Question about Lexmark Office Equipment & Supplies
How to get clear no paper mark in lexmark e260 printer
  • 2035 Answers
SOURCE: Lexmark X5470 printer says, "Clear paper jam, then press check mark."
  1. Turn the printer off and open the access cover.
  2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
  3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
  4. Watch the paper as it feeds through and try to determine where the jam is occurring.
  5. Check to see if all the rollers are turning.
    If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
    If not, there is probably a feed motor or a gear problem and the printer may require service.
  6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
  7. Turn the printer off.
  8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
  9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on May 28, 2008
SOURCE: lexmark printer is saying clear paper jam but
take an envelope and slide it across the whole printer (where the paper goes into the printer), it's a small piece of paper inside there, I called Lexmark and they walked me through it and it worked.
Posted on May 17, 2009
SOURCE: paper does not feed into lexmark X5470 all in one printer
feeding problems
not take apaper
not feed a paper
hey im tuval from israel,
first of all im sorry about my english :)
and now to the point.......
look, if you know where the feeding wheel its good (like elastic material over this wheel) , now take a"nail cleaner" (aceton)
and clean this wheel (the elastic thing), i did thet and the problem is gone!!!
after the cleanning send 15-20 empty doc to print (remember - empty, dont use you ink - you dont have to - save money), if all the paper is out from the printer,
you fix that.
i hope i help you.
hope fore replay.... :)
Posted on Jun 20, 2009
SOURCE: paper jam lexmark x3470
#2 works for an x3470, but jostling the small cylinder that accepts the paper (nudge it gently toward the printer) seems to be what pulls back the microswitch...
Posted on Aug 22, 2009
  • 4041 Answers
SOURCE: Lexmark X5650 printer
Hello there
ok try this my help you.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 26, 2010
It wont feed the paper it keeps say paper jam but the paper is not even going in
Lexmark Impact S301 Printer won't take the paper -
Dec 19, 2013 - Feeding paper is the first step of printing materials. However, what will you do when the Lexmark Impact S301 Printer won't take the paper ...
Paper Jam Troubleshooting on 2009 Printers - Lexmark
LexmarkLexmark Impact S301, Lexmark Impact S302, Lexmark Impact S305 ... When troubleshooting paper jams on Lemark's 2009 printer models, make sure you also ...
[PDF]Solving paper feed problems - Lexmark
LexmarkUse the following table to find solutions to paper feed problems you are ... For detailed instructions on clearing paper jams, see Clearing print media jams.Missing: impact ‎s301
How To: Clear a Paper Jam on a Top Feeding Lexmark ...
? 2:30
Jan 14, 2016 | Lexmark Impact S301 Wireless All-in-one...
How to reset lexmark e260 chip
Go to any website that sells bulk ink and toner refills. They have chip resetters. You need to do this every time you refill . It cannot be bypassed.
Jan 24, 2014 | Lexmark E260 Laser Printer
I have a Lexmark E260 printer and get ink marks along the edges my printed sheets about 1/4 inch wide on both sides. How can I fix this??
Please click on the link to see instructions on how to go about the procedure.
For further assistance, please contact Lexmark Technical Support.
Mar 21, 2011 | Lexmark E250dn Laser Printer
Lexmark X5470 printer displays message "Clear paper jam, then press (check mark). There is no paper jam and it will not print with the message showing. I have cleaned the rollers but it didn't help.
try taking all of the paper out and then just print one sheet.
also make sure that it is new paper, lays flat and that you have fanned it prior to inserting it in the printer.
Jan 08, 2010 | Lexmark X5470 All-In-One InkJet Printer
Lexmark x7550 printer jam. I cleared the jam and hit the check mark button as directed, but it keeps looping through the paper jam sequence. It does not seem to register that the jam has cleared. If I...
There will be some form of error clear code that would need to be entered. It would be something like "holding down the print key and powering on the printer at the same time" The manual may tell you.
There are different combos for different manufacturers.
Nov 17, 2009 | Lexmark X7550 InkJet Printer
Lexmark 6500 states I have a paper jam, but I don't.
Hooray for McGuyver techniques, but I just shoved a piece of paper in there so it actually had a jam, pulled it out, and it cleared fine!
Sep 22, 2009 | Lexmark X2550 All-In-One Printer
Message shows 'clear paper jam then press check paper jammed in printer but it will not reset.
message keeps showing print cartridge cradle cannot move, I have check everything, no paper jams nothing under printer, I am turned off printed but keep getting same message.
Sep 17, 2009 | Lexmark X4530 InkJet Printer
How do i clear a paper jam
The Lexmark Printer you are having a very sensitive printer.
Normally this tyoe of Printers are very very slow in Printing job.
Comparing with other laserjet used.
If the Laptop / Printer are under warranrty, the Service engineer
can rectifity the printer jamming.
Solutins :
Make the Printer - Monthly service compulsory.
Use only good quality paper in the Lexmark Printer.
Do not pull the paper through hand, when the print out is coming.
Jul 15, 2009 | Lexmark X5470 All-In-One InkJet Printer
Error message on Lexmark x5470
hi there: we have the same printer and we had the same paper jam problem to correct: this we opened it up as normal and than got a flashlight and looked real closley at it and there was a verry small piece of paper in the side of it folded and caught in it we took a pair of tweezers and removed it and the paperjam was cleared try that ok the smallest piece will give you this error and wont continue untill it is cleared
best of luck mike
Feb 09, 2009 | Lexmark X2500 All-In-One Printer
Lexmark, photo printer
Try to pass several sheets of plain paper
Then try the thicker photo paper.
If it is giving trouble send it back
Dec 31, 2007 | Lexmark P450 InkJet Photo Printer
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
