Patio Heater starts but flame is low and it goes out quickly. Presumably this has nothing to do with the pilot light or starter flame because the heater main flame has been started.
There are two heaters which were just put back into service after the winter. They are both acting the same way. The tanks were just filled. The main flame was OK at first but after one time they are puny and go out easily. One might suspect the tank safety valves, the regulators and ... what else? I don't think the pilot light is needed after the main flame has been ignited.
    Habit-Forming:
    New Friend:
  • 117 Answers
This sound like the thermocouple or flame sensor is bad .
Thermocouple is connected from gas valve and it sits next to pilot so when flame is established this heats up and tells the unit to stay on ,same as a flame sensor
Posted on May 17, 2017
Burner comes on at 3.any lower goes out.6 inch yellow flamestarts on rite side under pressure.not burner rite of burner
Troubleshooting :: AZ Patio Heaters and Replacement Parts
azpatioheaters.com/pages.php?pageid=11
How do I replace starting striker switch on a tall patio heater? How do I clean ... Why is my burner flame low? Why does ... Why does my pilot light, but goes out when heateris turned on high or low? Why do I get a yellow flame and black smoke? ... 6. Can I convert my LP gas patio heater into a natural gas patio heater? NO.
Nov 17, 2015 | Heating & Cooling
My patio mushroom heater lights up ok but keeps going out by itself after about 5 to 10 minutes and then can be started again inatantainiously by starting pilot light and away you go until it goes out...
Here's a few things to check. When you light the pilot, is it a strong blue pilot flame, a weak blue flame or a lazy yellow flame? Is it heating the thermocouple enough to make it red hot after a few minutes? If the pilot is small blue or lazy yellow flame, it may be dirty and need cleaned. When the burner lights, the weak pilot flame may diminish causing the thermocouple to cool off enough to shut down the main burner. Clean the dirty pilot orifice by using a can of compressed air with attached straw. (The same canned air you use to clean computer keyboards) Blow it into the pilot assembly where the pilot flame burns out from and blow thru the air holes on the side, if applicable. You might also check the thermocouple itself to make sure the tip is not partially burn't off. It should be a smooth, rounded tip. Replace the thermocouple if cleaning the pilot orifice doesn't solve the problem. Douglas
Aug 05, 2010 | Coleman (5040B750) Patio Heater
Main Heater will not light off
turn the gas on real slow. The air in the line is blowing out the pilot
Aug 26, 2009 | Stainless Patio Heaters - Steel Deluxe...
Charmglow gas patio heater
Your thermocoupler seems at fault. The thermocoupler is that probe that sits in the pilot flame. It controls the main fuel valve. Make sure that probe is in the pilot flame, better at the tip of the flame and hold the button down for a minute or so after lighting the pilot. If pilot extinguishes, the coupler is faulty. If pilot stays on the heater should fire up when you let up on the pilot button.. Good luck
May 30, 2009 | Coleman (5040B750) Patio Heater
Patio heater ignites and stays lit with pilot. Then goes out.
Press and hold for 60 seconds and then it should stay lit (this is a safty feature on most models!)
Dec 18, 2008 | Endless Summer gwt501a Open Flame Patio...
Natural gas patio heater
MAY I KNOW THE EXACT MODEL # OF YOUR UNIT.
Sep 27, 2008 | Heating & Cooling
make sure there is no dust dirt spider webs in the pilot hood if u have a nice blue flame coming from the pilot and u held the pilot knob down for at least 30 sec
and it still doesn't work then u have a bad THERMOCOUPLE
Sep 25, 2008 | Heating & Cooling
Patio Heater pilot lights won't stay lit
crappy pilot flame (not properly heating the thermocouple), bad thermocouple, thermocouple loose where it screws into the pilot safety valve, bad safety valve magnet.
One or more of those is the problem.
Oh...there is also a saftey switch...in case it tips over. It will also cause the pilot to not stay lit (if the switch or wires that go to i are faulty)
May 30, 2008 | Coleman (5040B750) Patio Heater
Windchaser patio heater
You have to hold the button down for 30 seconds at least before turning the knob to ON. If you are doing this and it still goes out after you let up on the knob, then it needs a new flame sensor, or thermocouple. Same thing different names.
Feb 29, 2008 | Endless Summer 2009 Open Flame Patio...
Heating & Cooling Logo
24 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
