Question about Refrigerators
Adjusting the top shelf - Refrigerators
Can I use my Triciry Bendix dishwasher DH101 if I remove the top. It needs more clearance below the worktop. When I remove the top there is a material, not a solid top.
Listen to hear if dishes are rattling against each other. Cups should be loaded only in the top and care to keep each cup separated from other. Chipping usually will occur when dishes are close together and in contact. The racks are rubberized and would be very unlikely the source.
If the feet are adjusted so the machine will not rock it would be unlikely that the top on or off would have any effect.
The upper shelf is adjustable up or down. Suggest locating upper shelf to the up position.
TRICITY BENDIX Dishwasher
Hope this helps?
Dec 06, 2016 | Dishwashers
Are the shelves adjustable?
The top shelf/countertop is not adjustable and it fixed at 33 inches high.
The lower two shelves are adjustable and can be placed at whichever height you desire.
Feb 16, 2014 | Seville Classics Bakers Rack Workstation...
AEG favorit 40850 dishwasher does not clean properly - help
under the top shelf or in the top of the machine is the water rotor. remove this and ensure none of the holes are blocked, also ensure your macine is not running on 1/2 half load as this may only activate the bottom. it should be set to full load to use both. if rotor bloackage is the problem use somthing to clear it. and also check the bottom one. also remove and clean the inner filter as debris may have got past it and getting pumped to your rotors.
I hope this was useful
Feb 15, 2013 | AEG 24 in. Favorit 40850 Free-standing...
How do I adjust these shelves?
you need to tap the shelf up and the black split rings will come loose you then put the split rings in the grove height you want and tap the shelf down to lock them. they are tapered. make sure the thin side is on top
Feb 03, 2013 | Office Equipment & Supplies
Kitchen aid top shelf warm
  1. check gasket
  2. check the light switch on top of the refrig. section. If then pushed the switch turns the light off, but the light is still on with the fridge door closed - door needs adjustment.
Oct 13, 2009 | KitchenAid KSS48QM 48" Built-In...
All food on top shelf of refrigeratr is freezing
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Aug 17, 2009 | Refrigerators
Door to refrigerator will not close properly.
The refrigerator door seal is being broken when you open the freezer door? Sounds like the rubber magnetic strip needs to be replaced on the refrig. door, they wear out after a number of years.
Oct 28, 2017 | Kenmore 73262 / 73264 / 73269 Top Freezer...
Water on bottom shelf of FRT15B3AW3
is the fan still running in the freezer compartment???? it may be your defrost thermostat.....
Aug 18, 2008 | Frigidaire FRT15B3A Top Freezer...
Admiral refrigerator -shelf removal
You just "pop out" the blue clips. Then pull the shelf out and relocate it to your desired position. Lastly, replace the blue clip to the top of the hole where you placed your shelf.
Jul 12, 2008 | Admiral 26 cu. ft. Side-By-Side...
Refrigerators Logo
18 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
