Question about Crafts & Hobbies
How to put the trigger spring in a 208 type 1 black and decker glue gun
SOURCE: iron D2000C type 1 black decker
the folowing reason for not working 1. the connection may be lose 2. the heating coil is gone 3. inside connection may be lose.
Posted on Sep 30, 2007
  • 50 Answers
SOURCE: black and decker steamer hs900 type 1
Hi marylou, below is a link to the user manual for this steamer. Just click on the link or copy and paste to the address window of your browser. You need Adobe Reader installed on your computer in order to open this .pdf file (free at www.adobe.com). If this helps, please rate this answer. Thanks! Hal
http://useandcaremanuals.com/pdf/HS90038.pdf
If that link doesn't work, try the one below and click on "Get This Manual"
http://kitchen.manualsonline.com/manuals/mfg/black_decker/hs900_1.html?s=fpw
Posted on Jun 21, 2009
  • 569 Answers
SOURCE: need owners manual for black and decker
You can download it from here (Black and Decker now owned by DeWalt)
http://www.dewaltservicenet.com/SearchResults.aspx?q=band+saw+no.+9422+type+1
Posted on Jan 11, 2010
  • 10865 Answers
SOURCE: need charging instructions for black & decker
Hello. Use an ordinary extension cord and plug it into the back of the light and into the wall. Charge it for 20-30 hours, but not more than 30 hours. Here is the downloadable manual for future reference
http://demandware.edgesuite.net/aaea_prd/on/demandware.static/Sites-black-and-decker-Site/Sites-cpo-master-catalog/default/v1269899899597/dw_manuals/black-and-decker/bdknvec157bd/bdknvec157bd_manual.pdf
Posted on Mar 29, 2010
Need to put a hot glue gun back togethe. How do you put the spring back on
Should be a short stub on the back of the trigger. Slide one end of the spring on this stub. compress spring and place trigger on mount. (socket or pin on one side of frame) replace the other half of the shell.
Aug 04, 2017 | Crafts & Hobbies
I need help in putting the gun back together
John did you get a answer I am having the same problem
Jun 02, 2013 | Black & Decker 1700 PSI Electric Pressure...
Black and decker glue gun
you didn't specify the model, but go to this page and scroll down to 'glue guns' and you can download the manual for your model
http://www.manualslib.com/brand/black-and-decker/
Jul 17, 2012 | BOSTIK Crafts & Hobbies
As soon as I turn the water on, it comes out of the gun and high pressure turbo wand even with the machine off. I used it yesterday with no problems. It does this without even pressing the trigger. ...
This part should be available from the manufacture, have you check their website. It is normal when you turn the water on for a small string of water to come out the gun when you press the trigger even when the engine is not running.
Thanks
Jun 03, 2011 | Black & Decker 1700 PSI Electric Pressure...
I have somehow realeased the trigger so it is not pushing the glue forward but i cant seem to open the glue gun up 2 fix this problem?
there should be small screws near the handle so that you can split the casing into 2 halves. then look for the spring that regulates the trigger
May 29, 2011 | Bostik Hot Melt Glue Guns Adhesives
Assembly instructions for reassembly. I had to disassemble glue to clean and the spring popped out and I am not sure how it goes back together
the spring goes behind the trigger, but i would need to know the brand and model glue gun to really help with this problem
Nov 17, 2010 | Crafts & Hobbies
Glue Gun Question
Gather the materials needed and place them on a flat surface near an electrical outlet. Examine the glue gun. Locate the metal rest. This is usually attached to the barrel of the gun and is shaped like a "W." Make sure it folds out and locks into place. Locate the trigger. This is just behind the barrel on the underneath side of the gun. It should be a solid piece of plastic shaped like a slice of pie. Just above the trigger, is the barrel loader. This is where the glue sticks go into the gun. Inside the barrel loader there is a smaller round piece of plastic. This is what actually pushes the glue stick through the barrel. Pull the trigger and watch the piece of plastic move with it. Pick up the electrical cord and examine it. Make sure the prongs are secure and not bent. Make sure the cord has no breaks in the outer lining and there are no frays at the base of the gun where the cord attaches. Plug the glue gun into the electrical outlet. Allow the gun to heat at least 15 minutes so it reaches operating temperature. When the gun has heated at least 15 minutes, insert a glue stick as far as it will go without forcing it. Now pull the trigger until a small drop of hot glue forms on the tip of the gun. Practice gluing on the paper plate. Pull the trigger until a ball of glue forms on the plate. Release the trigger and quickly press the tip of the gun down onto the surface of the plate and pull it to the side. This will break the glue and stop it from stringing out when you pull it away. Continue practicing until you get the right amount of glue you want for the object you imagine using. When you pull the gun away, there may be a small string but this will break off easily. When you have the perfect amount of glue and only a tiny string forming when you pull away, you are ready for your project.
Aug 27, 2008 | Rubbermaid Power Tool Hook Black
Crafts & Hobbies Logo
768 people viewed this question
Top Crafts & Hobbies Experts
Debbie
ray gallant
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
