf Car line and began production in 2007. ... JW1-100101 = 2008 JW2-100101 = 2008.
2008 Yamaha golf cart what drive does it have Google Search
Mar 22, 2017 | Golf
How to fix accelerator that doesn't come back off. When you push on it you have to pull it back off. On cub car golf cart.
Probably a broken return spring or just corrosion. You would have to get under the cart to see if this is the DS model. If it's the precedent model, It is one unit in the floorboard.
Mar 18, 2017 | Golf
I have a 2002 gas powered golf cart that won't start or run new battery it is a ez go txt
You definitely have an electrical problem hard to answer with little details here's a start check switch,all wiring connections for loose / broke wires and or rusty connections use a multimeter helps a lot of guess work good luck maybe there are fuses too
Aug 26, 2014 | Cars & Trucks
After installing six new 6V batteries in series on my 1999 Yamaha G16E golf cart, full power is fine up to the selenoid. nopower to the shifter or motor after that. Upon plugging in my charger to the cart,...
Verify series battery wiring. The main positive wire which goes to the solenoid should be on a positive battery post, that will be your main positive. Then from there we go series to all the rest of the batteries until we are left with a negative battery post, that will be your main negative. Make sure your charger wires are connected to the mains.
Sep 11, 2017 | RHOX Yamaha G14, G16, G19 Golf Cart 6"...
Club car brake light not working
2008 precedenmt golf cart dash light keep coming off an on
Mar 02, 2013 | Power Equipment Solutions 2002 Club Car DS...
I recently bought a 2006 club car precedent golf cart and can't find a service manual for it. Can you help? I need to add a light kit and do some other repairs
Hello! Go to; www.golfcartcatalog.com...
In the upper left side of page search for...service manuals.
Guru.................saailer
Dec 23, 2009 | Sport & Outdoor - Others
Club Cart Golf Cart Reverse only
You don't have it connected right. The DC motor is 'polarity reversed' to change direction. That's what the controller does is reverse the polarity to the motor to change direction. If the motor is still working in reverse, then the controller is 'probably' okay. Recheck the connections you made.
Sep 03, 2009 | 3d Rose Londons Times Funny Cow Cartoons -...
Wiring diagram
good luck
Wiring diagram
Jul 24, 2008 | Car Audio & Video
Golf Logo
47 people viewed this question
Top Golf Experts
FastHarley
FastHarley
ray gallant
Ronald Prier
Are you a Golf Expert? Answer questions, earn points and help others
