I am not a technician but my VRT shows code nF. I need help but can't tell if your site is free. Please advise
5 Suggested Answers
  • 3 Answers
SOURCE: Samsung VRT washing machine
nF means that washer tried to fill but was unsuccessful. Water supply valves needs to be fully open. Lines may be kinked or screen by the hose hookup at the washer end may be restricting flow. Check to ensure the screens are cleaned by removing hose and pull screens and clean them then try the washer again
Posted on Jan 18, 2008
SOURCE: VRT with a nf message.
if water flow is OK from the supply, remove the top cover and check the pressure hose that runs from the tub to the pressure sensor. They have a tendency to come loose on these machines. That is what my problem was...Always unplug power before removing covers...
Posted on Jul 26, 2010
SOURCE: 2007 Chevy Tahoe check engine scan codes: P0030,
There is a fault with the inbuilt heater in the oxygen sensor, before the catalytic converter, on the exhaust pipe the same side of the engine as cylinder 1. The oxygen sensor has four wires within the cable sheath to the top of it. Two of the wires will share the same color. These wires supply power to an internal heating element wire within the sensor. Follow the cable from the oxygen sensor to the connector, you can do a lot testing here. Check the resistance between the two 'same coloured ' wires. The resistance is low, somewhere between 1 and 10 ohms. If there is no continuity (infinite resistance) then this is the fault and the sensor needs to be replaced. The codes: P0030 the oxygen sensor heater relay is at fault P0053 Oxygen heater resistance error P0135 Sensor 1 bank 1 error You are looking at replacement. A further confirmation take the connection from sensor 1 bank 1 and swap it with the sensor 1 bank 2 on the other side of the engine. The codes should 'transfer' and show P0036; P0059 and P0141.
Posted on Apr 26, 2011
  • 26 Answers
SOURCE: I need a service manual
go to their web site and check for copies. call their customer service and ask there as well.
Posted on May 29, 2011
I have a nf code on my samsung wash machine vrt what does this mean
please go to the manufactures website and download the user guide and check in the trouble shooting guide eric
Jan 17, 2018 | Samsung Washing Machines
I need a Samsung Vrt steam manual. What does the error message 3E stand for on the, VRT Samsung Front Loader washing machine?
This video will help you diagnose the fault on Samsung Vrt steam 3e error codes and the video will help you solve the problem
Oct 24, 2015 | Samsung 3.9 Cu. Ft. VRT Steam and Power...
Can I get a list of error code and what they mean and how to fix. I keep getting nF as an error. What does this mean?
It means 'not filling'. So either nor or both of your water lines are turned off or just barely open, or the filter screens on your hose washers are clogged. Clean/clear them, or check water flow and you should be good to go.
Mar 10, 2015 | Samsung WF431ABP VRT Steam Front Load...
Error code of NF (no fill) on samsung top load washer (WA422PRHDWR/AA) even after checking lines for restrictions and ensuring clean line filters (red and blue). Now, when it does work, it will only do a...
Put the temp select switch on HOT, start machine. If water comes out check the flow amount. If no water flow, replace inlet water valve. If there is water flow switch to COLD, start machine. If water comes out check the flow amount should be approximately equal or slightly more than flow on HOT. If no water flow, replace inlet water valve. Move selector to WARM, start machine. Now there should be twice the flow of water than there was with HOT and COLD temps. I suspect it is the HOT side of inlet water valve that has failed because machines usually rinse with COLD water.
Jan 20, 2013 | Samsung WA422PRHDWR 4.2 Cu. Ft. VRT Top...
Jul 06, 2008 | Samsung WF337AA Front Load Washer
Abit motherboard nf-m2s
Hi chatzmoe, on page 8 of you're manual is a picture & layout for you're abit NF-M2S front panel connectors for LED's.
If you're current manual does not show this, tham download the manual from the link below.
http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=NF-M2S&fMTYPE=Socket%20AM2&pPRODINFO=Manual
Main web page for Abit NF-M2S.
Have more questions? Please feel free to ask.
Luck!
Mike
May 08, 2008 | Abit NF-M2S Motherboard
Samsung Front Load VRT
I've had that same code, the machine completely stops and you have to start over with the load, the repair man samsung sent out still cannot fix my problem. he says there is a defect on these machines, good luck!
Apr 15, 2008 | Samsung WF337AA Front Load Washer
Nov 24, 2007 | Samsung WF337AA Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
