I would like to install freeview on my Bauhn 50" FHD LED LCD TV. would like the instructions as my manual does not have it
gopakumarg43
  • 74831 Answers
SOURCE: tune in manual
Click here to download the user manual. It will have all details.
Posted on Aug 11, 2012
spr1949
  • 1182 Answers
SOURCE: My onix 40" Fhd LCD tv has power going in (red
In order to ensure, it is not caused by the input device, connect a DVD player and see. Also look for any loose contacts in power outlet, RC jack, cable and socket. Switch off TV, switch off power, remove plug and wait for 48 hours and retry.
If problem persists, I suggest it is better to refer it to a qualified service technician, since the back cover has to be opened for investigation/rectification.
Posted on Aug 23, 2012
gopakumarg43
  • 74831 Answers
SOURCE: My vial I V32LEDF fhd led LCD TV won't power up.
If power light too is absent, the fault is with its main power regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
If power light at its front panel lights up, and the set won't power up by pressing the power button at the remote control; the main board is faulty. If so try a reset to this set. Sometimes it might help you.
There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked above.
Posted on Nov 01, 2014
  • 39039 Answers
SOURCE: How to setup 40 fhd led tv with a remote an no
Request a manual from the manufacturer/distributor.
Posted on Nov 02, 2014
  • 12962 Answers
SOURCE: I have a new HITACHI 65" LED LCD FHD TV. MODEL VZ655100. IT will not auto tune or manual tune. Keeps saying no channels recognised.Have followed guide book iinstructions exactly. thanx.
Sets new?! Hook up antenna that works?
If nada, have them pick it up and exchange it for a new, hopefully working unit.
Take no prisoners!!!!!!
Posted on Dec 03, 2015
TV bauhn 50" 127 cm led LCD TV the blue light goes on but no show on TV
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Nov 20, 2016 | Televison & Video
Remote code for Bauhn ATV-BA32DV2
bauhn p v r setup Questions & Answers - Fixya
www.fixya.com > Forum > Tags
... bauhn universal remote control tv but i had vivo tv how ican set up that The universal ... ATV-BA32DV2, have done initial setup, but screen says have to scan ...
Remote code for BAUHN TV model ATV-19HED - TVs - Home theatre ...
forums.whirlpool.net.au > Home theatre > TVs
WhirlpoolDec 14, 2014 - I've mislaid the remote for this TV and I was wondering if anybody new how I could get hold of BAUHN remote IR codes. I've looked everywhere ... 32" (81CM) HD LED LCD TV $222
May 29, 2014
Bauhn 24" Full HD LED LCD TV with DVD
Jan 12, 2013
More results from forums.whirlpool.net.au
[PDF]32" (81cm) HD LED LCD TV
Feb 03, 2016 | Televison & Video
Need code for my remote control for my Bush Tv
Codes are in the remote. Finding the code depends upon knowing the "brand" of remote and whether it is universal (URC-???).
Feb 01, 2016 | Bush 42" LCD TV 1920x1080, 50 Hz, Freeview...
Can I use iphone connected to Bauhn FHD LCD TV via USB port to watch youtubes?
Any device connected to the TV, will display, as long as the TV is set to play the proper "video" mode selected, that device is plugged into. Meaning : if IPhone is plugged into USB, then the video mode needs to be switched from TV reception to USB. Normally this is done by pressing "Input"' on your TV 's remote, then selecting the proper mode.
Mar 16, 2015 | Televison & Video
I Have A Bauhn TV Set 50" Ful JD LED LCD TV. When You Plug To Power There A Blue Light But No display On Screen. please Tell Me What The Problem Is.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Jan 30, 2015 | Televison & Video
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
