Question about Clarion Computers & Internet
HELLO HOW DO I GET MY CLARION NX711 WORKING AGAIN IT DISPLAYSID-ODE:11100110 NAVE-1:203 SET:QV7120AW NAVI-2: SNO:00029425 E-NO:00000080 BOOT:IP 006:BS006: ET006:EH 006
Change japanese to english on clarion NX308
I learned this trick a few months ago and it is worth gold!
Get a smartphone with Google Translator on it, borrow one if you have to. Use the camera feature in Google Translator and point it at the screen. Magically, all the text turns to from Japanese to English when you highlight it. Look for Settings - Set Up - Language or similar.
Apr 27, 2016 | Clarion Navi SDD NX308
Site that i should open my mms
You'll need to complete all steps for this to work. Make sure that if you have to enter O2 in the settings you use the letter O and not a zero.
The phone has a four-way directional Navi key and two soft keys on either side of this. The Navi key can also be pressed in to select options.
  1. Press Menu (press Navi key)
  2. Highlight Settings and Select (press Navi key)
  3. Highlight Configuration and Select (press Navi key)
  4. Highlight Personal configuartion settings and Select (press Navi key)
  5. Press Add new(press Navi key)
  6. Highlight Multiedia msg. and Select (press Navi key)
  7. Highlight Account Name and Select(press Navi key), enter giffgaff - MMS then OK (press Navi Key).
  8. Highlight Server address and Select (press Navi key), enter http://mmsc.mediamessaging.co.uk:8002 and OK (press Navi key).
  9. Highlight Use preferred access point and Select (press Navi key), highlight No and Select (press Navi key)
  10. Highlight Access point settings and Select (press Navi key)
  11. Highlight Proxy and Select (press Navi key), highlight Enable and Select (press Navi key)
  12. Highlight Proxy address and Select (press Navi key), enter 193.113.200.195 and OK (press Navi key)
  13. Highlight Proxy port and Select (press Navi key), enter 8080 and OK (press Navi key)
  14. Highlight Bearer settings and Select (press Navi key)
  15. Highlight Packet data access point and Select(press Navi key), enter giffgaff.com and OK (press Navi key)
  16. Skip past Network type this should be set to IPv4
  17. Skip past Authentication type, this should be set as Normal
  18. Highlight Username and Select (press Navi key), enter giffgaff and OK (press Navi key)
  19. Highlight Password and Select (press Navi key), enter password then OK (press Navi key), verify password and again select OK (press Navi key)
  20. Press Back (right soft key) six times
  21. Highlight Messaging and Select (press Navi key)
  22. Highlight More and Select (press Navi key)
  23. Highlight Message settings and Select (press Navi key)
  24. Highlight Multimedia msgs. and Select (press Navi key)
  25. Highlight Configuration and Select (press Navi key)
  26. Highlight Configuration and Select (press Navi key), highlight Personal config. and Select (press Navi key)
  27. Highlight Account and Select (press Navi key)
  28. Highlight giffgaff - MMS and Select (press Navi key)
  29. Press the right soft key five times to get back to the standby screen
Please switch your handset off and back on again before using these settings.
The settings are now complete.
hope that helps
May 29, 2013 | Nokia C1 Cell Phone
I have an error message coming up on my Clarion NX501 in dash navigation system "Out of Memery" "Requested: 2416555267" "Cache : 0" Navigation will not come up at all....
take the navi card out and stick it in your computer then partition it then update it online with new navi software reinstall the card this should fix your problem
Sep 21, 2011 | Clarion NX501 Car Video Player
How do i connect my nokia 6230 to gprs
Hiiiiiiiiiii....................
Nokia 6230 GPRS and WAP Internet Settings
The phone has a 4 way directional 'Navi' key and 2 soft keys either side of this.
To insert the required symbol (e.g. : / . @) into your settings, simply press the * key, highlight the appropriate symbol and press the Use key to select.
1. Press Menu button (Navi key).
2. Scroll to 'Settings' and press 'Select' (Navi key).
3. Highlight 'Configuration' and press 'Select' (Navi key).
4. Highlight 'Personal Configuration Settings' and press 'Select' (Navi key).
5. Press 'Add' [If there are profiles in the hand set already Press 'Options' then select 'Add new']
6. Highlight 'Web' and press 'Select' (Navi key).
7. Highlight 'Account name' and press 'Select' (Navi key).
8. Enter 'giffgaff GPRS WAP' and then press 'OK' (Navi key).
9. Highlight 'Homepage' and press 'Select' (Navi key).
10. Enter 'http://giffgaff.com/mobile' then press 'OK' (Navi key).
11. Ignore 'User name': Leave blank.
12. Ignore 'Password': Leave blank.
13. Highlight 'Use preferred access point' press 'Select' (Navi key).
14. Highlight 'No' and press 'Select' (Navi key).
15. If asked to 'Define access point settings' then press 'OK' (Navi key).
16. Highlight 'Access point settings' and press 'Select' (Navi key).
17. Highlight 'Proxy' and press 'Select' (Navi key).
18. Highlight 'Enable' and press 'Select' (Navi key).
19. Highlight 'Proxy address' and press 'Select' (Navi key).
20. Enter '193.113.200.195' and press OK' (Navi key).
21. Highlight 'Proxy port' and press 'Select' (Navi key).
22. Enter '8080' and press 'OK' (Navi key).
23. Highlight 'Data bearer' and press 'Select' (Navi key).
24. Highlight 'GPRS' and press 'Select' (Navi key).
25. Highlight 'Bearer settings' and press 'Select' (Navi key).
26. Highlight 'GPRS access point' and press 'Select' (Navi key).
27. Enter 'giffgaff.com' and press 'OK' (Navi key).
28. Highlight 'Authentication type' and press 'Select' (Navi key).
29. Highlight 'Normal' and press 'Select' (Navi key).
30. Highlight 'User name' and press 'Select' (Navi key).
31. Enter 'giffgaff' and press 'OK' (Navi key).
32. Highlight 'Password' and press 'Select' (Navi key).
33. Enter 'password' and press 'OK' (Navi key)
34. When asked to 'Verify new password' enter 'password' and press 'OK' (Navi key).
35. Press 'Back' (right soft key) 3 times.
36. Highlight 'giffgaff GPRS WAP' and press 'Options' (left soft key).
37. Highlight 'Activate' and press 'Select' (Navi key).
38. Press 'Back' (right soft key) 4 times to return back to the standby screen.
Switch your handset off and then back on to complete your settings.
The GPRS WAP settings are now complete.
Nokia 6230 MMS Settings
4. Highlight 'Personal configuration settings' and press 'Select' (Navi key).
5. Press 'Add ' [If there are profiles in the hand set already Press 'Options' then select 'Add new']
6. Highlight 'Multimedia msg.' and press 'Select' (Navi key).
8. Enter 'giffgaff MMS' and then press 'OK' (Navi key).
9. Highlight 'Server Address' and press 'Select' (Navi key).
10. Enter 'http://mmsc.mediamessaging.co.uk:8002' and then press 'OK' (Navi key).
11. Highlight 'Use preferred access point' and press 'Select' (Navi key).
12. Highlight 'No' and press 'Select' (Navi key).
13. If asked to 'Define access point settings' then press 'OK' (Navi key).
14. Highlight 'Access point settings' and press 'Select' (Navi key).
15. Highlight 'Proxy' and press 'Select' (Navi key).
16. Highlight 'Enable' and press 'Select' (Navi key).
17. Highlight 'Proxy address' and press 'Select' (Navi key).
18. Enter '193.113.200.195' and press OK' (Navi key).
19. Highlight 'Proxy port' and press 'Select' (Navi key).
20. Enter '8080' and press 'OK' (Navi key).
21. Highlight 'Bearer settings' and press 'Select' (Navi key).
22. Highlight 'GPRS access point' and press 'Select' (Navi key).
23. Enter 'giffgaff.com' and press 'OK' (Navi key).
24. Highlight 'Authentication type' and press 'Select' (Navi key).
25. Highlight 'Normal' and press 'Select' (Navi key).
26. Highlight 'User name' and press 'Select' (Navi key).
27. Enter 'giffgaff' and press 'OK' (Navi key).
28. Highlight 'Password' and press 'Select' (Navi key).
29. Enter 'password' and press 'OK' (Navi key).
30. When asked to 'Verify new password' enter 'password' and press 'OK' (Navi key).
31. Press 'Back' (right soft key) 3 times.
32. Highlight 'giffgaff MMS' and press 'Options' (left soft key).
33. Highlight 'Activate' and press 'Select' (Navi key).
34 Press 'Back' (right soft key) 4 times to return to the standby screen.
35. Press Menu button (Navi key).
36. Scroll to 'Messages' and press 'Select' (Navi key).
37. Highlight 'Message Settings' and press 'Select' (Navi key).
38. Highlight 'Multimedia Msgs.' and press 'Select' (Navi key).
39. Highlight 'Configuration Settings' and press 'Select' (Navi key).
40. Highlight 'Configuration' and press 'Select' (Navi key).
41. Highlight 'Personal Config' and press 'Select' (Navi key).
42. Highlight 'Account' and press 'Select' (Navi key).
43. Highlight 'giffgaff MMS' and press 'Select' (Navi key).
44. Press 'Back' (right soft key) 5 times to return to the standby screen.
The MMS settings are now complete.
Enjoy............
Sep 21, 2011 | Computers & Internet
Does not internet
Hi jobmasai,
you may wanna try this:
Nokia 2330 GPRS and WAP / Internet Settings
1.Press Menu (press Navi key)
2.Highlight Settings and Select (press Navi key)
3.Highlight Configuration and Select (press Navi key)
4.Highlight Personal configuartion settings and Select (press Navi key)
5.Press Add new (Navi key)
6.Highlight Web and Select (press Navi key)
7.Highlight Account Name and Select (press Navi key), enter giffgaff WAP GPRS then OK (press Navi Key).
8.Highlight Homepage and Select (press Navi key), enter http://giffgaff.com/mobile then OK (press Navi Key)
9.Highlight User name and Select (press Navi key), enter giffgaff then OK (press Navi key)
10.Highlight Password and Select (press Navi key), enter password then OK (press Navi key), verify password and again select OK (press Navi key)
11.Highlight Use preferred access point and Select (press Navi key), highlight No and Select (press Navi key)
12.Highlight Access point settings and Select (press Navi key)
13.Highlight Proxy and Select (press Navi key), highlight Enable and Select (press Navi key)
14.Highlight Proxy address and Select (press Navi key), enter 193.113.200.195 and OK (press Navi key)
15.Highlight Proxy port and Select (press Navi key), enter 8080 and OK (press Navi key)
16.Highlight Bearer settings and Select (press Navi key)
17.Highlight Packet data access point and Select (press Navi key), enter giffgaff.com and OK (press Navi key)
18.Skip past Network type this should be set to IPv4
19.Skip past Authentication type, this should be set as Normal
20.Highlight User name and Select (press Navi key), enter giffgaff and OK (press Navi key)
21.Highlight Password and Select (press Navi key), enter password then OK (press Navi key), verify password and again select OK (press Navi key)
22.Press Back three times (right soft key)
23.Highlight giffgaff WAP GPRS and press Options (left soft key)
24.Highlight Activate and Select (press Navi Key)
25.Press Back (right soft key) four times.
Apr 14, 2011 | Nokia Classic 2330 Cell Phone
I cant receive mms
The phone has a 4-way directional 'Navi' key and 2 soft keys on either side of this and 4 additional soft keys either side of the keypad. The Navi key can also be pressed in to select options.
1. Select 'Menu' (press Navi Key).
2. Scroll to 'Settings' and select (press Navi key).
3. Scroll to 'Configuration' select (press Navi key).
4. Scroll to 'Personal configuration settings' and select (press Navi key).
5. Press 'Options' (left softkey) highlight 'Add new' select (press Navi key).
6. Highlight 'Multimedia msg.' and select (press Navi key).
7. Highlight 'Account Name' select (press Navi key), enter 'giffgaff MMS' then 'OK' (press Navi Key).
8. Highlight 'Server address' select (press Navi key), enter http://mmsc.mediamessaging.co.uk:8002' and 'OK' (press Navi Key).
9. Highlight 'Use preferred access point' and select (press Navi key), highlight 'No' and 'Select' (press Navi key).
10. Highlight 'Access point settings' and select (press Navi key).
11. Highlight 'Proxy' select (press Navi key), Highlight 'Enable' and select (press Navi key).
12. Highlight 'Proxy address' select (press Navi key), enter '193.113.200.195' and 'OK' (press Navi key).
13. Highlight 'Proxy port' select (press Navi key), enter '8080' and 'OK' (press Navi key).
14. Ignore 'Data bearer' as this is set at 'Packet data'.
15. Highlight 'Bearer settings' and select (press Navi key).
16. Highlight 'Packet data access point' select (press Navi key), enter 'giffgaff.com' and 'OK' (press Navi key).
17. Ignore 'Network type' as set at 'IPv4'.
18. Ignore 'Authentication type' as set at 'Normal'.
19. Highlight 'User name' select (press Navi key), enter 'giffgaff' and 'OK' (press Navi key).
20. Highlight 'Password' and select (press Navi key), enter 'password' then 'OK', verify password and again select 'OK' (press Navi Key).
21. Press 'Back' (right softkey) 6 times to get to the main menu.
22. Highlight 'Messaging' and select (press Navi key).
23. Scroll to 'Message settings' and select (press Navi key).
24. Highlight 'Multimedia msgs.' and select (press Navi key).
25. Ignore 'Delivery reports' as preset to 'No'.
26. Ignore 'Image size' as preset to '640x480'.
27. Ignore 'Default slide timing' as preset to '00:08'.
28. Ignore 'Allow multimedia reception' as preset to 'Yes'.
29. Ignore 'Incoming multimedia messages' as preset to 'Retrieve'.
30. Ignore 'Allow adverts' as preset to 'Yes'.
31. Highlight 'Configuration settings' and select (press Navi key).
32. Ignore 'Configuration' as this will change to 'Personal config.' with the next step.
33. Highlight 'Account' and select (press Navi key).
34. Highlight 'giffgaff MMS' and select (press Navi key).
35. Press the right softkey 5 times to get back to the standby screen.
Feb 07, 2011 | Nokia 6070 Cellular Phone
How can I set the clock on a Pioneer AVIC-N2 Nave Rcvr
Manual (PDF) for AVIC-N2 can be downloaded here. (It might take up to 2 minutes, depending on your internet connection).
Chapter 5 of the manual deals with "Customizing your navigation system." Page 67 lists specific instructions on how to change the time.
Good Luck!
Jan 16, 2010 | Pioneer AVIC-N2 DVD Navi Rcvr with 6.5"...
2003, 330Ci radio, navi buttons on the dash not functioning.
hello . ok first try disconecting the nave unit on the trunk if the radio comes up and the buttons work you have a bad nave unit (very common ) . other option look for radio fuse in glove box top open white tabs on top diconect the fuse and reconnect to see if it will restart the radio pannel if not replace the radio pannel .
Aug 25, 2008 | 2003 BMW 325
Nax970hd wont give me my current location
for some odd reason i disconnected the vss wire from the nav system to my cars ecm then reconnected it and bam it all of a sudden started working like it should.
May 29, 2008 | Clarion NAX970HD Navigation System GPS...
Computers & Internet Logo
101 people viewed this question
Top Clarion Computers & Internet Experts
David Payne
David Payne
Are you a Clarion Computer and Internet Expert? Answer questions, earn points and help others
