Sound but no picture for the last 3 hours - Televison & Video
Hi I have a Philips 40PFL3705D/F7 LCD TV. The picture shuts down after a while. Could be 3 weeks, 3 days or 3 hours of watching TV. Still have sound.
Maybe a thermal problem or there is something apart loose even use cold spray, manipulated by slight shaking or tapping components.
Oct 31, 2015 | Philips Televison & Video
When do i use the sp/ep button? What is the difference?
In a VCR SP which stands for standard play on an E180 tape will last for 3 hours. So you can record 3 hours on it and much longer in EP however the quality of the picture will be less.
However I suspect that you could mean a DVD recorder. In which case a 4.7GB disc will last for 120 minutes on SP and 240 minutes on EP. Again there will be a loss of picture quality on the longer setting, but most people can cope with that.
May 22, 2011 | JVC Televison & Video
My tv comes on runs for 30 sec. then loses sound and picture for 30 sec. and the standby light flashes green for 30 sec. then the picture and sound comes on . then about 30.sec. later it does the whole...
It is symptom of weak lamp that has been reached to an end of its working hours life but not dead/ broke yet.
If lamp has not been replaced in last 2-3 years then please replace lamp in tv to get solve this problem.
Lamp replacement procedure is easy and written in user manual, please buy Sony original lamp for good picture in tv.
Thanks.
Feb 11, 2011 | Sony KDF-E50A10 LCD TV
Picture blacks out for 26 seconds then resumes
It sounds lamp in tv has reached on its end of working hours life and tv requires new lamp.
If lamp has not been replaced in last 2-3 years then its time to replace it to fix the problem.
Let me know if you have additional question.
Thanks.
Jul 28, 2010 | Sony KDF-E55A20 55 in. LCD Television
I have sound but no picture, over the last month it has been taking an hour to get sound and picture from switch on, but today it is just sound after about 2 hours. 15PF4121/05
Similar problem in my Philips. No picture, just green led flashing in front panel. Reason was dried up capacitors in power supply card. Came on by renewing c223 and c228.
Jan 18, 2010 | Philips 15PF4121 15 in. LCD Television
Is my picture tube going?
Most proj TV's of that type have 3 Picture tubes Red, Green and Blue. It's not likely that all 3 went bad at the same time in the same manner. So I believe you have a circuit problem, probably in the power supply stages, possibly a bad solder joint.
Hope that helps...
Geno
Mar 25, 2008 | Televison & Video
Picture getting darker
The tv has a room light sensor,
shine a bright light at it , does picture get brighter?
other wise when it is cool open the bulb door , is it coated or blackened, Don't touch bulb at all.
and a heavy covering of dust on internal mirrors will cause the same effect.
you will need help to clean it.
Jan 26, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony grand wega KDF-E50A10
The looks of the bulb are no indication that it's okay. How many hours of operation do you have on that bulb? The bulbs are average rated for 5000 hours, but its been my experience that they usually last on average 3000 hours. Try replacing the bulb and then check and rest the buld hours counter.. Best place I've found for purchasing the bulbs is DLP lampsource. They'll sell you just the bulb without the housing at a dramatic savings. http://www.dlplampsource.com/
To display the lamp time press [ 2 ] nine times.
to reset press [ 3, mute, enter.] Or with the set in standby press [ display, 5, vol up, power ]
then press [ jump 3.]
Hope this helps!
Bill
Dec 01, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
