Question about The Optics
How many moons does saturn have in the solar system
How much moons are there
Your query is a little vague - do you mean in the entire Solar System ?
Jul 23, 2017 | Optics
Name five features of Jupiter
Great Red Spot
The Stripes
The Jovian Rings (yes, it does)
The largest moon in the Solar System, Ganymede
The White Ovals
The shortest day of all planets
The greatest mass of all planets, more than all the others combined
Nov 18, 2016 | Computers & Internet
How many moons have neptune and urans have
MOONS OF NEPTUNE
Neptune has 13 known moons, though most are small and orbit closer to Neptune than its rings. Triton is Neptune's only large moon with a diameter of 2,704 km, and Proteus and Nereid are Neptune's second and third largest moons, respectively.
The moon Triton
(click to enlarge)
Triton: The backward moon of Neptune
Voyager 2 discovered many of Neptune's moons in 1989, and took pictures revealing many previously unknown properties of Triton. Triton's icy, spherical surface reflects so much of the sunlight it receives that it is the coldest world in the solar system.
Triton is the only moon in the solar system with a retrograde orbit. This, along with Triton's high inclination relative to Neptune's equator, suggests that Triton may have been captured from interplanetary space.
The surface of Triton
Photos of Triton show a strange surface shaped by more than just impact cratering, although its many undisturbed craters suggest that major geologic activity has subsided. Regions on Titan's surface show evidence of past volcanic and tectonic activity. The internal heat source for Triton's geologic activity is not known, but it may involve tidal heating.
The sublimation of surface ices creates a thin, hazy atmosphereon Triton made mostly of Nitrogen. The atmosphere creates wind streaks on the surface, and unknown processes pump unusual plumes of gas and particles into the atmosphere.
Uranus' medium-size moons
(300 - 1,500 km in diameter)
5 medium-size moons orbit Uranus (from innermost to outermost):
  • Miranda
  • Ariel
  • Umbriel
  • Titania
  • Oberon
Uranus' medium-size moons are made of ice and rock. Like other objects that formed far from the Sun, the ice is made up of ammonia, methane and water.
These moons pose several puzzles. Ariel and Umbriel are about the same size and density, but Ariel's young features indicate volcanic and tectonic activity, while Umbriel's largely cratered, uniform surface implies a lack of geologic activity. Titania and Oberon are also very close in radius, but show different levels of geologic activity. The faults on Titania indicate internal forces while Oberon's heavily cratered, icy surface shows few signs of movement.
A Canyon on Miranda
(click to enlarge)
Voyager 2 came closest to Uranus' smallest moon, Miranda, as it passed by on its way to Neptune. The features on Miranda's surface are different from other jovian moons. With a mixture of old and new surfaces, Miranda shows relatively few craters but has a number of canyons up to 12 miles deep. Due to Miranda's odd surface features, scientists spectulate that there is an additional source of heat, such as tidal heating. The cliff walls seen in the inset are higher than those of the Grand Canyon on Earth.
Uranus' Small Moons
(click to enlarge)
Uranus' small moons
Uranus' smallest moons are its innermost satellites. Portia heads a group of 8 inner satellites. The Portia Group consists of Bianca, Cressida, Desdemona, Juliet, Rosalind, Cupid, Belinda and Perdita. The Portian orbit is slowly decaying due to tidal deceleration and may one day either break apart to form a planetary ring or could potentially collide with Uranus. Orbits of the other satellites in the Portia Group have a similar fate.
Feb 07, 2015 | Miscellaneous
Name the moons of neptune
On July 15, a 14th moon of Neptune, provisionally called S/2004 N 1, was announced.
Outwards from Neptune, the inner moons are Naiad, Thalassa, Despina, Galatea, Larissa, S/2004 N 1 and Proteus.Next outward from Neptune, Triton is one of four moons in the solar system known to have an atmosphere. The thin nitrogen haze is thought to have evaporated off of the frozen surface.After Triton comes Nereid. Much further out than Nereid orbit five outer moons, Halimede, Sao, Laomedeia, Neso and Psmathe.
http://www.space.com/21977-neptune-moons-planet-facts-infographic.html
Feb 03, 2015 | Optics
Do solar panels need direct sunlight to work?
No. It will work in with diffused light too. Some sensitive ones will generate voltage even at moon-light.
Electro help
Nov 09, 2014 | Moultrie Feeders 12V Solar Panel
What are some nouns describing the sun and some nouns for the moon?
Nouns that describe the sun include day-star, solar disk, solar orb, eye of heaven, great luminary, light of the day, lamp of the day, source of light and giver of light.
  • Nouns do not describe; adjectives are the describing words for nouns.
  • The word moon is a noun, some adjectives that describe the moon are: bright, cool, round,full, half, new, crescent
Feb 28, 2014 | Hasbro Toys
What is special futures of uranus
Uranus was the first planet to be discovered in modern history. It was actually discovered by accident in 1781 by William Herschel.
Like the other gas giants, Uranus has a very thick cloud cover and an atmosphere made up mostly of hydrogen, helium, methane, and ammonia. The trace amount of methane is what gives Uranus and its twin, Neptune, their blue color. Unlike Saturn and Jupiter, Uranus has a different internal structure.
The core of Uranus is probably composed of liquid rock. Then, farther up, the liquid rock slowly gives way to an ocean made mostly of hydrogen, helium, and water, with small amounts of ammonia and methane. This "ocean" accounts for most of Uranus's bulk. Then, the water slowly thins out into the bland, almost featureless atmosphere.
Uranus also has a system of about 11 rings - not nearly as large as Saturn's. Nine were found when Uranus passed in front of a bright star, the rings causing the star to temporarily disappear when they passed in front of it. This was the first time astronomers had detected rings around any planet other than Saturn. It was the first time, also, that astronomers had detected thin rings around any planet. The other two rings were found when Voyager 2 passed by.
Uranus also has 27 known moons, most of which little is known about.
Uranus has two main unique features. First, there is absolutely no detail in the cloud cover. Only when pushed to the maximum level of color enhancement and contrast on computers do scientists start to see small swirls in the atmosphere.
uranus_rings.jpgSecond, Uranus is the only planet rotates on its side. This produces the strangest seasons of any planet in the solar system. For 21 years, Uranus's moons are seen as one would view a dart board, with one pole facing the sun. The next 21 years Uranus has its side to the sun, and the moons move up and down across the equator. then the cycle repeats itself starting with the other pole. Scientists aren't sure why this is, but they think that a large body smashed into it with such force that it pushed the planet over.
Mythology
Uranus was named for the ancient Greek god of the heavens. When Earth was first made, Uranus was the first thing she saw, and they fell in love.
Dec 11, 2013 | Cars & Trucks
The moon roof on my 1996 saturn sl2 not working
I have the same car and had the same problem, when you pull down the head liner you will find the motor for the moon roof. i disconnected the motor so that i could analyze it. i found that the gears in the moon roof motor are made of plastic and most of the gear teeth were chewed off. i disconnected the wireing harness from the motor and left it unplugged, i then pushed the moon roof back into position and tightened the screws to the moon roof. That is the way i left it for the past 2 years, because i was not about to spend the money t fix the motor.
Mar 20, 2009 | 1996 Saturn SL
Optics Logo
Top The Optics Experts
 steve
steve
Clyde Ottaway
deton8 von Splosion
Are you a The Optic Expert? Answer questions, earn points and help others
