How to remove knob of timer on Hoover700lc
Need to replace timer control but cant get knob off
shaggyrat
  • 1224 Answers
SOURCE: How can I replace a damaged timer control knob?
i was reading up on this item and i came across section where they mentioned you have to purchase 4 complete different replacement knob boxes or panels
heres the link boy this product is having one heck of time
http://www.reviewcentre.com/reviews105062.html
Posted on May 09, 2008
mikedurland
  • 481 Answers
SOURCE: replacing timer
  • push the timer in and turn it counter clockwise. this should unscrew it.
  • if that does not work, check the back of the timer for a black plastic tab. pull it out to unlock the timer knob from the timer.
  • there are many different styles of timer knobs.
Posted on Jun 29, 2008
  • 958 Answers
SOURCE: Removal of the timer knob.
you have two different knobs to replace?..is it the water level knob or the timer knob?
if its the timer knob you need to remove, look underneath the timer and you will find a black plastic pin depressed at the middle. pull it slowly for about 1/4 of an inch.
then you can remove the knob in the front of the timer switch.
in putting it back, install the knob first in the timer and then depressed that black plastic pin to lock the knob.
be carefull not to pull the plastic pin all the way out. it would be very hard to put it back in.
cheers,
drcool
Posted on Aug 02, 2008
aborcass
  • 2651 Answers
SOURCE: how to remove control knob on maytag mde8400ayw timer
youll need to "pop" the center of the dryer knob off, the outer mos part of the knobin which oyou turn is a false front, that actually locks the knob onto the timer shaft, use a small screw driver to pry it off
Posted on Jan 25, 2009
  • 197 Answers
SOURCE: how do i put the timer knob with indicater on the
lots af washing up liquid to lubricate the knob
Posted on Jul 12, 2009
How to replace the timer on a Kenmore 90 series washing machine?
The timer on a washing Kenmore washing machine is the brains of the unit. The timer controls how long the clothes are to be washed, rinsed, spun and dried. The timer is located behind the timer knob in the main control panel. If the timer fails, it can be replaced with just a few hand tools.
1 Unplug the washing machine's cord from the electrical outlet.
2 Remove the two screws securing the main-panel end caps with a Phillips-head screwdriver. Lift the main panel up and rotate it backward so the inside of the panel is exposed. If your model does not have end caps, slide a putty knife between the main panel and the washing machine's top, then pry up to free the panel from its retaining clips.
3 Turn the knob by hand from one side while looking at the back of the timer from the other side. You should see the timer knob's shaft turning. Grasp the black plastic locking tab in the center of the timer knob's shaft with a pair of needle-nose pliers and pull it out. You should feel a click.
4 Pull the timer knob off of its shaft. You may need to hold the locking tab with the pliers as you do this. Remove the trim plate from under the knob.
5 Unplug the wiring connector from the back of the timer. Remove the screws securing the timer to the main panel with a nut driver and remove the timer.
6 Install the new timer into the panel and secure it with the screws, using a nut driver. Install the timer's trim plate and wire connector.
7 Install the knob onto the timer's shaft. Make sure the locking tab is still pulled out before installing the knob. Once the knob is pushed onto the shaft, hold the knob with one hand while pushing the locking tab in from the other side. You should feel it click into position.
8 Reinstall the main panel and end caps, if applicable. Plug in the electrical cord and run the washer on various wash and rinse cycles to test that the timer is working.
Things You Will Need
  • Phillips-head screwdriver
  • Putty knife
  • Nut driver
  • Needle-nose pliers
  • Timer
Warning
  • Pulling or installing the timer knob without first pulling the locking tab can break the tab, the shaft or the knob.
Apr 24, 2014 | Kenmore 15944 Top Load Washer
HOW DOES ONE REMOVE THE WASHER TIMER (AND REPLACE IT) "FSP 3351744",ONCE THE CONTROL COVER IS OPEN?
Hello, Since you have the control panel open all you have to do is unscrew the timer knob and then remove the two screws under the knob to remove the timer. Hope this helps..
Jun 06, 2011 | Whirlpool Kitchen Ranges
I have a Whirlpool washing machine LA8800XT. It seems the timer knob can no longer engage the timer shaft. Part number of the timer is 3352091. I am positive the machine and the timer are fine. I tried...
I have a Whirlpool washer #LA8800XT and want to remove the Fabric Softener dispenser so I can remove the agitator. Does it just screw off? It seems to be stuck and I didn't want to break it if it didn't screw off.
Oct 09, 2010 | Whirlpool 3362624 Washer Control Timer...
The timing knob on my dryer wouldn't turn, it would just spin without selecting a setting so I pulled the knob off and tried using pliers to turn the plastic shaft to select a setting. It worked a couple...
Both the timer and the knob is replaceable.
Locate the model number of the unit. Here's info on how to find it:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=+86673100&pathTaken=partSearch
You can get the timer and the knob from www.searspartsdirect.com or call 1-800-252-1698.
Once you have the part, remove the screws from the back of the control panel, removing the back cover. From there you should see the timer. It will either have one wiring harness or many wires attached to the timer. INSURE UNIT IS UNPLUGGED WITH NO POWER TO IT. If there is a harness, unplug the harness. The timer will be held in place either by a couple screws on the front of the control panel that is normally hidden by the knob AND/OR a screw INSIDE the control panel at the timer. There could also be a plastic tab holding the timer in place. Raise this tab and turn timer until it is free. Remove timer and put new timer in place. Fit harness onto timer.
If there are many wires attached to the old timer, I would hold the new timer in my hand and transfer the wires one-by-one to insure you get the right wires on the right terminal tab. Once wires are transferred, remove old timer and put new timer in place.
At this point. put new knob on the timer on the front of the control panel. Plug unit in, stay clear of exposed wiring, and test dryer. If it works, replace back cover and you are done.
If it doesn't work, further troubleshooting will be needed and Ill need the make and model number.
Hope this helps. Please take a minute to give a testimonial if I've help you.
Thanks, G
Aug 04, 2010 | Dryers
How do you access the control panel the knob that sets the wash cycles is broken and needs replaced
The topside control panel has four small torx screws that hold the control panel to the rear. The timer has a small U clip under the knob that needs to be removed with needle nose and then the knob comes off so the timer can be replaced. I have your washer's training manual HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 20, 2010 | GE WJSR2070B Top Load Washer
How to remove control knob on maytag mde8400ayw timer
Jan 25, 2009 | Maytag Atlantis MDE8400AY Electric...
Control knob will not turn to desired setting
the timer knob has a clip that will allow you to remove the knob from the timer. it is between the knob and the dial. what happens is the knob has gear like teeth that will become stripped out.it is easy to replace but alittle hard to remove. you need to get a small screwdriver and go behind the knob, pull on it alittle and you will see the clip, then use the screwdriver to push the clip out of the knob, then the knob will pull of and you can replace it.
Dec 28, 2008 | GE WJRR4170E Top Load Washer
cheers,
drcool
Aug 02, 2008 | Frigidaire GLWS1339CS Top Load Washer
Timer Knob
The clip pulls straight up off the shaft directly behind the knob. You can use a small screwdriver or a pair of needlenose pliers to pull it out. Once the clip is removed the knob will slide off the timer shaft.
Apr 21, 2008 | GE WDSR2080D Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
